Fix:
at91_emac.c: In function 'at91emac_phy_init':
at91_emac.c:244:20: warning: variable 'duplex' set but not used
[-Wunused-but-set-variable]
at91_emac.c:244:13: warning: variable 'speed' set but not used
Use new debug_cond() to fix these warnings. In the result, anumber of
inconsistent printf() formats are detected:
at91_emac.c: In function 'at91emac_read':
at91_emac.c:147:2: warning: format '%x' expects argument of type
'unsigned int', but argument 2 has type 'struct at91_emac_t *'
[-Wformat]
at91_emac.c: In function 'at91emac_write':
at91_emac.c:157:2: warning: format '%x' expects argument of type
[-Wformat]
'unsigned int', but argument 4 has type 'short unsigned int *'
[-Wformat]
at91_emac.c: In function 'at91emac_recv':
at91_emac.c:451:3: warning: format '%d' expects argument of type
'int', but argument 2 has type 'long unsigned int' [-Wformat]
at91_emac.c:451:3: warning: format '%x' expects argument of type
'unsigned int', but argument 4 has type 'long unsigned int' [-Wformat]
Fix these, too.
Cc: Jens Scharsig <js_at_ng@scharsoft.de>
Cc: Andreas Bießmann <andreas.devel@gmail.com>
Cc: Reinhard Meyer <u-boot@emk-elektronik.de>
Fix:
ne2000_base.c: In function 'dp83902a_send':
ne2000_base.c:282:7: warning: variable 'tmp' set but not used
ne2000_base.c: In function 'dp83902a_RxEvent':
ne2000_base.c:376:5: warning: variable 'rsr' set but not used
ne2000_base.c: In function 'dp83902a_TxEvent':
ne2000_base.c:513:5: warning: variable 'tsr' set but not used
ne2000_base.c: In function 'dp83902a_ClearCounters':
ne2000_base.c:550:17: warning: variable 'cnt3' set but not used
ne2000_base.c:550:11: warning: variable 'cnt2' set but not used
ne2000_base.c:550:5: warning: variable 'cnt1' set but not used
This fixes the build of the two sh boards shmin and r7780mp and qemu-mips
which currently fail to build due to dropped pre-CONFIG_NET_MULTI code.
This v2 patch minimizes the number of lines in the diff for easy review
and to eliminate any possible accidential changes resulting from moving
lines of code in the file. This also makes the register function very easy.
Any cleanups and improvements are intentionally deferred to follow-up patches
to keep this patch as simple and as easy to review as possible.
A new driver register function, ne2k_register() calls the existing
one-time setup part of the old init function and calls eth_register().
Changes to shmin, r7780mp and qemu-mips:
- Call the new ne2k_register() from board_eth_init() of the boards.
- Tested using qemu-mips board,
- Tested the two renesas / sh boards r7780mp and shmin to compile again,
and should work.
checkpatch-clean when "--ignore VOLATILE" is added to .checkpatch.conf,
and no warnings introduced in none of the three boards using this driver.
Signed-off-by: Bernhard Kaindl <bernhard.kaindl@gmx.net>
Fix:
inca-ip_sw.c: In function 'inca_switch_init':
inca-ip_sw.c:210:6: warning: variable 'v' set but not used
Fix the condition for number of phys in
davinci_eth_phy_detect() function.
CONFIG_SYS_DAVINCI_EMAC_PHY_COUNT indicates number of
phys. From this commit id dc02badab480563b0bf9d3908046ea9d6b22ae63
davinci emac initilazed one less than the number of phy count.
Signed-off-by: Prabhakar Lad <prabhakar.csengg@gmail.com>
Acked-by: Heiko Schocher <hs@denx.de>
For some reason code setting the speed based on the PHY feedback causes
troubles on AM3517 so hardcode 100Mbps for now.
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
DaVinci EMAC is present on TI AM35xx SoCs (ARMv7) which run with D-Cache
enabled by default. So we have to take care and flush/invalidate the
cache before/after the DMA operations.
Please note that the receive buffer alignment to 32 byte boundary comes
from the old driver version I don't know if it is really needed or
alignment to cache line size is enough.
On AM35xx CPPI RAM had different addresses when accessed from the CPU
and from the EMAC. We need to account this to deal with the buffer
descriptors correctly.
DaVinci EMAC is found not only on DaVinci SoCs but on some OMAP3 SoCs
also. This patch moves common defines from arch-davinci/emac_defs.h to
drivers/net/davinci_emac.h
DaVinci specific PHY drivers hacked to include the new header. We might
want to switch to phylib in future.
This patch fix compilation warnings for Armada100 FEC driver
Ref:
warning: dereferencing type-punned pointer will break
strict-aliasing rules
Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com>
Acked-by: Anatolij Gustschin <agust@denx.de>
This adds support for the SMSC LAN87xx PHYs.
Following PHYs can be used by set CONFIG_PHY_SMSC to config.
- SMSC LAN8700
- SMSC LAN8710/LAN8720
A setup of PHY was copied from linux kenrel.
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
Fixed white space errors; modified commit message a bit.
Fix:
mvgbe.c: In function 'mvgbe_send':
mvgbe.c:555:2: warning: dereferencing type-punned pointer will
break strict-aliasing rules [-Wstrict-aliasing]
mvgbe.c: In function 'mvgbe_recv':
mvgbe.c:640:2: warning: dereferencing type-punned pointer will
Cc: Prafulla Wadaskar <prafulla@marvell.com>
Acked-By: Prafulla Wadaskar <prafulla@marvell.com>
The original m88e1111s_config() does not do the SGMII mode
initialization and is buggy. Rewrite the function according to
3.0.6 kernel function m88e1111_config_init() in drivers/net/phy/marvell.c
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
Acked-by: Andy Fleming <afleming@freescale.com>
Cc: Kumar Gala <galak@kernel.crashing.org>
The sh_eth driver had an own mii functions. However the function
didn't support the gigabit PHY. The U-Boot has the general phy driver
and miiphybb driver, and they already support it.
So this patch removes the own functions and uses the phy driver.
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Several macros are used to identify and locate the microcode binary image
that U-boot needs to upload to the QE or Fman. Both the QE and the Fman
use the QE Firmware binary format to package their respective microcode data,
which is why the same macros are used for both. A given SOC will only have
a QE or an Fman, so this is safe.
Unfortunately, the current macro definition and usage has inconsistencies.
For example, CONFIG_SYS_FMAN_FW_ADDR was used to define the address of Fman
firmware in NOR flash, but CONFIG_SYS_QE_FW_IN_NAND contains the address
of NAND. There's no way to know by looking at a variable how it's supposed
to be used.
In the future, the code which uploads QE firmware and Fman firmware will
be merged.
* 'hs@denx.de' of git://git.denx.de/u-boot-staging:
drivers/net/dnet.c: Fix GCC 4.6 warnings
board/xaeniax/flash.c: Fix GCC 4.6 warnings
net/bootp.c: Fix GCC 4.6 warning
common/cmd_bootm.c: Fix GCC 4.6 warnings
board/mx1ads/mx1ads.c: Fix GCC 4.6 warning
board/mx1ads/syncflash.c: Fix GCC 4.6 warnings
board/lubbock/flash.c: Fix GCC 4.6 warnings
drivers/net/cs8900.c: Fix GCC 4.6 warning
arch/arm/cpu/arm926ejs/omap/cpuinfo.c: Fix GCC 4.6 warnings
drivers/net/lan91c96.c: Fix GCC 4.6 warning
board/ronetix/pm9263/pm9263.c: Fix GCC 4.6 warning
drivers/mtd/onenand/samsung.c: Fix GCC 4.6 warning
drivers/usb/musb/musb_hcd.c: Fix GCC 4.6 warning
Fix:
dnet.c: In function 'dnet_send':
dnet.c:136:9: warning: variable 'len' set but not used
dnet.c: In function 'dnet_set_hwaddr':
dnet.c:209:2: warning: dereferencing type-punned pointer will
Fix:
cs8900.c: In function 'get_reg_init_bus':
cs8900.c:69:14: warning: variable 'c' set but not used
Fix:
lan91c96.c: In function 'dump_memory_info':
lan91c96.c:157:7: warning: variable 'mem_info' set but not used
lan91c96.c: In function 'smc_send_packet':
lan91c96.c:320:16: warning: variable 'ioaddr' set but not used
device is already in *normal* (D0) mode => it doesn't need to be wake-up.
With this patch, we only wake-up (writing on TEST_BYTE register) if PM_MODE
bits of PM_CTRL register is in sleep (D1/D2) mode.
Signed-off-by: Bertrand Cachet <bertrand.cachet@heig-vd.ch>
No one uses this driver, and it isn't converted to the NET_MULTI
framework (which we dropped recently), so drop this driver too.
Fix the following build warning in drivers/net/e1000.c
e1000.c: In function 'e1000_reset_hw':
e1000.c:1373:11: warning: variable 'icr' set but not used [-Wunused-but-set-variable]
e1000.c: In function 'e1000_phy_init_script':
e1000.c:4395:11: warning: variable 'ret_val' set but not used [-Wunused-but-set-variable]
Cc: Kyle Moffett <Kyle.D.Moffett@boeing.com>
Some of the EEPROM Word Offset macros, and a few others, are defined
twice in e1000.h.
Fix:
enc28j60.c: In function 'enc_receive':
enc28j60.c:435:5: warning: variable 'eir_reg' set but not used
enc28j60.c: In function 'enc_poll':
enc28j60.c:503:5: warning: variable 'estat_reg' set but not used
Fix:
at91_emac.c: In function 'at91emac_write_hwaddr':
at91_emac.c:477:15: warning: variable 'dev' set but not used
Fix:
4xx_enet.c: In function 'ppc_4xx_eth_init':
4xx_enet.c:875:6: warning: variable 'ethgroup' set but not used [-Wunused-but-set-variable]
I used "__maybe_unused" here intentionally, since all other
alternatives to fix this compilation warning would result in more
ifdef's.
* 'master' of git://git.denx.de/u-boot-arm:
arm, davinci: add DAVINCI_MMC_CLKID
arm, davinci_emac: fix driver bug if more then 3 PHYs are detected
arm, davinci: da850/dm365 lowlevel cleanup
omap5: Add omap5_evm board build support.
omap4/5: Add support for booting with CH.
omap5: emif: Add emif/ddr configurations required for omap5 evm
omap5: clocks: Add clocks support for omap5 platform.
omap5: Add minimal support for omap5430.
omap: Checkpatch fixes
omap4: make omap4 code common for future reuse
GCC4.6: Squash warnings in onenand_base.c
GCC4.6: Fix common/usb.c on xscale
OneNAND: Add simple OneNAND SPL
PXA: vpac270: Enable the new generic MMC driver
PXA: Cleanup serial_pxa
PXA: Drop csb226 and innokom boards (unmaintained)
m28evk: Fix comment about the number of RAM banks
mx31: Fix checkpatch warnings in generic.c
mx31: Use proper IO accessor for GPR register
mx31: Remove duplicate definition for GPR register
qong: Use generic function for configuring GPR register
M28EVK: Enable USB HOST support
iMX28: Add USB HOST driver
iMX28: Add USB and USB PHY register definitions
M28: Add memory detection into SPL
iMX28: Fix ARM vector handling
M28: Add doc/README.m28 documentation
M28: Add MMC SPL
iMX28: Add support for DENX M28EVK board
iMX28: Add u-boot.sb target to Makefile
iMX28: Add image header generator tool
iMX28: Add driver for internal RTC
iMX28: Add GPMI NAND driver
iMX28: Add APBH DMA driver
iMX28: Add SPI driver
iMX28: Add GPIO control
iMX28: Add I2C bus driver
iMX28: Add PINMUX control
FEC: Add support for iMX28 quirks
iMX28: Add SSP MMC driver
iMX28: Initial support for iMX28 CPU
MX25: zmx25: GCC4.6 fix build warnings
da850: add new config file for AM18xx
BeagleBoard: config: Switch to ttyO2
OMAP3: Change omap3_evm maintainer
devkit8000: Fix NAND SPL on boards with 256MB NAND
integrator: enable Vpp and disable flash protection
integrator: add system controller header
integrator: make flash writeable on boot
integrator: use io-accessors for board init
integrator: move text offset to config
integrator: pass configs for core modules
ARM: remove superfluous setting of arch_number in board specific code.
SPL: Allow ARM926EJS to avoid compiling in the CPU support code
integrator: do not test first part of the memory
arm: a320: fix broken timer
ARM: define CONFIG_MACH_TYPE for all ronetix boards
dm646x: pass board revision info to kernel
dm646x: add new configuration for dm6467T
arm, davinci: Fix setting of the SDRAM configuration register
arm, davinci: Remove the duplication of LPSC functions
arm, davinci: Rename AM1808 lowlevel functions to DA850
da8xxevm: fix build error
ARM: re-add MACH_TYPE_XXXXXX for VCMA9 board and add CONFIG_MACH_TYPE
since commits:
davinci: emac: add support for more than 1 PHYs
062fe7d332c28ede25626f448681e43d76bb312e
davinci: remove obsolete macro CONFIG_EMAC_MDIO_PHY_NUM
fb1d6332b5430b90a8fa8ebab709f33a60e9f816
I get following warning on the enbw_cmc board:
Err: serial
Net: 5 ETH PHY detected
miiphy_register: non unique device name 'KSZ8873 @ 0x01'
DaVinci-EMAC
Hit any key to stop autoboot: 0
Also I see some debug printfs:
=> run load
+ emac_close
+ emac_ch_teardown
- emac_ch_teardown
+ emac_ch_teardown
- emac_ch_teardown
- emac_close
+ emac_open
- emac_open
Using DaVinci-EMAC device
reason is 062fe7d332c28ede25626f448681e43d76bb312e new define MAX_PHY.
This is set to 3! I get on this board 5 active phys, so
this leads in wrong memory writes ...
so I changed:
- define CONFIG_SYS_DAVINCI_EMAC_PHY_COUNT to set
the MAX_PHY value, add a description in README
for the new CONFIG_SYS option.
- print an error message if more then MAX_PHYs are
detected.
- fill the active_phy_addr array in a for loop with
0xff
- changed printf() in debug_emac()
Cc: Sandeep Paulraj <s-paulraj@ti.com>
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Cc: Manjunath Hadli <manjunath.hadli@ti.com>
Cc: Prabhakar Lad <prabhakar.csengg@gmail.com>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Tom Rini <tom.rini@gmail.com>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
Fix:
fm.c: In function 'fm_init_common':
fm.c:398:6: warning: variable 'n' set but not used [-Wunused-but-set-variable]
Cc: Ben Warren <biggerbadderben@gmail.com>
Cc: Detlev Zundel <dzu@denx.de>
Erratum NMG_eTSEC129 (eTSEC86 in MPC8548 document) applies to some early
verion silicons. This workaround detects if the eTSEC Rx logic is properly
initialized, and reinitialize the eTSEC Rx logic.
Signed-off-by: Gong Chen <g.chen@freescale.com>
Signed-off-by: Zhao Chenhui <chenhui.zhao@freescale.com>
Arm: re-introduce the MACH_TYPE_XXXXXX for EB_CPUX9K2 board
arm: jadecpu: Readd MACH_TYPE_JADECPU
at91: defined mach-types for otc570 board in board config file
at91: defined mach-types for meesc board in board config file
mx31pdk: Enable D and I caches
ehci-mxc: remove incorrect comment
README: Fix supported i.MX SoC list for CONFIG_MXC_SPI
mx53: Turn off child clocks before reconfigure perclk_root
qong: enable support for compressed images
imx: imx31_phycore.h: fix checkpatch warnings
vision2: Remove unused get_board_rev function
mx53smd: Remove unused get_board_rev function
mx53ard: Remove unused get_board_rev function
mx53evk: Remove unused get_board_rev function
mx53evk: Add RTC support
mx53loco: Remove unused get_board_rev function
mx53evk: Remove unneeded '1' from mx53evk.h
OMAP3: mvblx: Initial support for mvBlueLYNX-X
ARM: dig297: Define MACH_TYPE_OMAP3_CPS and CONFIG_MACH_TYPE
omap3: mem: Move comments next to definitions
omap3: mem: Clean-up whitespaces
omap3: mem: Define and use common macros
Davinci: ea20: added PREBOOT to configuration
Davinci: ea20: added I2C support
Davinci: ea20: added video support
VIDEO: davinci: add framebuffer to da8xx
ARM: Davinci: added missing registers to hardware.h
Davinci: ea20: add gpios for LCD backlight control
Davinci: ea20: add gpio for keeping power on in board_late_init
Davinci: ea20: Add default U-Boot environment
Davinci: ea20: Add early init to get early output from console
Davinci: ea20: Add NAND support
Davinci: ea20: set GPIOs to hold MII-Phy in reset and set UART0-Switch for console
Davinci: ea20: set console on UART0
arm, davinci: add cam_enc_4xx support
arm926ejs, davinci: add missing spi defines for dm365
arm926ejs, davinci: add cpuinfo for dm365
arm, davinci: add lowlevel function for dm365 soc
arm, davinci: add header files for dm365
spl, nand: add 4bit HW ecc oob first nand_read_page function
arm, davinci: add support for new spl framework
spl: add option for adding post memory test to the SPL framework
net, davinci_emac: make clock divider in MDIO control register configurable
arm, usb, davinci: make USBPHY_CTL register configurable
usb, davinci: add enable_vbus() weak function
omap3evm: fix errors caused by multiple definitions
omap3evm: Add (quick) configuration for NAND only
omap3evm: Add (quick) configuration for MMC/SD only
omap3evm: move common config options to new file
omap3evm: Prepare to split configuration
omap3evm: Reorder related config options
omap/spl: actually enable the console
davinci_emac: compilation fix, phy is array now
omap3evm: Set environment variable 'ethaddr'
arm, arm926: fix missing symbols in NAND_SPL mode
arm, davinci: Add function lpsc_syncreset()
arm, davinci: replace CONFIG_PRELOADER with CONFIG_SPL_BUILD
arm/km: portl2 environment address update to P1B
arm/km: adapt bootcounter evaluation
arm/km: enable jffs2 cmds
arm/km: trigger reconfiguration for the Xilinx FPGA
arm/km: add boardid and hwkey to kernel command line
ARM: Reintroduce MACH_TYPE_KM_KIRKWOOD for keymile ARM boards
netspace_v2: enable I2C EEPROM support
netspace_v2: fix SDRAM configuration
armada100: define CONFIG_SYS_CACHELINE_SIZE
pantheon: define CONFIG_SYS_CACHELINE_SIZE
kirkwood: define CONFIG_SYS_CACHELINE_SIZE
kirkwood: drop empty asm-offsets.s file
arm/km/mgcoge3un: enhance "waitforne" feature
arm/km: add variable waitforne to mgcoge3un
gplugD: Fix for error:MACH_TYPE_SHEEVAD undeclared
ARM: dreamplug: fix compilation
ARM: DockStar: fix compilation
ARM: netspace_v2: fix warnings
am335x: Drop board_sysinfo struct
am335x: Temporarily add MACH_TYPE define
misc:pmic:samsung Enable PMIC driver at C210 Universal target
dcache:s5p CONFIG_SYS_CACHELINE_SIZE added for s5p UNIVERSAL C210 target
dcache:s5p CONFIG_SYS_CACHELINE_SIZE added for s5p GONI target
smdkv310: use macro for mmc data read function address
smdkv310: use spl framework for mmc spl
SMDKV310: use get_ram_size() to validate dram size
SMDKV310: Initialize board id using CONFIG_MACH_TYPE
ORIGEN : use absolute paths and fix tool naming
ORIGEN : enable device tree support
MX25: tx25: Fix building due to missing MACH_TYPE
mx31: Add board support for HALE TT-01
mx31: add ESD control registers
mx31: define pins and init for UART2 and CSPI3
MX35: add support for flea3 board
MX51: vision2: add MACH_TYPE in config file
vision2: Remove unused header file
mx51evk: Remove unused get_board_rev function
mx51evk: Remove unneeded '1' from mx51evk.h
I2C: Fix mxc_i2c.c problem on imx31_phycore
mx35pdk: Add RTC support
mx51evk: Use GPIO API for configuring the IOMUX
mx51evk: Add RTC support
rtc: Make mc13783-rtc driver generic
qong: remove unneeded IOMUX settings
qong: Use mx31_set_gpr to setup USBH2 pins
mx31: Introduce mx31_set_gpr function
mx31pdk: Add MC13783 PMIC support
qong: remove unneeded "1" from qong.h
misc: pmic: fix regression in pmic_fsl.c (SPI)
mx5 configs: CONFIG_PRIME should really be CONFIG_ETHPRIME
MX35: Drop unnecessary prototypes from imx-regs.h
I2C: added I2C-2 and I2C-3 to MX35
MX35: factorize common assembly code
MX35: add reset cause as provided by other i.MX
MX35: add pins definition for UART3
MX35: added ESDC structure to imx-regs
Fix:
rtl8139.c: In function 'rtl8139_probe':
rtl8139.c:256:15: warning: variable 'fullduplex' set but not used
rtl8139.c:256:6: warning: variable 'speed10' set but not used
rtl8139.c: In function 'rtl_transmit':
rtl8139.c:419:16: warning: variable 'txstatus' set but not used
Change code to use new debug macros; also fix the new errors and
warnigns popping up now, like "error: 'to' undeclared" and some
"warning: format '%X' expects argument of type 'unsigned int', but
argument X has type 'long unsigned int'"
Fix:
rtl8169.c: In function 'rtl_init':
rtl8169.c:742:13: warning: variable 'printed_version' set but not used
Fix:
pcnet.c: In function 'pcnet_probe':
pcnet.c:247:8: warning: variable 'chipname' set but not used
Cc: Wolfgang Grandegger <wg@denx.de>
Define CONFIG_SYS_EMAC_TI_CLKDIV for setting the clkdiv value
in the MDIO control register.
cc: Sandeep Paulraj <s-paulraj@ti.com>
cc: Wolfgang Denk <wd@denx.de>
Fix compilation issues introduced by recent multiply PHY patch.
Fix build problem:
mvgbe.c: In function 'mvgbe_initialize':
mvgbe.c:735: warning: implicit declaration of function 'get_random_hex'
dockstar.c: In function 'board_early_init_f':
dockstar.c:43: warning: implicit declaration of function 'kw_config_gpio'
dockstar.c: In function 'board_init':
dockstar.c:113: warning: implicit declaration of function 'kw_sdram_bar'
dockstar.c: In function 'set_leds':
dockstar.c:161: warning: implicit declaration of function 'readl'
dockstar.c:161: error: dereferencing pointer to incomplete type
dockstar.c:162: warning: implicit declaration of function 'writel'
dockstar.c:162: error: dereferencing pointer to incomplete type
dockstar.c:163: error: dereferencing pointer to incomplete type
dockstar.c:164: error: dereferencing pointer to incomplete type
make[1]: *** [dockstar.o] Error 1
make: *** [board/Seagate/dockstar/libdockstar.o] Error 2
Reported-by: Roland Kletzing <devzero@web.de>
Fix:
4xx_enet.c: In function 'enet_rcv':
4xx_enet.c:1772:21: warning: variable 'ef_ptr' set but not used
Cc: Stefan Roese <sr@denx.de>
Fix:
eepro100.c: In function 'read_hw_addr':
eepro100.c:926:6: warning: variable 'eeprom' set but not used
Fix:
ns8382x.c: In function 'ns8382x_check_duplex':
ns8382x.c:704:6: warning: variable 'hun' set but not used
To fix this, we get rid of the NS8382X_DEBUG code and use standard
debug() instead.
This will now trigger a so far undetected warning:
ns8382x.c:780:2: warning: format '%X' expects argument of type
'unsigned int', but argument 2 has type 'long unsigned int' [-Wformat]
Fix that, too.
Commit 114d7fc0 "e1000: Rewrite EEPROM checksum error to give more
information" failed to initialize the checksum variable which should
result in random results. Fix that.
Commit 2326a94d caused a ton of "unused variable 'x'" warnings.
Fix these. While we are at it, remove some bogus parens.
Tested-by: Kyle Moffett <Kyle.D.Moffett@boeing.com>
As a part of the manufacturing process for some of our custom hardware,
we are programming the EEPROMs attached to our Intel 82571EB controllers
from software using U-Boot and Linux.
This code provides several conditionally-compiled features to assist in
our manufacturing process:
CONFIG_CMD_E1000:
This is a basic "e1000" command which allows querying the controller
and (if other config options are set) performing EEPROM programming.
In particular, with CONFIG_E1000_SPI this allows you to display a
hex-dump of the EEPROM, copy to/from main memory, and verify/update
the software checksum.
CONFIG_E1000_SPI_GENERIC:
Build a generic SPI driver providing the standard U-Boot SPI driver
interface. This allows commands such as "sspi" to access the bus
attached to the E1000 controller. Additionally, some E1000 chipsets
can support user data in a reserved space in the E1000 EEPROM which
could be used for U-Boot environment storage.
CONFIG_E1000_SPI:
The core SPI access code used by the above interfaces.
For example, the following commands allow you to program the EEPROM from
a USB device (assumes CONFIG_E1000_SPI and CONFIG_CMD_E1000 are enabled):
usb start
fatload usb 0 $loadaddr 82571EB_No_Mgmt_Discrete-LOM.bin
e1000 0 spi program $loadaddr 0 1024
e1000 0 spi checksum update
Please keep in mind that the Intel-provided .eep files are organized as
16-bit words. When converting them to binary form for programming you
must byteswap each 16-bit word so that it is in little-endian form.
This means that when reading and writing words to the SPI EEPROM, the
bit ordering for each word looks like this on the wire:
Time >>>
... [7, 6, 5, 4, 3, 2, 1, 0, 15, 14, 13, 12, 11, 10, 9, 8], ...
(MSB is 15, LSB is 0).
Signed-off-by: Kyle Moffett <Kyle.D.Moffett@boeing.com>
A followup patch will be adding a configurable feature to enable
programming of E1000 EEPROMs from the command line or via the generic
U-Boot SPI interface.
In order for it to work it needs access to certain E1000-internal
functions, so export those in the e1000.h header file.
As an aide to debugging, we should print out the expected value of the
EEPROM checksum in addition to just saying that it is wrong.
By allocating the e1000 device structures much earlier, we can easily
generate better error messages and siginficantly clean things up.
The only user-visable change (aside from reworded error messages) is
that a detected e1000 device which fails to initialize due to software
or hardware error will still be allocated a device number.
As one example, consider a system with 2 e1000 PCI devices where the
first controller has a corrupted EEPROM. Using the old code the
second controller would be "e1000#0", while with this change it would be
"e1000#1".
This change should hopefully make such EEPROM errors much more
straightforward to handle correctly in boot scripts and the like.
It is also necessary for a followup patch which allows SPI programming
of an e1000 controller's EEPROM even if the checksum is invalid.
Consolidate the test for a dual-port NIC to one location for easy
modification, then fix support for the dual-port 82571.
ARM: Add Calxeda Highbank platform
dkb: make mmc command as default enabled
Marvell: dkb: add mmc support
ARM: pantheon: add mmc definition
davinci: remove config.mk file from the sources
ARM:AM33XX: Add support for TI AM335X EVM
ARM:AM33XX: Added timer support
ARM:AM33XX: Add emif/ddr support
ARM:AM33XX: Add clock definitions
ARM:AM33XX: Added support for AM33xx
omap3/emif4: fix registers definition
davinci: emac: add new features to autonegotiate for EMAC
da850evm: Move LPSC configuration to board_early_init_f()
omap4_panda: Build in cmd_gpio support on panda
omap: Don't use gpio_free to change direction to input
mmc: omap: Allow OMAP_HSMMC[23]_BASE to be unset
OMAP3: overo : Add environment variable optargs to bootargs
OMAP3: overo: Move ethernet CS4 configuration to execute based on board id
OMAP3: overo : Use ttyO2 instead of ttyS2.
da830: add support for NAND boot mode
dm36x: revert cache disable patch
dm644X: revert cache disable patch
devkit8000: Add malloc space
omap: spl: fix build break due to changes in FAT
OMAP3 SPL: Provide weak omap_rev_string
omap: beagle: Use ubifs instead of jffs2 for nand boot
omap: overo: Disable pull-ups on camera PCLK, HS and VS signals
omap: overo: Configure mux for gpio10
SPL: Add DMA library
omap3: Add interface for omap3 DMA
omap3: Add DMA register accessors
omap3: Add Base register for DMA
arm, davinci: add missing LSPC define for MMC/SD1
U-Boot/SPL: omap4: Make ddr pre-calculated timings as default.
DaVinci: correct MDSTAT.STATE mask
omap4: splitting padconfs into common, 4430 and 4460
omap4: adding revision detection for 4460 ES1.1
omap4: replacing OMAP4_CONTROL with OMAP4430_CONTROL
gplug: fixed build error as a result of code cleanup patch
kirkwood_spi: add dummy spi_init()
gpio: mvmfp: reduce include platform file
ARM: orion5x: reduce dependence of including platform file
serial: reduce include platform file for marvell chip
ARM: kirkwood: reduce dependence of including platform file
ARM: armada100: reduce dependence of including platform file
ARM: pantheon: reduce dependence of including platform file
Armada100: Add env storage support for Marvell gplugD
Armada100: Add SPI flash support for Marvell gplugD
Armada100: Add SPI support for Marvell gplugD
SPI: Add SPI driver support for Marvell Armada100
dreamplug: initial board support.
imx: fix coding style
misc: pmic: drop old Freescale's pmic driver
MX31: mx31pdk: use new pmic driver
MX31: mx31ads: use new pmic driver
MX31: mx31_litekit: use new pmic driver
MX5: mx53evk: use new pmic driver
MX5: mx51evk: use new pmic driver
MX35: mx35pdk: use new pmic driver
misc: pmic: addI2C support to pmic_fsl driver
misc: pmic: use I2C_SET_BUS in pmic I2C
MX5: efikamx/efikasb: use new pmic driver
MX3: qong: use new pmic driver
RTC: Switch mc13783 to generic pmic code
MX5: vision2: use new pmic driver
misc: pmic: Freescale PMIC switches to generic PMIC driver
misc:pmic:samsung Enable PMIC driver at GONI target
misc:pmic:max8998 MAX8998 support at a new PMIC driver.
misc:pmic:core New generic PMIC driver
mx31pdk: Remove unneeded config
mx31: provide readable WEIM CS accessor
MX51: vision2: Set global macros
I2C: Add i2c_get/set_speed() to mxc_i2c.c
ARM: Update mach-types
devkit8000: Add config to enable SPL MMC boot
devkit8000: protect board_mmc_init
arm, post: add missing post_time_ms for arm
cosmetic, post: Codingstyle cleanup
arm, logbuffer: make it compileclean
tegra2: Enable MMC for Seaboard
tegra2: Add more pinmux functions
tegra2: Rename PIN_ to PINGRP_
tegra2: Add more clock functions
tegra2: Clean up board code a little
tegra2: Rename CLOCK_PLL_ID to CLOCK_ID
