path: root/drivers/pci/Makefile
2019-06-20dm: pci: add Freescale PowerPC PCIe driverHou Zhiqiang
Add PCIe DM driver for Freescale PowerPC PCIe controllers. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-05-26Merge branch 'master' of git://git.denx.de/u-boot-shTom Rini
- Gen3 PCIe driver + enablement on Salvator-X platforms. - Gen3 recovery SPL used to reload ATF/OpTee/U-Boot instead of minimon. - SDHI HS400 fixes ported from latest BSP and datasheet.
2019-05-22pci: ls_pcie_g4: add device tree fixups for PCI Stream IDsHou Zhiqiang
Add the infrastructure for Layerscape SoCs PCIe Gen4 controller to update device tree nodes to convey SMMU stream IDs in the device tree. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-05-22pci: Add PCIe Gen4 controller driver for NXP Layerscape SoCsHou Zhiqiang
Add PCIe Gen4 driver for the NXP Layerscape SoCs. This PCIe controller is based on the Mobiveil IP, which is compatible with the PCI Express™ Base Specification, Revision 4.0. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Signed-off-by: Bao Xiaowei <Xiaowei.Bao@nxp.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-05-21pci: renesas: Add RCar Gen3 PCIe controller driverMarek Vasut
Add driver for the Renesas RCar PCIe controller present on Gen3 SoCs. The PCIe on Gen3 is used both to connect external PCIe peripherals. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-05-08pci: intel: Add Intel FPGA PCIe controller driverLey Foon Tan
Add PCIe driver for Intel FPGA PCIe IP. This driver operates the PCIe IP in rootport mode only, the EP mode is not supported. The driver is tested with the Intel e1000e NIC driver. Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
2018-03-30arm64: a37xx: pci: add support for aardvark pcie driverWilson Ding
This patch introduced the Aardvark PCIe driver based driver model. The PCIe driver is supposed to work in Root Complex mode. It only supports X1 lane width. Signed-off-by: Wilson Ding <dingwei@marvell.com> Reviewed-on: http://vgitil04.il.marvell.com:8080/38725 Reviewed-by: Victor Gu <xigu@marvell.com> Reviewed-by: Hua Jing <jinghua@marvell.com> Tested-by: Hua Jing <jinghua@marvell.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Ken Ma <make@marvell.com> Signed-off-by: Stefan Roese <sr@denx.de>
2018-01-27pci: rmobile: Add RCar Gen2 PCIe controller driverMarek Vasut
Add driver for the Renesas RCar PCIe controller present on Gen2 SoCs. The PCIe on Gen2 is used both to connect external PCIe peripherals as well as access the on-SoC USB EHCI controller. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
2018-01-10PCI: Drop CONFIG_TSI108_PCITuomas Tynkkynen
Last user of this option went away in 2015 in commit: d928664f41 ("powerpc: 74xx_7xx: remove 74xx_7xx cpu support") Signed-off-by: Tuomas Tynkkynen <tuomas@tuxera.com>
2017-10-06PCI: Add driver for a 'pci-host-ecam-generic' host controllerTuomas Tynkkynen
QEMU emulates such a device with '-machine virt,highmem=off' on ARM. The 'highmem=off' part is required for things to work as the PCI code in U-Boot doesn't seem to support 64-bit BARs. Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-01-25Drop CONFIG_WINBOND_83C553Simon Glass
This is not used in U-Boot. Drop this option and associated dead code. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-01-18pci: layerscape: move kernel DT fixup to a separate fileHou Zhiqiang
To make the layerscape pcie driver clear, move the kernel DT fixup code from pcie_layerscape.c to pcie_layerscape_fixup.c. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: York Sun <york.sun@nxp.com>
2016-12-05pci: mvebu: Add PCIe driver for Armada-8KShadi Ammouri
This patch adds a driver for the PCIe controller integrated in the Marvell Armada-8K SoC. This controller is based on the DesignWare IP core. The original version was written by Shadi and Yehuda. I ported this driver to the latest mainline U-Boot version with DM support. Tested on the Marvell DB-88F8040 Armada-8K eval board. Signed-off-by: Shadi Ammouri <shadi@marvell.com> Signed-off-by: Yehuda Yitschak <yehuday@marvell.com> Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Cc: Nadav Haklai <nadavh@marvell.com> Cc: Neta Zur Hershkovits <neta@marvell.com> Cc: Kostya Porotchkin <kostap@marvell.com> Cc: Omri Itach <omrii@marvell.com> Cc: Igal Liberman <igall@marvell.com> Cc: Haim Boot <hayim@marvell.com> Cc: Hanna Hawa <hannah@marvell.com>
2016-09-21pci: xilinx: Add a driver for Xilinx AXI to PCIe bridgePaul Burton
This patch adds a driver for the Xilinx AXI bridge for PCI express, an IP block which can be used on some generations of Xilinx FPGAs. This is mostly a case of implementing PCIe ECAM specification, but with some quirks about what devices are valid to access. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-01-12dm: pci: video: Convert video and pci_rom to use DM PCI APISimon Glass
Adjust these files to use the driver-model PCI API instead of the legacy functions. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-12dm: pci: Use driver model PCI API in auto-configSimon Glass
At present we are using legacy functions even in the auto-configuration code used by driver model. Add a new pci_auto.c version which uses the correct API. Create a new pci_internal.h header to hold functions that are used within the PCI subsystem, but are not exported to other drivers. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2015-12-01dm: pci: Disable PCI compatibility functions by defaultSimon Glass
We eventually need to drop the compatibility functions for driver model. As a first step, create a configuration option to enable them and hide them when the option is disabled. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-12-01dm: pci: Move common auto-config functions to a common fileSimon Glass
Some functions will be used by driver model and legacy PCI code. To avoid duplication, put these in a separate, shared file. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-12-01dm: pci: Rename pci_auto.c to pci_auto_old.cSimon Glass
This file should not be used with driver model as it has lots of legacy/ compatibility functions. Rename it to make this clear. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-17pci: mvebu: Add PCIe driverAnton Schubert
This adds a PCI driver for the controllers found on Marvell MVEBU SoCs. Besides the driver, this patch also removes the statically defined PCI MBUS windows. As they are not needed anymore, since this PCIe driver now creates the windows dynamically. Tested on Armada XP db-mv784mp-gp eval board using an Intel E1000 PCIe card in all 3 PCIe slots. And on the Armada 38x db-88f6820-gp eval board using this Intel E1000 PCIe card in the PCIe 0 slot. This port was done in cooperation with Anton Schubert. Signed-off-by: Anton Schubert <anton.schubert@gmx.de> Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Dirk Eibach <eibach@gdsys.de>
2015-04-18dm: x86: pci: Add a PCI driver for driver modelSimon Glass
Add a simple x86 PCI driver which uses standard functions provided by the architecture. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-16dm: sandbox: pci: Add a PCI emulation uclassSimon Glass
Since sandbox does not have real devices (unless it borrows those from the host) it must use emulations. Provide a uclass which permits PCI operations to be passed through to an emulation device. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-16dm: sandbox: Add a simple PCI driverSimon Glass
Add a driver which can access emulations of devices and make them available in sandbox. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-16dm: pci: Add a uclass for PCISimon Glass
Add a uclass for PCI controllers and a generic one for PCI devices. Adjust the 'pci' command and the existing PCI support to work with this new uclass. Keep most of the compatibility code in a separate file so that it can be removed one day. TODO: Add more header file comments to the new parts of pci.h Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-16dm: pci: Move common PCI functions into their own fileSimon Glass
Driver model will share many functions with the existing PCI implementation. Move these into their own file to avoid duplication and confusion. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-12-18pci: tegra: Add Tegra PCIe driverThierry Reding
Add support for the PCIe controller found on some generations of Tegra. Tegra20 has 2 root ports with a total of 4 lanes, Tegra30 has 3 root ports with a total of 6 lanes and Tegra124 has 2 root ports with a total of 5 lanes. This is based on the Linux kernel driver, originally submitted upstream by Mike Rapoport. Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-12-11arm: ls102xa: Update PCIe dts node statusMinghuan Lian
The patch changes PCIe dts node status to 'disabled' if the corresponding controller is disabled according to serdes protocol. Signed-off-by: Minghuan Lian <Minghuan.Lian@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-11-25pci: Add general support for execution of video ROMsSimon Glass
Some platforms don't have native code for dealing with their video hardware. In some cases they use a binary blob to set it up and perform required actions like setting the video mode. This approach is a hangover from the old PC days where a ROM was provided and executed during startup. Even now, these ROMs are supplied as a way to set up video. It avoids the code for every video chip needing to be provided in the boot loader. But it makes the video much less flexible - e.g. it is not possible to do anything else while the video init is happening (including waiting hundreds of milliseconds for display panels to start up). In any case, to deal with this sad state of affairs, provide an API for execution of x86 video ROMs, either natively or through emulation. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-02-19Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-02-06ARM: PCI: Remove the IXP PCI driverMarek Vasut
The driver is no longer used, remove it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Michael Schwingen <michael@schwingen.org> Cc: Tom Rini <trini@ti.com>
2014-01-26ARM: mx6: Add PCI express driverMarek Vasut
Add PCIe driver for the Freescale i.MX6 SoC . This driver operates the PCIe block in RC mode only, the EP mode is NOT supported. The driver is tested with the Intel e1000 NIC driver. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Eric Nelson <eric.nelson@boundarydevices.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Stefano Babic <sbabic@denx.de>
2013-11-09malta: support for coreFPGA6 boardsPaul Burton
This patch adds support for running on Malta boards using coreFPGA6 core cards, including support for the msc01 system controller used with them. The system controller is detected at runtime allowing one U-boot binary to run on a Malta with either. Due to the PCI I/O base differing between Maltas using gt64120 & msc01 system controllers, the UART setup is modified slightly. A second UART is added so that there is one pointing at the correct address for each system controller. The Malta board then defines its own default_serial_console function to select the correct one at runtime. The incorrect UART will simply not function. Tested on: - A coreFPGA6 Malta running interAptiv and proAptiv bitstreams, both with and without an L2 cache. - QEMU. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2013-10-31drivers: convert makefiles to Kbuild styleMasahiro Yamada
2013-07-24MIPS: qemu-malta: add PCI supportGabor Juhos
Qemu emulates the Galileo GT64120 System Controller which provides a CPU bus to PCI bus bridge. The patch adds driver for this bridge and enables PCI support for the emulated Malta board. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2013-06-07pci: introduce CONFIG_PCI_INDIRECT_BRIDGE optionGabor Juhos
The pci_indirect.c file is always compiled when CONFIG_PCI is defined although the indirect PCI bridge support is not needed by every board. Introduce a new CONFIG_PCI_INDIRECT_BRIDGE config option and only compile indirect PCI bridge support if this options is enabled. Also add the new option into the configuration files of the boards which needs that. Compile tested for powerpc, x86, arm and nds32. MAKEALL results: powerpc: --------------------- SUMMARY ---------------------------- Boards compiled: 641 Boards with warnings but no errors: 2 ( ELPPC MPC8323ERDB ) ---------------------------------------------------------- Note: the warnings for ELPPC and MPC8323ERDB are present even without the actual patch. x86: --------------------- SUMMARY ---------------------------- Boards compiled: 1 ---------------------------------------------------------- arm: --------------------- SUMMARY ---------------------------- Boards compiled: 311 ---------------------------------------------------------- nds32: --------------------- SUMMARY ---------------------------- Boards compiled: 3 ---------------------------------------------------------- Cc: Tom Rini <trini@ti.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
2011-12-05pci_ftpci100: Implementation FTPCI100 PCI driverGavin Guo
FTPCI100 is a SoC PCI componenet of Faraday company. Which is usually built into SoC chips for providing embedded PCI functions. Signed-off-by: Gavin Guo <gavinguo@andestech.com> Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2009-01-31ixp: move pci drivers to drivers/pciJean-Christophe PLAGNIOL-VILLARD
2008-08-13drivers/pci: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-03-28sh: Add support PCI host driver for SH7751/SH7751RNobuhiro Iwamatsu
2008-03-28sh: Move SuperH PCI driver from cpu/sh4 to drivers/pciNobuhiro Iwamatsu
2007-11-24drivers/pci : move pci drivers to drivers/pciJean-Christophe PLAGNIOL-VILLARD
