path: root/drivers/pci/pci_common.c
2019-08-11env: Move env_get() to env.hSimon Glass
Move env_get() over to the new header file. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-01-18dm: pci: remove pci_bus_to_hose(0) callingMinghuan Lian
There may be multiple PCIe controllers in a SoC. It is not correct that always calling pci_bus_to_hose(0) to get the first PCIe controller for the PCIe device connected other controllers. We just remove this calling because hose always point the correct PCIe controller. Signed-off-by: Minghuan Lian <Minghuan.Lian@nxp.com> Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-01-12dm: pci: Switch to DM API for PCI address mappingSimon Glass
We should use the new address mapping functions unless we are in compatibility mode. Disable the old functions by default. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-12dm: pci: Drop the old version of pci_find_class()Simon Glass
Move this function into the compatibility file so that it is not available by default. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-12dm: pci: Drop the old version of pci_find_device/s()Simon Glass
Move these functions into the compatibility file so that they are not available by default. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-11-23pci: fix address range check in __pci_hose_phys_to_bus()Marcel Ziswiler
The address range check may overflow if the memory region is located at the top of the 32-bit address space. This can e.g. be seen on TK1 if using the E1000 gigabit Ethernet driver where start and size are both 0x80000000 leading to the following messages: Apalis TK1 # tftpboot $loadaddr test_file Using e1000#0 device TFTP from server 192.168.10.1; our IP address is 192.168.10.2 Filename 'test_file'. Load address: 0x80408000 Loading: pci_hose_phys_to_bus: invalid physical address This patch fixes this by changing the order of the addition vs. subtraction in the range check just like already done in __pci_hose_bus_to_phys(). Reported-by: Ivan Mercier <ivan.mercier@nexvision.fr> Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-11-12pci: fix checking PCI_REGION_MEM in pci_hose_phys_to_bus()Cheng Gu
When converting between PCI bus and phys addresses, a two pass search was introduced with preference to non-PCI_REGION_SYS_MEMORY regions. See commit 2d43e873a29ca4959ba6a30fc7fb396d3fd0dccf. However, since PCI_REGION_MEM is defined as 0, the if statement was always asserted true: ((flags & PCI_REGION_MEM) == PCI_REGION_MEM) This patch uses PCI_REGION_TYPE bit to check if the region is PCI_REGION_MEM: ((flags & PCI_REGION_TYPE) == PCI_REGION_MEM) Signed-off-by: Cheng Gu <chenggu@marvell.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-07-28dm: pci: Support bridge device configuration correctlyBin Meng
Commit aec241d "dm: pci: Use the correct hose when configuring devices" was an attempt to fix pci bridge device configuration, but unfortunately that does not work 100%. In pciauto_config_devices(), the fix tried to call pciauto_config_device() with a ctlr_hose which is supposed to be the root controller hose, however when walking through a pci topology with 2 or more pci bridges this logic simply fails. The call chain is: pciauto_config_devices()->pciauto_config_device() ->dm_pci_hose_probe_bus(). Here the call to dm_pci_hose_probe_bus() does not make any sense as the given hose is not the bridge device's hose, instead it is either the root controller's hose (case#1: if it is the 2nd pci bridge), or the bridge's parent bridge's hose (case#2: if it is the 3rd pci bridge). In both cases the logic is wrong. For example, for failing case#1 if the bridge device to config has the same devfn as one of the devices under the root controller, the call to pci_bus_find_devfn() will return the udevice of that pci device under the root controller as the bus, but this is wrong as the udevice is not a bus which does not contain all the necessary bits associated with the udevice which causes further failures. To correctly support pci bridge device configuration, we should still call pciauto_config_device() with the pci bridge's hose directly. In order to access valid pci region information, we need to refer to the root controller simply by a call to pci_bus_to_hose(0) and get the region information there in the pciauto_prescan_setup_bridge(), pciauto_postscan_setup_bridge() and pciauto_config_device(). Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-07-14dm: pci: Use the correct hose when configuring devicesSimon Glass
Only the PCI controller has access to the PCI region information. Make sure to use the controller (rather than any attached bridges) when configuring devices. This corrects a failure to scan and configure devices when driver model is enabled for PCI. Also add a comment to explain the problem. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-06-04pci: Move pci_hose_phys_to_bus() to pci_common.cBin Meng
pci_hose_phys_to_bus() is needed by several drivers. Move it to pci_common.c to avoid a broken build when CONFIG_DM_PCI is on. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-16dm: pci: Move common PCI functions into their own fileSimon Glass
Driver model will share many functions with the existing PCI implementation. Move these into their own file to avoid duplication and confusion. Signed-off-by: Simon Glass <sjg@chromium.org>
