path: root/drivers/pci/pcie_layerscape_fixup_common.h
2020-07-17treewide: convert bd_t to struct bd_info by coccinelleMasahiro Yamada
The Linux coding style guide (Documentation/process/coding-style.rst) clearly says: It's a **mistake** to use typedef for structures and pointers. Besides, using typedef for structures is annoying when you try to make headers self-contained. Let's say you have the following function declaration in a header: void foo(bd_t *bd); This is not self-contained since bd_t is not defined. To tell the compiler what 'bd_t' is, you need to include <asm/u-boot.h> #include <asm/u-boot.h> void foo(bd_t *bd); Then, the include direcective pulls in more bloat needlessly. If you use 'struct bd_info' instead, it is enough to put a forward declaration as follows: struct bd_info; void foo(struct bd_info *bd); Right, typedef'ing bd_t is a mistake. I used coccinelle to generate this commit. The semantic patch that makes this change is as follows: <smpl> @@ typedef bd_t; @@ -bd_t +struct bd_info </smpl> Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
2020-01-24pci: layerscape: device tree fixup based on SoC andWasim Khan
lx2160a rev1 requires layerscape_gen4 device tree fixup and lx2160a rev2 requires layerscape device tree fixup. Add device tree fixup for lx2160a based on SoC and Version. Signed-off-by: Wasim Khan <wasim.khan@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-01-24pci: layerscape: Move streamId allocation to common device tree fixupWasim Khan
Move streamId allocation to layerscape common device tree fixup. Calculate streamId based on SoC variant. Signed-off-by: Wasim Khan <wasim.khan@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-01-24pci: layerscape: Common device tree fixup for NXP SoCsWasim Khan
Add Common device tree fixup for NXP SoCs. Based on SoC and revision call pcie_layerscape or pcie_layerscape_gen4 fixup. Signed-off-by: Wasim Khan <wasim.khan@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
