2007-11-25 | drivers/net : move net drivers to drivers/net | Jean-Christophe PLAGNIOL-VILLARD | |
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> | |||
2007-07-09 | drivers/[n-z]*: Remove obsolete references to CONFIG_COMMANDS | Jon Loeliger | |
Signed-off-by: Jon Loeliger <jdl@freescale.com> | |||
2007-07-04 | drivers/: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*). | Jon Loeliger | |
This is a compatibility step that allows both the older form and the new form to co-exist for a while until the older can be removed entirely. All transformations are of the form: Before: #if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT) After: #if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT) || defined(CONFIG_CMD_AUTOSCRIPT) Signed-off-by: Jon Loeliger <jdl@freescale.com> | |||
2004-02-23 | * Patch by Laurent Mohin, 10 Feb 2004: | wdenk | |
Fix buffer overflow in common/usb.c * Patch by Tolunay Orkun, 10 Feb 2004: Add support for Cogent CSB272 board * Code cleanup | |||
2004-02-23 | * Patch by Thomas Elste, 10 Feb 2004: | wdenk | |
Add support for NET+50 CPU and ModNET50 board * Patch by Sam Song, 10 Feb 2004: Fix typos in cfi_flash.c * Patch by Leon Kukovec, 10 Feb 2004 Fixed long dir entry slot id calculation in get_vfatname * Patch by Robin Gilks, 10 Feb 2004: add "itest" command (operators: -eq, -ne, -lt, -gt, -le, -ge, ==, !=, <>, <, >, <=, >=) |
