path: root/drivers/pch
2020-05-18common: Drop log.h from common headerSimon Glass
Move this header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-12-15x86: Allow removal of standard PCH driversSimon Glass
These drivers are not needed on all platforms. While they are small, it is useful in TPL to drop then. Add Kconfig control to allow this. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-10-08x86: Allow the PCH and LPC uclasses to work with of-platdataSimon Glass
At present these uclasses assumes that they are used with a device tree. Update them to support of-platdata as well. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-02-20pch: Add ioctl supportSimon Glass
At present the PCH has 4 operations and these are reasonably widely used in the drivers. But sometimes we want to add rarely used operations, and each of these currently adds to the size of the PCH operations table. Add an ioctl() method which can be easily expanded without any more impact on the operations table. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-02-20sandbox: pch: Add a test for the PCH uclassSimon Glass
This uclass currently has no tests. Add a sandbox driver and some simple tests to provide basic coverage. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> [bmeng: Use "sandbox,pch" for the compatible string, for consistency] Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2019-02-20x86: sandbox: pch: Add a CONFIG option for PCHSimon Glass
At present this uclass is selected only on x86. In order to add a test for it, it must also support sandbox. Create a new CONFIG_PCH option and enable it on x86 and sandbox. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2018-04-27Remove unnecessary instances of DECLARE_GLOBAL_DATA_PTRTom Rini
We have a large number of places where while we historically referenced gd in the code we no longer do, as well as cases where the code added that line "just in case" during development and never dropped it. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-07-27dm: Use dm_scan_fdt_dev() directly where possibleSimon Glass
Quite a few places have a bind() method which just calls dm_scan_fdt_dev(). We may as well call dm_scan_fdt_dev() directly. Update the code to do this. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-07-27dm: Convert users from dm_scan_fdt_node() to dm_scan_fdt_dev()Simon Glass
This new function is more convenient for callers, and handles pre-relocation situations automatically. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-02-05x86: pch9: Implement get_io_base opBin Meng
IO_BASE is only seen on PCH9 device, implement the get_io_base op. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2016-02-05dm: pch: Add get_io_base opBin Meng
On some newer chipset (eg: BayTrail), there is an IO base address register on the PCH device which configures the base address of a memory-mapped I/O controller. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2016-02-05x86: pch: Implement get_gpio_base opBin Meng
Implement get_gpio_base op for bd82x6x, pch7 and pch9 drivers. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2016-02-05dm: pch: Add get_gpio_base opBin Meng
x86 GPIO registers are accessed via I/O port whose base address is configured in a PCI configuration register on the PCH device. Add an op get_gpio_base to get the GPIO base address from PCH. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2016-02-05dm: pch: Rename get_sbase op to get_spi_baseBin Meng
Spell out 'sbase' to 'spi_base' so that it looks clearer. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2016-02-05dm: pch: Remove pch_get_version opBin Meng
pch_get_version op was only used by the ich spi controller driver, and does not really provide a good identification of pch controller so far, since we see plenty of Intel PCH chipsets and one differs from another a lot, which is not simply either a PCHV_7 or PCHV_9. Now that ich spi controller driver was updated to not get such info from pch, the pch_get_version op is useless now. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2016-01-24dm: x86: Add a driver for Intel PCH9Simon Glass
At some point we may need to distinguish between different types of PCHs, but for existing supported platforms we only need to worry about version 7 and version 9 bridges. Add a driver for the PCH9. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-24dm: x86: Add a driver for Intel PCH7Simon Glass
At some point we may need to distinguish between different types of PCHs, but for existing supported platforms we only need to worry about version 7 and version 9 bridges. Add a driver for the PCH7. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-24dm: Expand the uclass for Platform Controller Hubs (PCH)Simon Glass
A Platform Controller Hub is an Intel concept - it is like the peripherals on an SoC and is often in a separate chip from the CPU. The chip is typically found on the first PCI bus and integrates multiple devices. We have a very simple uclass to support PCHs. Add a few operations, such as setting up the devices on the PCH and finding the SPI controller base address. Also move it into drivers/pch/ since we will be adding a few PCH drivers. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
