path: root/drivers/pci/pci_indirect.c
2011-06-23IXP42x PCI rewriteMichael Schwingen
clean up IXP PCI handling: get rid of IXP-private bus scan, BAR assign etc. code and use u-boot's PCI infrastructure instead. Move board-specific PCI setup code (clock/reset) to board directory. Signed-off-by: Michael Schwingen <michael@schwingen.org>
2010-01-23ppc4xx: Fix sending type 1 PCI transactionsFelix Radensky
The list of 4xx SoCs that should send type 1 PCI transactions is not defined correctly. As a result PCI-PCI bridges and devices behind them are not identified. The following 4xx variants should send type 1 transactions: 440GX, 440GP, 440SP, 440SPE, 460EX and 460GT. Signed-off-by: Felix Radensky <felix@embedded-sol.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-08-13drivers/pci: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2007-11-24drivers/pci : move pci drivers to drivers/pciJean-Christophe PLAGNIOL-VILLARD
