path: root/drivers/net
2017-01-04powerpc: mpc85xx: Remove variant SoCs T1020/T1022/T1013/T1014York Sun
Remove these SoCs from Kconfig because they don't have individual configuration. Clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-12-27Update Maintainer and Author's email addressAjay Bhargav
I am not longer using my old email address "ajay.bhargav@einfochips.com". For U-Boot development email address is now updated to contact@8051projects.net Signed-off-by: Ajay Bhargav <contact@8051projects.net>
2016-12-20net: xilinx: Use mdio_register_seq() to support multiple instancesMichal Simek
axi_emac, emaclite and gem have the same issue with registering multiple instances with mdio busses. mdio bus name has to be uniq but drivers are setting up only one name for all. Use mdio_register_seq() and pass dev->seq number to allow multiple mdio instances registration. Reported-by: Phani Kiran Kara <phanikiran.kara@gmail.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-12-18Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
Migrate CONFIG_ARCH_USE_MEMSET/MEMCPY with this merge. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-12-16dm: net: fec: Add .read_rom_hwaddrJagan Teki
Add .read_rom_hwaddr on dm eth_ops. Cc: Stefano Babic <sbabic@denx.de> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2016-12-16net: fec_mxc: Driver cleanupsJagan Teki
- Remove exctra space - Add space - Add tab space - Fix single line comments quotes - Fix 'CHECK: Avoid CamelCase' - Fix 'CHECK: Alignment should match open parenthesis' - Fix 'WARNING: line over 80 characters' - Re-arrage header include files Cc: Simon Glass <sjg@chromium.org> Cc: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Michael Trimarchi <michael@amarulasolutions.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2016-12-16net: fec_mxc: Convert into driver modelJagan Teki
This patch add driver model support for fec_mxc driver. Cc: Simon Glass <sjg@chromium.org> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-12-16net: fec_mxc: Remove unneeded eth_device arg from fec_get_hwaddrJagan Teki
fec_get_hwaddr never used eth_device argument, hence removed. Cc: Simon Glass <sjg@chromium.org> Cc: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Michael Trimarchi <michael@amarulasolutions.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2016-12-16arm: imx: add i.MX53 Beckhoff CX9020 Embedded PCPatrick Bruenn
Add CX9020 board based on mx53loco. Add simplified imx53 base device tree from kernel v4.8-rc8, to reuse serial_mxc with DTE and prepare for device tree migration of other functions and imx53 devices. The CX9020 differs from i.MX53 Quick Start Board by: - use uart2 instead of uart1 - DVI-D connector instead of VGA - no audio - CCAT FPGA connected to emi - enable rtc Signed-off-by: Patrick Bruenn <p.bruenn@beckhoff.com>
2016-12-15driver: fsl-mc: qbman: Add QBMAN 4.1 supportPriyanka Jain
LS2080A SoC family has QBMAN ver 4.0 whereas newer SoCs like LS2088A, LS1088A has QBMAN ver 4.1 QBMAN ver 4.0 and ver 4.1 supports dqrr size as 4 and 8 respectively. Add support of to check QBMAN version based on SoC SVR update dqrr_size accordingly update code to support larger dqrr_size Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com> Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-12-09Revert "Merge branch 'master' of git://www.denx.de/git/u-boot-microblaze"Tom Rini
This reverts commit 3edc0c252257e4afed163a3a74aba24a5509b198, reversing changes made to bb135a0180c31fbd7456021fb9700b49bba7f533.
2016-12-09Merge branch 'master' of git://www.denx.de/git/u-boot-microblazeTom Rini
2016-12-08net/phy/vitesse: Rework RGMII skew configuration for VSC8601Alex
The VSC8601 config tried to add an RGMII skew based on #defines that no config defines. That's quite an ugly way to do it. Since the skew is only needed on RGMII interfaces, check the interface mode at runtime, and apply the settings accordingly. Tested on custom board with AM3352 SOC and VSC801 PHY. Signed-off-by: Alexandru Gagniuc <alex.g@adaptrum.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-12-08net: fman: fix 2.5G SGMII settingsshaohui xie
The settings for 2.5G SGMII are wrong, which the 2.5G case is missed in set_if_mode(), and the serdes PCS configuration are wrong, this patch uses the correct settings took from Linux. Signed-off-by: Shaohui Xie <Shaohui.Xie@nxp.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-12-08net: phy: realtek: Only force master mode on rtl8211b/coliver@schinagl.nl
Commit 525d187af ("net: phy: Optionally force master mode for RTL PHY") added the define to force the PHY into master mode. Unfortunatly this is an all or nothing switch. So it applies to either all PHY's or no PHY's. The bug that define tried to solve was a buggy PLL in the RTL8211C only. The Olimex OLinuXino Lime2 has gotten an upgrade where the PHY was replaced with an RTL8211E. With this define however, both lime2 boards are either forced to master mode or not. We could of course have a binary for each board, but the following patch fixes this by adding a 'quirk' to the flags to the rtl8211b and rtl8211c only. It is now possible to force master mode, but only have it apply to the rtl8211b and rtl8211c. Signed-off-by: Olliver Schinagl <oliver@schinagl.nl> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-12-08net: phy: realtek: make define more consistentoliver@schinagl.nl
All internal defines in the realtek phy are with a small X, except MIIM_RTL8211X_CTRL1000T_MASTER. Make this more consistent Signed-off-by: Olliver Schinagl <oliver@schinagl.nl> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-12-08net: phy: realtek: Use the BIT() macrooliver@schinagl.nl
The BIT macro is the preferred method to set bits. This patch adds the bit macro and converts bit invocations. Signed-off-by: Olliver Schinagl <oliver@schinagl.nl> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-12-08net: phy: micrel: Fix error handlingMarek Vasut
Fix the following error, the $ret variable handling must be part of the loop, while due to the missing parenthesis it was not. drivers/net/phy/micrel.c: In function ‘ksz9021_of_config’: drivers/net/phy/micrel.c:303:2: warning: this ‘for’ clause does not guard... [-Wmisleading-indentation] for (i = 0; i < ARRAY_SIZE(ofcfg); i++) ^~~ drivers/net/phy/micrel.c:305:3: note: ...this statement, but the latter is misleadingly indented as if it is guarded by the ‘for’ if (ret) ^~ drivers/net/phy/micrel.c: In function ‘ksz9031_of_config’: drivers/net/phy/micrel.c:411:2: warning: this ‘for’ clause does not guard... [-Wmisleading-indentation] for (i = 0; i < ARRAY_SIZE(ofcfg); i++) ^~~ drivers/net/phy/micrel.c:413:3: note: ...this statement, but the latter is misleadingly indented as if it is guarded by the ‘for’ if (ret) ^~ Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-12-08net: xilinx: Use mdio_register_seq() to support multiple instancesMichal Simek
axi_emac, emaclite and gem have the same issue with registering multiple instances with mdio busses. mdio bus name has to be uniq but drivers are setting up only one name for all. Use mdio_register_seq() and pass dev->seq number to allow multiple mdio instances registration. Reported-by: Phani Kiran Kara <phanikiran.kara@gmail.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Series-to: u-boot Series-cc: Phani Kiran Kara <phanikiran.kara@gmail.com>
2016-12-04net: rtl8169: remove unneeded definitionAndre Przywara
The rtl8169_intr_mask variable isn't used anywhere in the code, so just remove it to avoid a GCC 6.2 compiler warning. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-12-04net: e1000: fix indentationAndre Przywara
Apparently the indentation is off here, for the IGB model just want to bail out early. Fix this to avoid both compiler warnings and puzzled readers. Pointed out by GCC 6.2's -Wmisleading-indentation warning. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-12-02common: miiphyutil: Work and report phy address in hex in mdio cmdMichal Simek
It is confusing that mdio commands work and report phy id as decimal value when mii is working with hex values. For example: ZynqMP> mdio list gem: 21 - TI DP83867 <--> ethernet@ff0e0000 ZynqMP> mdio read ethernet@ff0e0000 0 Reading from bus gem PHY at address 21: 0 - 0x1140 ZynqMP> mii dump 21 0 Incorrect PHY address. Range should be 0-31 ... ZynqMP> mii dump 15 0. (1140) -- PHY control register -- (8000:0000) 0.15 = 0 reset U-Boot normally takes hex values that's why this patch is changing mdio command to handle hex instead of changing mii command to handle decimal values. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-11-29Merge git://git.denx.de/u-boot-mpc85xxTom Rini
2016-11-28drivers: net: keystone_net: add rgmii link type support when parsing dtMugunthan V N
Add support to detect RGMII link interface from link-interface device tree entry. Also rename the existing link type enums so that it provides meaningful interface like SGMII. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reported-by: Sekhar Nori <nsekhar@ti.com> Tested-by: Sekhar Nori <nsekhar@ti.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-11-28sun8i_emac: Fix mdio read sequencePhilipp Tomsich
To send a parametrized command to the PHY over MDIO, we should write the data first, the trigger the execution by the command register write. Fix the access pattern in our MDIO write routine. Apparently this doesn't really matter with the Realtek PHY on the Pine64, but other PHYs (which require more setup) will choke on the wrong order. [Andre: add commit message] Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Jagan Teki <jagan@openedev.com>
2016-11-23powerpc: T4080: Drop configuration for T4080York Sun
There is no T4080 target. Drop related macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T4240: Remove macro CONFIG_PPC_T4240York Sun
Use CONFIG_ARCH_T4240 from Kconfig instead. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T4160: Remove macro CONFIG_PPC_T4160York Sun
Use CONFIG_ARCH_T4160 instead. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T2080, T2081: Remove macro CONFIG_PPC_T2080 and CONFIG_PPC_T2081York Sun
Use CONFIG_ARCH_T2080 and CONFIG_ARCH_T2081 instead. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T1042: Remove macro CONFIG_PPC_T1042York Sun
Replace CONFIG_PPC_T1042 with ARCH_T1024 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T1040: Remove macro CONFIG_PPC_T1040York Sun
Replace CONFIG_PPC_T1040 with ARCH_T1040 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T1024: Remove macro CONFIG_PPC_T1024York Sun
Replace CONFIG_PPC_T1024 with ARCH_T1024 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T1023: Remove macro CONFIG_PPC_T1023York Sun
Replace CONFIG_PPC_T1023 with ARCH_T1023 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: B4420: Remove macro CONFIG_PPC_B4420York Sun
Replace CONFIG_PPC_B4420 with ARCH_B4420 in Kconfig and clean up existing macros.
2016-11-23powerpc: B4860QDS: Remove macro CONFIG_B4860QDSYork Sun
Use CONFIG_TARGET_B4860QDS instead. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: B4860: Remove macro CONFIG_PPC_B4860York Sun
Replace CONFIG_PPC_B4860 with ARCH_B4860 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P5040: Remove macro CONFIG_P5040York Sun
Replace CONFIG_P5040 with ARCH_P5040 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P5020: Remove macro CONFIG_PPC_P5020York Sun
Replace CONFIG_PPC_P5020 with ARCH_P5020 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P4080: Remove macro CONFIG_PPC_P4080York Sun
Replace CONFIG_PPC_P4080 with ARCH_P4080 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P3041: Remove macro CONFIG_PPC_P3041York Sun
Replace CONFIG_PPC_P3041 with ARCH_P3041 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P2041: Remove macro CONFIG_PPC_P2041York Sun
Replace CONFIG_PPC_P2041 with ARCH_P2041 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P1017: Drop configuration for P1017York Sun
P1017 is a single-core version of P1023. There is no P1017 target configured. Drop related macros. P1017 SoC is still supported. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P1023: Remove macro CONFIG_P1023York Sun
Replace CONFIG_P1023 with ARCH_P1023 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-21driver: net: ldpaa_eth: Fix missing bracket issuePriyanka Jain
Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com> Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-11-17Merge tag 'signed-efi-next' of git://github.com/agraf/u-bootTom Rini
Patch queue for efi - 2016-11-17 Highlights this time around: - x86 efi_loader support - hello world efi test case - network device name is now representative - terminal output reports modes correctly - fix psci reset for ls1043/ls1046 - fix efi_add_runtime_mmio definition for x86 - efi_loader support for ls2080
2016-11-17ls2080: Exit dpaa only right before exiting U-BootAlexander Graf
On ls2080 we have a separate network fabric component which we need to shut down before we enter Linux (or any other OS). Along with that also comes configuration of the fabric using a description file. Today we always stop and configure the fabric in the boot script and (again) exit it on device tree generation. This works ok for the normal booti case, but with bootefi the payload we're running may still want to access the network. So let's add a new fsl_mc command that defers configuration and stopping the hardware to when we actually exit U-Boot, so that we can still use the fabric from an EFI payload. For existing boot scripts, nothing should change with this patch. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: York Sun <york.sun@nxp.com> [agraf: Fix x86 build]
2016-11-15net: zynq_gem: Correct SGMII enable bit settingSiva Durga Prasad Paladugu
Correct the SGMII enable bit position to 27 instead of 31. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-11-15net: zynq_gem: Modify the nwcfg bit definitionsSiva Durga Prasad Paladugu
Modify the nwcfg bit definitions to have 32-bit by removing the extra nibble. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-11-07net: mvgbe: Fix build error with CONFIG_PHYLIBChris Packham
Commit 5a49f17481bb ("net: mii: Use spatch to update miiphy_register") updated the mvgbe implementation of smi_reg_read/smi_reg_write. Prior to that change mvgbe_phy_read and mvgbe_phy_write where used as wrappers to satisfy the phylib APIs. Because these functions weren't updated in that commit build errors where triggered when CONFIG_PHYLIB was enabled. Fix these build errors by removing mvgbe_phy_read and mvgbe_phy_write and using smi_reg_read/smi_reg_write directly. Signed-off-by: Chris Packham <judge.packham@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-11-07net: phy: micrel: center FLP burst timing at 16msAsh Charles
Like [1], reset the FLP burst timing for the KSZ9031 to the 16ms specified by the IEEE802.3 standard from the chip's default of 8ms. For more details, see the "Auto-Negotiation Timing" section of the KSZ9031RNX datasheet. [1] https://patchwork.kernel.org/patch/6558371/ Signed-off-by: Ash Charles <ash.charles@savoirfairelinux.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
