o 440GX:
- Fix PCI Indirect access for type 1 config cycles with ppc440.
- Add phymode for 440 enet
- fix pci pre init
o XPedite1K:
- Change board_pre_init to board_early_init_f
- Add user flash to bus controller setup
- Fix pci pre init
- Fix is_pci_host to check GPIO for monarch bit
- Force xpedite1k to pci conventional mode (via #define option)
* Patch by Brad Kemp, 4 Feb 2004:
- handle the machine check that is generated during the PCI scans
on 82xx processors.
- define the registers used in the IMMR by the PCI subsystem.
* Patch by Pierre Aubert, 03 Feb 2004:
cpu/mpc5xxx/start.S: copy MBAR into SPR311
* Patch by Jeff Angielski, 03 Feb 2004:
Fix copy & paste error in cpu/mpc8260/pci.c
* Patch by Reinhard Meyer, 24 Jan 2004:
Fix typo in cpu/mpc5xxx/pci_mpc5200.c
- Added Motorola CPU 8540/8560 support (cpu/85xx)
- Added Motorola MPC8540ADS board support (board/mpc8540ads)
- Added Motorola MPC8560ADS board support (board/mpc8560ads)
* Minor code cleanup
Fix problem with only partially cleared .bss segment
* Patch by Rune Torgersen, 12 May 2003:
get PCI to work on a MPC8266ADS board; incorporate change to
cpu/mpc8260/pci.c to enable overrides of PCI memory parameters
(includes support for Intel 82365 and compatible PC Card controllers,
and Yenta-compatible PCI-to-CardBus controllers)
* Patch by Rod Boyce, 21 Nov 2002:
fix PCMCIA on MBX8xx board
* Patch by Pierre Aubert , 21 Nov 2002
Add CFG_CPM_POST_WORD_ADDR to make the offset of the
bootmode word in DPRAM configurable
