path: root/drivers/phy
2018-05-14phy: marvell: a3700: Use reg_set_indirect istead of 2 reg_setsMarek Behún
Create a special function for indirect register setting, reg_set_indirect, and use it instead of the two calls to reg_set. Signed-off-by: Marek Behun <marek.behun@nic.cz> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2018-05-14phy: marvell: a3700: Use (!ret) instead of (ret == 0)Marek Behún
In U-Boot it is usually written this way. Signed-off-by: Marek Behun <marek.behun@nic.cz> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2018-05-14phy: marvell: a3700: Use same timeout for all register pollingMarek Behún
The timeout is set to PLL_LOCK_TIMEOUT in every call to comphy_poll_reg. Remove this parameter from the function. Signed-off-by: Marek Behun <marek.behun@nic.cz> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2018-05-14phy: marvell: a3700: Don't create functional macro for each registerMarek Behún
Currently there is for each register special functional macro, ie: LANE_CFG1_ADDR(u) GLOB_CLK_SRC_LO_ADDR(u) ... where can be either PCIE or USB3. Change this to one function PHY_ADDR(unit, addr). The code becomes: phy_addr(PCIE, LANE_CFG1) phy_addr(PCIE, GLOB_CLK_SRC_LO) ... Signed-off-by: Marek Behun <marek.behun@nic.cz> Signed-off-by: Stefan Roese <sr@denx.de>
2018-05-14phy: marvell: a3700: Use reg_set16 instead of phy_write16Marek Behún
The macro phy_write16 is not used by the rest of the code, phy_read16 is not used at all. We also change the macro SGMIIPHY_ADDR to a static inline function. Signed-off-by: Marek Behun <marek.behun@nic.cz> Signed-off-by: Stefan Roese <sr@denx.de>
2018-05-14phy: marvell: a3700: Change return type of macro MVEBU_REGMarek Behún
All the calls to reg_set and friends have to cast the first argument to void __iomem *. Lets change the return type of the MVEBU_REG macro instead. Signed-off-by: Marek Behun <marek.behun@nic.cz> Signed-off-by: Stefan Roese <sr@denx.de>
2018-05-07regmap: change regmap_init_mem() to take ofnode instead udeviceMasahiro Yamada
Currently, regmap_init_mem() takes a udevice. This requires the node has already been associated with a device. It prevents syscon/regmap from behaving like those in Linux. Change the first argumenet to take a device node. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Neil Armstrong <narmstrong@baylibre.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-05-07regmap: clean up regmap allocationMasahiro Yamada
Putting zero length array at the end of struct is a common technique to embed arbitrary length of members. There is no good reason to let regmap_alloc_count() branch by "if (count <= 1)". As far as I understood the code, regmap->base is an alias of regmap->ranges[0].start, but it is not helpful but make the code just ugly. Rename regmap_alloc_count() to regmap_alloc() because the _count suffix seems pointless. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: fixup cpu_info-rcar.c] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-04-27Remove unnecessary instances of DECLARE_GLOBAL_DATA_PTRTom Rini
We have a large number of places where while we historically referenced gd in the code we no longer do, as well as cases where the code added that line "just in case" during development and never dropped it. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-04-11phy: Add Amlogic Meson USB2 & USB3 Generic PHY driversNeil Armstrong
The Amlogic Meson GXL and GXM (simple variant) embeds up to 3 USB2 PHYs and an USB3 PHY. This patch adds drivers for these for the standard generic PHY interface and supports the power-on/off calls and set the Host mode by default. They are based on the excellent work from Martin Blumenstingl merged in linux. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2018-03-21phy: add support for bcm6318 usbh phyÁlvaro Fernández Rojas
Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2018-03-21phy: add support for bcm6368 usbh phyÁlvaro Fernández Rojas
2018-03-21phy: add support for bcm6358 usbh phyÁlvaro Fernández Rojas
2018-03-21phy: add support for bcm6348 usbh phyÁlvaro Fernández Rojas
2018-03-05libfdt: move headers to <linux/libfdt.h> and <linux/libfdt_env.h>Masahiro Yamada
Thomas reported U-Boot failed to build host tools if libfdt-devel package is installed because tools include libfdt headers from /usr/include/ instead of using internal ones. This commit moves the header code: include/libfdt.h -> include/linux/libfdt.h include/libfdt_env.h -> include/linux/libfdt_env.h and replaces include directives: #include <libfdt.h> -> #include <linux/libfdt.h> #include <libfdt_env.h> -> #include <linux/libfdt_env.h> Reported-by: Thomas Petazzoni <thomas.petazzoni@bootlin.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-11-06sti: fix STMicroelectronics copyrightPatrice Chotard
Uniformize all STMicroelectronics copyrights headers for STi related code. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2017-10-04treewide: replace with error() with pr_err()Masahiro Yamada
U-Boot widely uses error() as a bit noisier variant of printf(). This macro causes name conflict with the following line in include/linux/compiler-gcc.h: # define __compiletime_error(message) __attribute__((error(message))) This prevents us from using __compiletime_error(), and makes it difficult to fully sync BUILD_BUG macros with Linux. (Notice Linux's BUILD_BUG_ON_MSG is implemented by using compiletime_assert().) Let's convert error() into now treewide-available pr_err(). Done with the help of Coccinelle, excluing tools/ directory. The semantic patch I used is as follows: // <smpl> @@@@ -error +pr_err (...) // </smpl> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Re-run Coccinelle] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-22usb: phy: Add STi USB2 PHYPatrice Chotard
This is the generic phy driver for the picoPHY ports used by USB2/1.1 controllers. It is found on STiH407 SoC family from STMicroelectronics. Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-28phy: add a NO-OP phy driverJean-Jacques Hiblot
This driver is used to stub PHY operations in a driver (USB, SATA). This is useful when the 'client' driver (USB, SATA, ...) uses the PHY framework and there is no actual PHY harwdare to drive. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2017-07-28drivers: phy: Set phy->dev to NULL when generic_phy_get_by_index() failsPatrice Chotard
phy->dev need to be set to NULL in case of generic_phy_get_by_index() fails. Then phy->dev can be used to check if the phy is valid Reported-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-10pipe3: Fix broken dependencyJean-Jacques Hiblot
ARCH_OMAP2 has been renamed ARCH_OMAP2PLUS in commit a93fbf4a7892 ("ARM: omap2+: rename config to ARCH_OMAP2PLUS and consolidate Kconfig") Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-06-01sandbox: phy: Update driver for livetreeSimon Glass
Update the sandbox phy driver to support livetree. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-01dm: phy: Update uclass to support livetreeSimon Glass
Update the phy uclass to support livetree. Fix the xlate() method which has no callers. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-01dm: core: Rename of_device_is_compatible()Simon Glass
The of_ prefix conflicts with the livetree version of this function. Rename it to avoid problems when we add livetree support. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-01dm: core: Replace of_offset with accessor (part 2)Simon Glass
At present devices use a simple integer offset to record the device tree node associated with the device. In preparation for supporting a live device tree, which uses a node pointer instead, refactor existing code to access this field through an inline function. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-01dm: Rename dev_addr..() functionsSimon Glass
These support the flat device tree. We want to use the dev_read_..() prefix for functions that support both flat tree and live tree. So rename the existing functions to avoid confusion. In the end we will have: 1. dev_read_addr...() - works on devices, supports flat/live tree 2. devfdt_get_addr...() - current functions, flat tree only 3. of_get_address() etc. - new functions, live tree only All drivers will be written to use 1. That function will in turn call either 2 or 3 depending on whether the flat or live tree is in use. Note this involves changing some dead code - the imx_lpi2c.c file. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-09Merge git://git.denx.de/u-boot-dmTom Rini
2017-05-09drivers: phy: add PIPE3 phy driverJean-Jacques Hiblot
This phy is found on omap platforms with sata capabilities. Except for the part related to the DM and the PHY framework, the code is basically a copy paste from arch/arm/mach-omap2/pipe3-phy.c Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-09dm: test: Add tests for the generic PHY uclassJean-Jacques Hiblot
Those tests check: - the ability for a phy-user to get a phy based on its name or its index - the ability of a phy device (provider) to manage multiple ports - the ability to perform operations on the phy (init,deinit,on,off) - the behavior of the uclass when optional operations are not implemented Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-09drivers: phy: add generic PHY frameworkJean-Jacques Hiblot
The PHY framework provides a set of APIs to control a PHY. This API is derived from the linux version of the generic PHY framework. Currently the API supports init(), deinit(), power_on, power_off() and reset(). The framework provides a way to get a reference to a phy from the device-tree. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-09fix: phy: marvell: cp110: pcie: update analog parameters according to latest ETPIgal Liberman
Add PCIE analog parameters initialization values according to latest ETP. Signed-off-by: Igal Liberman <igall@marvell.com> Reviewed-by: Stefan Roese <sr@denx.de>
2017-05-09fix: phy: marvell: cp110: rename comphy_index to cp_indexIgal Liberman
No functional change. The variable name "comphy_index" is misleading, it represents cp index and not comphy index. Signed-off-by: Igal Liberman <igall@marvell.com> Reviewed-by: Stefan Roese <sr@denx.de>
2017-05-09fix: phy: marvell: cp110: sfi: update analog parameters according to latest ETPIgal Liberman
Add SFI analog parameters initialization values according to latest ETP. Signed-off-by: Igal Liberman <igall@marvell.com> Reviewed-by: Stefan Roese <sr@denx.de>
2017-05-09phy: marvell: print comphy status even when it's disconnectedStefan Roese
since now the COMPHY can also be ignored, we must know the state of the COMPHY. we cannot assume anymore that a missing COMPHY is unconnected. Signed-off-by: Yehuda Yitschak <yehuday@marvell.com> Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Igal Liberman <igall@marvell.com> Reviewed-by: Stefan Roese <sr@denx.de>
2017-05-09fix: phy: marvell: cp110: fix comphy lane 4 selection optionsStefan Roese
The comphy configuration is incorrect. Set the correct values for SGMII. In addition, remove xaui from the comment as it is not supported. Signed-off-by: Yoav Gvili <ygvili@marvell.com> Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Igal Liberman <igall@marvell.com> Reviewed-by: Stefan Roese <sr@denx.de>
2017-05-09phy: marvell: cp110: add 5G XFI modeIgal Liberman
This patch adds the option to configure a comphy to 5G XFI mode. In order to configure the comphy to 5G XFI, update the comphy node in the device-tree: phy2 { phy-type = <PHY_TYPE_SFI>; phy-speed = <PHY_SPEED_5_15625G>; }; Signed-off-by: Igal Liberman <igall@marvell.com> Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Stefan Roese <sr@denx.de>
2017-05-09fix: phy: marvell: cp110: update comphy selector optionStefan Roese
Align PHY selectors register with Armada-CP-110 functional SPEC update all relevant device trees with this change. Signed-off-by: Hanna Hawa <hannah@marvell.com> Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Igal Liberman <igall@marvell.com> Reviewed-by: Stefan Roese <sr@denx.de>
2017-05-09fix: phy: marvell: cp110: sata: update analog parameters according to latest ETPIgal Liberman
Add SATA analog parameters initialization values according to latest ETP. Signed-off-by: Konstantin Porotchkin <kostap@marvell.com> Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Igal Liberman <igall@marvell.com> Reviewed-by: Stefan Roese <sr@denx.de>
2017-05-09fix: phy: marvell: cp110: fix the KR/SFI line 4 selectorStefan Roese
This patch fixes the following: 1. KR/SFI on lane #4 mux selector is 0x2 and not 0x1 2. Comment typo Signed-off-by: Rabeeh Khoury <rabeeh@solid-run.com> Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Igal Liberman <igall@marvell.com> Reviewed-by: Stefan Roese <sr@denx.de>
2017-05-09phy: marvell: add IGNORE COMPHY typeStefan Roese
This type tells u-boot to preserve the COMPHY settings as is it is usefull in situations where the COMPHY was initialized by earlier firmware. Note that IGNORE is different from UNCONNECTED since setting UNCONNECTED type will disconnect the COMPHY in the COMPHY MUX which is a desired behaviour Signed-off-by: Yehuda Yitschak <yehuday@marvell.com> Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Igal Liberman <igall@marvell.com> Reviewed-by: Stefan Roese <sr@denx.de>
2017-05-09phy: marvell: cp110: update utmi phy connection typeStefan Roese
UTMI_PHY_TO_USB_HOST was used in USB3 UTMI dts node only, but there will be USB2 UTMI dts node for some SoCs that have got USB2 controller, so rename TO_USB_HOST to TO_USB3_HOST to distinguish TO_USB2_HOST in later on patches. Signed-off-by: zachary <zhangzg@marvell.com> Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Igal Liberman <igall@marvell.com> Reviewed-by: Stefan Roese <sr@denx.de>
2017-05-09phy: marvell: cp110: add support for end point configurationStefan Roese
The serdes was always configured in root complex mode. this patch add new entry in device tree (per serdes) which indicates whether the serdes is in end point mode. if so, it skips the root complex configuration. Signed-off-by: Haim Boot <hayim@marvell.com> Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Igal Liberman <igall@marvell.com> Reviewed-by: Stefan Roese <sr@denx.de>
2017-05-09phy: marvell: Replace PHY_TYPE_KR with PHY_TYPE_SFIStefan Roese
Use correct naming as done in the latest Marvell U-Boot version as well. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Igal Liberman <igall@marvell.com> Reviewed-by: Stefan Roese <sr@denx.de>
2017-05-09fix: mvebu_ comphy: Update COMPHY sequence numberKonstantin Porotchkin
Use local static counter for maintaining the COMPHY chip-ID upon its initialization. The dev->seq originally used as the COMPHY chip-ID depends on the device tree scan order and produces wrong results that breaks the deficated PHYs init flow, which in turn breaks the USB support. Change-Id: I4e3f7ec36590a7f95dc94d9269a3c47fb708c4a9 Signed-off-by: Konstantin Porotchkin <kostap@marvell.com> Cc: Stefan Roese <sr@denx.de> Cc: Igal Liberman <igall@marvell.com> Cc: Stefan Chulski <stefanc@marvell.com> Cc: Nadav Haklai <nadavh@marvell.com> Reviewed-by: Stefan Roese <sr@denx.de>
2017-02-08dm: core: Replace of_offset with accessorSimon Glass
2017-02-01phy: comphy_a3700: Change SD/MMC compatible DT node to match the updatesStefan Roese
Now that the SD/SDIO/MMC DT properties are updated in the Marvell A3700 and A7/8k DT files, we need to match the checks for compatible node in the PHY driver as well. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Kostya Porotchkin <kostap@marvell.com> Cc: Nadav Haklai <nadavh@marvell.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2016-12-05drivers/phy: marvell: Add support for the slave CP COMPHY deviceStefan Roese
With the support for the Armada 8k, a 2nd COMPHY controller now needs to get supported from the CP110 slave controller. This patch adds support for this 2nd contoller in the COMPHY driver. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Nadav Haklai <nadavh@marvell.com> Cc: Neta Zur Hershkovits <neta@marvell.com> Cc: Kostya Porotchkin <kostap@marvell.com> Cc: Omri Itach <omrii@marvell.com> Cc: Igal Liberman <igall@marvell.com> Cc: Haim Boot <hayim@marvell.com> Cc: Hanna Hawa <hannah@marvell.com>
2016-12-04marvell: comphy_a3700: fix bitmaskAndre Przywara
Obviously the mask for the rx and tx select field cannot be right, as it would overlap in one and exceed the 32-bit register in the other case. From looking at the neighbouring bits it looks like the mask should be really 4 bits wide instead of 8. Pointed out by a GCC 6.2 (default) warning. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Stefan Roese <sr@denx.de>
2016-10-13libfdt: Sync fdt_for_each_subnode() with upstreamSimon Glass
The signature for this macro has changed. Bring in the upstream version and adjust U-Boot's usages to suit. Signed-off-by: Simon Glass <sjg@chromium.org> Update to drivers/power/pmic/palmas.c: Signed-off-by: Keerthy <j-keerthy@ti.com> Change-Id: I6cc9021339bfe686f9df21d61a1095ca2b3776e8
