path: root/drivers/pcmcia
2014-09-24kconfig: add blank Kconfig filesMasahiro Yamada
This would be useful to start moving various config options. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-08-21powerpc: mpc8xx: remove svm_sc8xx boardMasahiro Yamada
This board has been orphaned for a while and old enough. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-07-07mpc8xx: remove RPXlite_dw, quantum board supportMasahiro Yamada
These boards are old enough and have no maintainers. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-04-18powerpc: remove RPXClassic, RPXlite boards supportMasahiro Yamada
Enough time has passed since these boards were moved to Orphan. Remove. - Remove board/RPXlite/* - Remove board/RPXClassic/* - Remove include/configs/RPXlite.h - Remove include/configs/RPXClassic.h - Clean-up defined(CONFIG_RPXCLASSIC) - Move the entry from boards.cfg to doc/README.scrapyard Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-10-31drivers: convert makefiles to Kbuild styleMasahiro Yamada
2012-03-26PXA: Remove PXA PCMCIA supportMarek Vasut
Say good bye to some ancient, very broken and unused code. Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
2011-11-07drivers/pcmcia/mpc8xx_pcmcia.c: Fix GCC 4.6 build warningWolfgang Denk
Fix: mpc8xx_pcmcia.c: In function 'pcmcia_on': mpc8xx_pcmcia.c:76:8: warning: variable 'slotbit' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-10-27GCC4.6: Squash error in pcmcia/i82365.cMarek Vasut
i82365.c: In function 'cirrus_set_opts': i82365.c:329: error: 'buf' undeclared (first use in this function) i82365.c:329: error: (Each undeclared identifier is reported only once i82365.c:329: error: for each function it appears in.) Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Mike Frysinger <vapier@gentoo.org>
2011-10-27GCC4.6: Squash warnings in tqm8xx_pcmcia.cMarek Vasut
tqm8xx_pcmcia.c: In function 'power_off': tqm8xx_pcmcia.c:46: warning: passing argument 1 of 'out_be32' makes pointer from integer without a cast tqm8xx_pcmcia.c: In function 'power_on_5_0': tqm8xx_pcmcia.c:52: warning: passing argument 1 of 'out_be32' makes pointer from integer without a cast tqm8xx_pcmcia.c: In function 'power_on_3_3': tqm8xx_pcmcia.c:58: warning: passing argument 1 of 'out_be32' makes pointer from integer without a cast Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Mike Frysinger <vapier@gentoo.org>
2011-10-05PPC: Cleanup tqm8xx_pcmcia.cMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Tested-by: Wolfgang Denk <wd@denx.de> Acked-by: Wolfgang Denk <wd@denx.de>
2011-08-04Convert ISO-8859 files to UTF-8Albert ARIBAUD
There was a mix of UTF-8 and ISO-8859 files in the U-Boot source tree, which could cause issues with the patchwork review system. This commit converts all ISO-8859 files to UTF-8. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2010-09-19Remove HMI10 board supportWolfgang Denk
Recent changes caused that the HMI10 board now is included in the boards built by MAKEALL, which revealed that compilation for this board has been broken for a long time: ps2ser.c: In function 'ps2ser_init': ps2ser.c:155: error: 'UART_LCR' undeclared (first use in this function) ps2ser.c:155: error: (Each undeclared identifier is reported only once ps2ser.c:155: error: for each function it appears in.) ps2ser.c:156: error: 'UART_DLL' undeclared (first use in this function) ps2ser.c:157: error: 'UART_DLM' undeclared (first use in this function) ps2ser.c:159: error: 'UART_IER' undeclared (first use in this function) ps2ser.c:160: error: 'UART_MCR' undeclared (first use in this function) ps2ser.c:161: error: 'UART_FCR' undeclared (first use in this function) ps2ser.c:162: error: 'UART_FCR_ENABLE_FIFO' undeclared (first use in this function) ps2ser.c:166: error: 'UART_LSR' undeclared (first use in this function) ps2ser.c: In function 'ps2ser_putc': ps2ser.c:198: error: 'UART_LSR' undeclared (first use in this function) ps2ser.c:200: error: 'UART_TX' undeclared (first use in this function) ps2ser.c: In function 'ps2ser_getc_hw': ps2ser.c:224: error: 'UART_LSR' undeclared (first use in this function) ps2ser.c:225: error: 'UART_RX' undeclared (first use in this function) ps2ser.c: In function 'ps2ser_interrupt': ps2ser.c:293: error: 'UART_IIR' undeclared (first use in this function) The board is orphaned, and AFAICT has reached EOL. Drop support for it. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-09-04Misc ti_pci1410a fixupsGraeme Russ
Removed do_pinit() - now declared in cmd_pcmcia.c Added #define CONFIG_CMD_PCMCIA around pcmcia_off() in line with other PCMCIA drivers signed/unsigned type fixups Added semi-colon after default: label as required by newer gcc The only board that appears to use this driver is the sc520_spunk which is very old and very likely very broken anyway. I do not have one to test whether this patch breaks anything functionaly, I have can only check that it compiles without warning or error Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2009-02-18mpc8xx_pcmcia: move CONFIG_8xx out of .c file and into MakefileMike Frysinger
Move the CONFIG_8xx mpc8xx_pcmcia.c protection out of the C file and into the Makefile so we avoid pointless compiling of the file. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-06-26pcmcia/ti_pci1410a: Move compile condition to the MakefileJean-Christophe PLAGNIOL-VILLARD
2008-06-26pxa_pcmcia: Move compile condition to the MakefileJean-Christophe PLAGNIOL-VILLARD
2008-06-26marabun_pcmcia: Move compile condition to the MakefileJean-Christophe PLAGNIOL-VILLARD
2008-05-19drivers/pcmcia: add missing i82365Jean-Christophe PLAGNIOL-VILLARD
2008-05-03pxa: fix pcmcia operation on 'i' may be undefinedJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-01-15pcmcia: Remove CONFIG_COMMANDS from marubun pcmcia driverNobuhiro Iwamatsu
2007-12-27Fix coding style issues; update CHANGELOG.Wolfgang Denk
2007-12-07sh: Moved driver of the SuperH dependenceNobuhiro Iwamatsu
The composition of the directory in the drivers/ changed. I moved SuperH serial driver and marubun PCMCIA driver. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2007-11-24drivers/pcmcia : move pcmcia drivers to drivers/pcmciaJean-Christophe PLAGNIOL-VILLARD
