Rename the pci header for FSL HW so we can move some prototypes
in there and stop doing explicit externs
Some register value was hardcoded for System memory size 128MB and
memory offset 0x08000000. This patch fixed the problem.
Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com>
It is necessary for some pci device driver.
This is just a handy routine that reports last PCI busno: we walk
down all the hoses and return last hose's last_busno.
Will be used by PCI/PCIe initialization code.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
It is no longer always true that the pci bus address can be
used as the virtual address for pci accesses. pci_map_bar()
is created to return the virtual address for a pci region.
Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
When we search for an address match in pci_hose_{phys_to_bus,bus_to_phys}
we should give preference to memory regions that aren't system memory.
Its possible that we have over mapped system memory in the regions and
we want to avoid depending on the order of the regions.
The PCI_REGION_MEMORY and PCI_REGION_MEM are a bit to similar and
can be confusing when reading the code.
Rename PCI_REGION_MEMORY to PCI_REGION_SYS_MEMORY to clarify its used
for system memory mapping purposes.
Add fsl_pci_config_unlock() function to enable a
PCI/PCIe interface configured in agent/endpoint mode to
respond to inbound PCI configuration cycles.
fsl_pci_init.c: In function 'fsl_pci_setup_inbound_windows':
fsl_pci_init.c:122: warning: comparison is always true due to limited range of data type
The check only makes sense if we are CONFIG_PHYS_64BIT
The current code will cause the creation of a 4GB window
starting at 0 if we have more than 4GB of RAM installed,
which overlaps with PCI_MEM space and causes pci_bus_to_phys()
to return erroneous information. Limit the size to 4GB - 1;
which causes the code to create one 2GB and one 1GB window
instead.
Acked-by: Andy Fleming <afleming@freescale.com>
The existing code has a few errors that need to be fixed in
order to support large RAM sizes. Fix those, and add a
comment to make it clearer.
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
Acked-by: Kumar Gala <galak@kernel.crashing.org>
Signed-off-by: Andrew Fleming-AFLEMING <afleming@freescale.com>
Add a common setup function that determines the pci_region(s) based
on how much memory we have in the system.
* PCI Inbound window was setup incorrectly. The PCI address and system
address were swapped. The PCI address should be setting piwar/piwbear
and the system address should be setting pitar.
* Removed masking of addresses to allow for system address to support
system address & PCI address >32-bits
* Set PIWBEAR & POTEAR to allow for full 64-bit PCI addresses
* Respect the PCI_REGION_PREFETCH for inbound windows
PCI bus is inherently 64-bit. While not all system require access to
the full 64-bit PCI address range some do. This allows those systems
to enable the full PCI address width via CONFIG_SYS_PCI_64BIT.
Acked-by: Wolfgang Denk <wd@denx.de>
Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
Add function of new PCI, pci_skip_dev and pci_print_dev.
Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com>
This patch moves the check, if a device should be skipped in PCI PNP
configuration into the function pci_skip_dev(). This function is defined
as weak so that it can be overwritten by a platform specific one if
needed. The check if the device should get printed in the PCI summary upon
bootup (when CONFIG_PCI_SCAN_SHOW is defined) is moved to the function
pci_print_dev() which is also defined as weak too.
This was configured to use the deprecated CONFIG_OF_FLAT_TREE, change
to CONFIG_OF_LIBFDT.
WARNING: This conversion is untested because I do not have a board to
test it on.
NOTE: The FDT blob (DTS) must have an /aliases/ethernet0 and (optionally)
/aliases/ethernet1 property for the ethernet to work.
Signed-off-by: Gerald Van Baren <vanbaren@cideas.com>
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
This reverts commit 55774b512fdf63c0516d441cc5da7c54bbffb7f2
which broke many PowerPC boards.
Physical addrs need to be represented by phys_addr_t, not
unsigned long. Otherwise, systems that use CONFIG_PHYS_64BIT
are going to fail mightily.
pme_msg_det exists only on PCIe controllers only set it if we are a "bridge".
Remove test for CONFIG_MPC5200 in drivers/pci/pci_auto.c and define
CONFIG_PCIAUTO_SKIP_HOST_BRIDGE in related board configuration files.
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
In current source code, when the device number of PCI is 0, process PCI
bridge without fail. However, when the device number is 0, it is not PCI
always bridge. There are times when device of PCI allocates.
When CONFIG_PCI_SKIP_HOST_BRIDGE is enable, this problem is solved when
use this patch.
On the MPC85xx boards that have PCIe enable the PCIe errata fix.
(MPC8544DS, MPC8548CDS, MPC8568MDS).
