Memory allocated via malloc is not guaranteed to be zeroized.
So explicitly use calloc instead of malloc.
Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
We add the various SMC91XX symbols to drivers/net/Kconfig and then this
converts the following to Kconfig:
CONFIG_SMC911X
CONFIG_SMC911X_BASE
CONFIG_SMC911X_16_BIT
CONFIG_SMC911X_32_BIT
[trini: Apply to the rest of the tree, re-squash old and new patch]
U-Boot widely uses error() as a bit noisier variant of printf().
This macro causes name conflict with the following line in
include/linux/compiler-gcc.h:
# define __compiletime_error(message) __attribute__((error(message)))
This prevents us from using __compiletime_error(), and makes it
difficult to fully sync BUILD_BUG macros with Linux. (Notice
Linux's BUILD_BUG_ON_MSG is implemented by using compiletime_assert().)
Let's convert error() into now treewide-available pr_err().
Done with the help of Coccinelle, excluing tools/ directory.
The semantic patch I used is as follows:
// <smpl>
-error
+pr_err
// </smpl>
[trini: Re-run Coccinelle]
CONFIG_MVNETA
Signed-off-by: Chris Packham <judge.packham@gmail.com>
Add support for obtaining PHY reset GPIO from DT and toggling it
before configuring the PHY to put the PHY into defined state.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
After soft reset complete, write mac address immediately will fail.
Add delay to work around this problem.
Signed-off-by: rick <rick@andestech.com>
Add cache inval and flush when rx and tx.
Update the Micrel KSZ90x1 driver for a live tree.
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Update the Designware Ethernet MAC driver to support a live device
tree.
All these places seem to inherit the codes from the MMC driver where
a FIXME was put in the comment. However the correct operation after
read should be cache invalidate, not flush.
The underlying drivers should be responsible for the cache operation.
Remove these codes completely.
Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
Tested-by: York Sun <york.sun@nxp.com>
This patch adds support for RGMII protocol
NXP's LDPAA2 support RGMII protocol. LS1088A is the
first Soc supporting both RGMII and SGMII.
Signed-off-by: Amrita Kumari <amrita.kumari@nxp.com>
Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com>
LS1088A is compliant with the Layerscape Chassis Generation 3 with
eight ARM v8 Cortex-A53 cores in 2 cluster, CCI-400, one 64-bit DDR4
SDRAM memory controller with ECC, Data path acceleration architecture
2.0 (DPAA2), Ethernet interfaces (SGMIIs, RGMIIs, QSGMIIs, XFIs),
QSPI, IFC, PCIe, SATA, USB, SDXC, DUARTs etc.
Signed-off-by: Alison Wang <alison.wang@nxp.com>
Signed-off-by: Raghav Dogra <raghav.dogra@nxp.com>
Signed-off-by: Shaohui Xie <Shaohui.Xie@nxp.com>
[YS: Revised commit message]
Update MC address calculation as per MC design requirement of address
as least significant 512MB address of MC private allocated memory,
i.e. address should point to end address masked with 512MB offset in
private DRAM block.
Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
Signed-off-by: Ashish Kumar <ashish.kumar@nxp.com>
[YS: reformatted commit message]
%s/Desriptor/Descriptor/g
The old logic always enabled the TX-delay when the phy-mode was set to
PHY_INTERFACE_MODE_RGMII. With this patch we enable the TX delay for
PHY_INTERFACE_MODE_RGMII_ID and PHY_INTERFACE_MODE_RGMII_TXID and
disable it for PHY_INTERFACE_MODE_RGMII.
Based on a similar change made in the Linux Realtek PHY driver
by Martin Blumenstingl <martin.blumenstingl@googlemail.com>.
Signed-off-by: Madalin Bucur <madalin.bucur@nxp.com>
Acked-by: York Sun <york.sun@nxp.com>
Update pfla02 for setenv changes and PHYLIB/etc migration to Kconfig.
We are now using an env_ prefix for environment functions. Rename these
other functions as well, for consistency:
getenv_vlan()
getenv_bootm_size()
getenv_bootm_low()
getenv_bootm_mapsize()
env_get_default()
Suggested-by: Wolfgang Denk <wd@denx.de>
Rename this function for consistency with env_get().
two functions for consistency. Also add function comments in common.h.
Quite a few places use getenv() in a condition context, provoking a
warning from checkpatch. These are fixed up in this patch also.
Rename this function for consistency with env_set().
commonly used functions, for consistency. Also add function comments in
common.h.
We are now using an env_ prefix for environment functions. Rename setenv()
Even after memory free of phydev, priv is still pointing to the
obsolete address.
So update priv->phydev as NULL after memory free.
The GMAC in the RK3368 once again is identical to the incarnation in
the RK3288 and the RK3399, except for where some of the configuration
and control registers are located in the GRF.
This adds the RK3368-specific logic necessary to reuse this driver.
Set BM poll size once during priv probe and do not
overwrite it during port probe procedure. Pool is common for
all CP ports.
Signed-off-by: Stefan Chulski <stefanc@marvell.com>
Tested-by: iSoC Platform CI <ykjenk@marvell.com>
Reviewed-by: Nadav Haklai <nadavh@marvell.com>
Reviewed-by: Igal Liberman <igall@marvell.com>
TX drain in transmit procedure could cause issues due
to race between drain procedure and transmition of descriptor
between AGGR TXQ and physical TXQ.
TXQ will be cleared before moving to Linux by stop procedure.
MVPP22 driver support 64 Bit arch and require BM pool
high address configuration.
Remove IRQ configuration from U-Boot PP driver.
U-Boot don't use interrupts and configuration of IRQ in U-Boot
caused crashes in Linux shared interrupt mode.
Also interrupt use is redundant in RX routine since a single RX
queue is used.
MBUS driver were replaced by AXI in PPv22 and relevant
only for PPv21.
U-boot use single physical tx queue with size 16 descriptors.
So aggregated tx queue size should be equal to physical tx queue
and cpu descriptor chunk(number of descriptors delivered from
physical tx queue to aggregated tx queue by one chunk) shouldn't be
larger than physical tx queue.
Fix:
Set AGGR_TXQ and CPU_DESC_CHUNK to be 16 descriptors, same as
physical TXQ.
Issue:
BM counters were overrun by probe that called per Network interface and
caused release of wrong number of buffers during remove procedure.
Fix:
Use probe_done and num_ports to call init and remove procedure
once per communication controller.
This patch enables padding of packets shorter than 64B in TX(set by default).
Disabling of padding causes crashes on MACCIATO board.
A8K marvell SoC has two South Bridge communication controllers(CP0 and CP1).
Each communication controller has packet processor ports and MDIO.
On MACHIATOBin board ports from CP1 are connected to mdio on CP0.
Issue:
Wrong base address is assigned to MDIO interface during probe.
Fix:
Get MDIO address from PHY handler parent base address.
This should be refined in the future when MDIO driver is implemented.
This patch add GPIO configuration support in mvpp2x driver.
Driver will handle 10G SFP gpio reset and SFP TX disable. GPIO pins should
be set in device tree.
Reviewed-by: Kostya Porotchkin <kostap@marvell.com>
In fsl_mc_ldpaa_exit(), in case of mc is booted and dpl is applied,
it should return earlier without executing dpbp_exit().
Signed-off-by: Santan Kumar <santan.kumar@nxp.com>
Acked-by: Priyanka Jain <priyanka.jain@nxp.com>
Acked-by: Yogesh Narayan Gaur <yogeshnarayan.gaur@nxp.com>
The environment variable "disable_giga" can now be used to disable
1000baseTx on the Micrel's KSZ9031.
Signed-off-by: Sebastien Bourdelin <sebastien.bourdelin@savoirfairelinux.com>
Added the AFE (Analog Front End) settings for stability to the
Broadcom Cygnus phy. This improves the time take to perform
auto negotiation.
Signed-off-by: Arun Parameswaran <arun.parameswaran@broadcom.com>
move to Kconfig:
CONFIG_BCM_SF2_ETH
CONFIG_BCM_SF2_ETH_DEFAULT_PORT
CONFIG_BCM_SF2_ETH_GMAC
Also modified defconfigs of all platforms that use these configs.
Signed-off-by: Suji Velupillai <suji.velupillai@broadcom.com>
Tested-by: Suji Velupillai <suji.velupillai@broadcom.com>
Reviewed-by: JD Zheng <jiandong.zheng@broadcom.com>
Reviewed-by: Scott Branden <scott.branden@broadcom.com>
Signed-off-by: Steve Rae <steve.rae@raedomain.com>
The correct option is PHY_MICREL_KSZ90X1, but some configs still
select the 9021 and 9031 options, which are deprecated.
Signed-off-by: Alexandru Gagniuc <alex.g@adaptrum.com>
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
There should be no longer be any ksz9000 users that pick up the PHY
driver from ksz8xxx, so remove ksz9000 remnants from there.
The KS8721BL and KSZ9021 PHYs are software-incompatible, yet they
share the same ID. Drivers for bothe PHYs cannot safely coexist, so
the solution was to use #ifdefs to select between the two drivers.
As a result KSZ9031, which has a unique ID, is now caught in the
crossfire. Unless CONFIG_PHY_MICREL_KSZ9031 is defined, the KSZ9031
will not function properly, as some essential configuration code is
ifdef'd-out.
To prevent such situations, move the KSZ9000 drivers to a separate
file, and place them under a separate Kconfig option. While it is
possible to enable both KSZ8000 and KSZ9000 drivers at the same time,
the assumption is that it is highly unlikely for a system to contain
both a KSZ8000 and a KSZ9000 PHY, and that only one of the drivers
will be enabled at any given time.
Don't wait forever.
Pass errors back to the caller.
The register constants don't use the exact names that are used in the
TRM, so add comments that use the exact names so that it is clear what
register is being referred to.
https://www.atheros-drivers.com/qualcomm-atheros-datasheets-for-AR9331.html
phy_device_create(..) sets the addr of phy_device with a sane value.
There is no need overwrite it.
Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com>
Reviewed-by: Hannes Schmelzer <oe5hpm@oevsv.at>
Tested-by: Hannes Schmelzer <oe5hpm@oevsv.at>
Add support for enabling and disabling the clock using the clock
framework based on the content of OF instead of doing it manually
in the board file.
The order of parameters passed to the phy_connect() was wrong.
Moreover, only PHY address 0 was used. Replace this with code
capable of detecting the PHY address.
