path: root/drivers/pci_indirect.c
2006-01-12Fixed PCI indirect config ops to handle multiple PCI controllersKumar Gala
We need to adjust the bus number we are trying to access based on which PCI controller its on Patch by Kumar Gala 12 Jan 2006
2005-09-25Fix warnings for PCI code on ixpWolfgang Denk
Patch by Joe <lgxue@yahoo.com>, 13 Jan 2005
2005-08-08Changed CONFIG_440_xx to CONFIG_440xx for a consistent design (405 and linux)Stefan Roese
Patch by Stefan Roese, 08 Aug 2005
2005-08-01Add support for AMCC PPC440EP/GR eval boards Yosemite and Yellowstone.Stefan Roese
Patch by Steven Blakeslee, 27 Jul 2005
2005-01-12* Some Cleanup.wdenk
* Patch by Richard Woodruff, 10 Jan 2005: Update support for OMAP2420 (ARM11) and H4 board: o clean up and add new types to H4 memory probe code. o fix to work with internal boot. o added PRCM config III operation. o fix marginal flash timings. o add revison ATAG usage. o enable voltage scaling at power chip. o fix compile error for i2c. * Fix network problem (error when receiving multiple ARP packets)
2004-02-22* Patch by Travis Sawyer, 09 Feb 2004:wdenk
o 440GX: - Fix PCI Indirect access for type 1 config cycles with ppc440. - Add phymode for 440 enet - fix pci pre init o XPedite1K: - Change board_pre_init to board_early_init_f - Add user flash to bus controller setup - Fix pci pre init - Fix is_pci_host to check GPIO for monarch bit - Force xpedite1k to pci conventional mode (via #define option) * Patch by Brad Kemp, 4 Feb 2004: - handle the machine check that is generated during the PCI scans on 82xx processors. - define the registers used in the IMMR by the PCI subsystem. * Patch by Pierre Aubert, 03 Feb 2004: cpu/mpc5xxx/start.S: copy MBAR into SPR311 * Patch by Jeff Angielski, 03 Feb 2004: Fix copy & paste error in cpu/mpc8260/pci.c * Patch by Reinhard Meyer, 24 Jan 2004: Fix typo in cpu/mpc5xxx/pci_mpc5200.c
2003-05-22* Patch by Dave Ellis, 22 May 2003:LABEL_2003_05_23_0055wdenk
Fix problem with only partially cleared .bss segment * Patch by Rune Torgersen, 12 May 2003: get PCI to work on a MPC8266ADS board; incorporate change to cpu/mpc8260/pci.c to enable overrides of PCI memory parameters
2003-05-18Add support for CompactFlash on ATC boardwdenk
(includes support for Intel 82365 and compatible PC Card controllers, and Yenta-compatible PCI-to-CardBus controllers)
2003-03-25Add PCI support for MPC8250 Boards (PM825 module)wdenk
2002-11-21* Added support for both PCMCIA slots (at the same time!) on MPC8xxLABEL_2002_11_22_0015wdenk
* Patch by Rod Boyce, 21 Nov 2002: fix PCMCIA on MBX8xx board * Patch by Pierre Aubert , 21 Nov 2002 Add CFG_CPM_POST_WORD_ADDR to make the offset of the bootmode word in DPRAM configurable
