The DT binding says:
- phy-reset-duration : Reset duration in milliseconds. Should present
only if property "phy-reset-gpios" is available. Missing the property
will have the duration be 1 millisecond. Numbers greater than 1000 are
invalid and 1 millisecond will be used instead.
However the current code:
- clamps values greater than 1000ms to 1000ms rather than 1.
- does not initialize the delay if the property does not exist
(else clause mismatch)
- returns an error if phy-reset-gpios is not defined
Fix all this and simplify by using dev_read_u32_default()
Signed-off-by: Martin Fuzzey <martin.fuzzey@flowbird.group>
(cherry picked from commit 331fcabe4f9b4c7ec58d070da039f875673c9c9d)
The DT binding says that phy-reset-duration is in ms, but the driver
currently uses udelay().
Switch to mdelay() to fix this.
Reviewed-by: Michael Trimarchi <michael@amarulasolutions.com>
(cherry picked from commit 9b8b91888493d25873b835d262b89f1c4efa0df7)
Add the missing gpio phy reset binding to the gpio and
reset time configuration
Signed-off-by: Michael Trimarchi <michael@amarulasolutions.com>
(cherry picked from commit efd0b791069af93e9d439a70d1fe2ae8994dbbfa)
drivers/net/fec_mxc.c
When the power domain driver is enabled, we need to enable clocks after power
domain on. So the clock settings can't set in board_init, needs to set them
when the device is probed. Add this weak function in driver, that SoC codes
can implement the clock settings.
Reviewed-by: Peng Fan <peng.fan@nxp.com>
Signed-off-by: Ye Li <ye.li@nxp.com>
(cherry picked from commit c0e4ac66196b20f363f711fb18e40b70e3be9240)
The MIB RAM and FIFO receive start register does not exist on
i.MX8. Accessing these register will cause SERROR in kernel.
(cherry picked from commit 2a47ebbccb95e8482360813d6dff5288429f1248)
The formal production name starts with imx, so change relevant names
in codes to use this prefix.
Add the fuse checking in drivers, when the module is disabled in fuse,
the driver will not work.
Changed drivers: BEE, GPMI, APBH-DMA, ESDHC, FEC, QSPI, ECSPI, I2C,
USB-EHCI, GIS, LCDIF and EPDC.
(cherry picked from commit 1704e116f9b39aeb99201919a18bc2b1e19a980e)
(cherry picked from commit 2d3b5df8530cd5ef883750378838dea7c40259af)
Since the probe function has changed to reset FEC controller prior than
setup PHY. If reset FEC controller timeout, the priv->phydev is not
initialized, so can't free it.
Add i.MX6UL/SX/SL/i.MX7D compatible.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
On i.MX6SX, 6UL and 7D, there are two enet controllers each has a
MDIO port. But Some boards share one MDIO port for the two enets. So
introduce a configuration CONFIG_FEC_MXC_MDIO_BASE to indicate
the MDIO port for sharing.
In Kconfig, user needs enable CONFIG_FEC_MXC_SHARE_MDIO first to enter
the CONFIG_FEC_MXC_MDIO_BASE.
To i.MX28, adapt to use the new config
Cc: Fabio Estevam <fabio.estevam@nxp.com>
To platforms has two enet interface, using dev->seq could
avoid conflict.
i.MX6UL/ULL evk board net get the wrong MAC address from fuse,
eth1 get MAC0 address, eth0 get MAC1 address from fuse. Set the
priv->dev_id to device->seq as the real net interface alias id then
.fec_get_hwaddr() read the related MAC address from fuse.
No need to provide two prototype for this function.
Use ulong for the first parameter, then this function
could be shared for DM/non DM case.
When using ethernet DM driver, the recv interface has a
change with non-DM interface, that driver needs to set
the packet pointer and provide it to upper layer to process.
In fec driver, the fecmxc_recv functions does not handle the
packet pointer parameter. This may cause crash in upper layer
processing because the packet pointer is not set.
This patch allocates a buffer for the packet pointer and free it
through free_pkt interface.
Thomas reported U-Boot failed to build host tools if libfdt-devel
package is installed because tools include libfdt headers from
/usr/include/ instead of using internal ones.
This commit moves the header code:
include/libfdt.h -> include/linux/libfdt.h
include/libfdt_env.h -> include/linux/libfdt_env.h
and replaces include directives:
#include <libfdt.h> -> #include <linux/libfdt.h>
#include <libfdt_env.h> -> #include <linux/libfdt_env.h>
Reported-by: Thomas Petazzoni <thomas.petazzoni@bootlin.com>
Add entries for the R8A77965 M3N SoC.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Signed-off-by: Arno Steffens <star@gmx.li>
Fix commit f1bcad22dd19 ("net: e1000: add support for writing to
EEPROM").
Signed-off-by: Bernhard Messerklinger <bernhard.messerklinger@br-automation.com>
After commit ba1f966725223 ("net: designware: add clock support")
we got NET broken on axs101 and axs103 platforms.
Some clock don't support gating so their clock drivers don't
implement .enable/.disable callbacks. In such case clk_enable
returns -ENOSYS.
Also some clock drivers implement .enable/.disable callbacks not for all
clock IDs and return -ENOSYS (or -ENOTSUPP) for others.
If we have such clock in 'clocks' list of designware ethernet controller
node we fail to probe designware ethernet.
Fix it.
Signed-off-by: Eugeniy Paltsev <Eugeniy.Paltsev@synopsys.com>
Reviewed-by: Patrice Chotard <patrice.chotard@st.com>
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Fix some style violations in the generic PHY management code.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
Commit 68e6ecadc551 ("net: phy: marvell 88e151x: Fix handling of RGMII
interface types") fixed the initialization of 88e151x phys, but made it
so that interfaces of type PHY_INTERFACE_MODE_RGMII had both RX and TX
delay bits cleared. The default (like in m88e1111s_config) is to have
both bits set.
Hence, this patch changes the behavior in the PHY_INTERFACE_MODE_RGMII
case so that both bits are set.
Fix some style violations (mostly wrong indentions) in the Marvell PHY
driver.
Make the tsec ethernet driver compatible with a live device tree.
tsec_initialize allocates a private driver structure using malloc.
Should the memory allocation of this private structure fail, the
function execution is aborted with a return 0, but the previously
allocated device structure is never freed, hence leaked.
Free the device structure in the error case.
ll_temac driver was used by Xilinx Microblaze big endian and
Xilinx ppc405/ppc440 SoCs.
ppc support was removed by: "powerpc: remove 4xx support"
(sha1: 98f705c9cefdfdba62c069821bbba10273a0a8ed)
and Microblaze BE is not tested for a long time that's why this driver
can be removed because none is going to updated it to DM anyway.
Drop the whole map/unmap_physmem stuff and just use the address
already obtained from DT in ofdata_to_platdata(), instead of
repeating that, wrongly, in probe.
Fix minor checkpatch warning about udelay(3000) being too long
and should be replaced by mdelay(3).
Drop the len variable, it's useless.
Inline this variable which is quite useless.
Reset and initialize the PHY once in the probe() function rather than
doing it over and over again is start() function. This requires us to
keep the clock enabled while the driver is in use. This significantly
reduces the time between transfers as the PHY doesn't have to restart
autonegotiation between transfers, which takes forever.
Cc: Geert Uytterhoeven <geert+renesas@glider.be>
There is no value to enable phylib without networking support.
Implement programming MAC address to the hardware, i.e. external flash
seen as EEPROM.
MAC address is only written if it differs from what is already stored in
flash or if reading the current MAC address fails.
Signed-off-by: Hannu Lounento <hannu.lounento@ge.com>
CC: Joe Hershberger <joe.hershberger@ni.com>
Signed-off-by: Martyn Welch <martyn.welch@collabora.co.uk>
Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
Split the implementation of e1000_read_mac_addr into eeprom and register
versions called by e1000_read_mac_addr.
This allows for calling e1000_read_mac_addr when MAC address is needed
with no constraints where it is read from, and for calling the register
and, especially, the eeprom version directly in order to specify where
to read the address from.
Port functions for writing to EEPROM, updating the checksum and
committing data to flash from the Linux kernel igb driver.
Functions were ported from Linux 4.8-rc2 (694d0d0bb20).
Reviewed-by: Stefano Babic <sbabic@denx.de>
When building for 64bits system, we get some warnings about type
cast between pointer and integer. This patch eliminates the warnings
by using ulong/long type which is 32bits on 32bits system or 64bits on
64bits system.
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
i.MX8M. Accessing these register will cause system hang.
For for case of lazyapply method, API fdt_fixup_board_enet() gets
invoked before DPL being deployed. This leads to an issue that
fsl-mc fdt fixup status marked as fail and dprc driver didn't get
registered in linux boot.
Fixes this issue by calling fdt_fixup_board_enet() for case when
DPL is deployed successfully in lazyapply method.
Signed-off-by: Yogesh Gaur <yogeshnarayan.gaur@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
When we have a driver that is used on both 32bit and 64bit targets and
we are talking about address space we cannot use u64 nor u32 and instead
need to use phys_addr_t.
Fixes: 377883f16d36 ("net: mvpp2x: fix phy connected to wrong mdio issue")
Cc: Stefan Chulski <stefanc@marvell.com>
Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
The GMAC in the RK3228 once again is identical to the incarnation in
the RK3288 and the RK3399, except for where some of the configuration
and control registers are located in the GRF.
This adds the RK3368-specific logic necessary to reuse this driver.
Signed-off-by: David Wu <david.wu@rock-chips.com>
Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
The GMAC2IO in the RK3328 once again is identical to the incarnation in
This adds the RK3328-specific logic necessary to reuse this driver.
The rv1108 GMAC only support rmii interface, so need to add the
set_rmii() ops. Use the phy current interface to set rmii or
rgmii ops. At the same time, need to set the mac clock rate of
rmii with 50M, the clock rate of rgmii with 125M.
Add DM capable code into the SH ethernet driver and support probing
both from DT and pdata. The legacy non-DM, non-DT support is retained
as there are still systems in the tree which are not DM or DT capable.
Move the legacy functions around, so that they can be wrapped in a
massive ifdef CONFIG_DM_ETH once DM support is added. No functional
change.
Split sh_eth_init() function into smaller chunks, which can
be called from both DM and non-DM code while handling the
specifics of both configurations.
Pull out the code for writing MAC address into the NIC into a
separate function, so it can be reused by both DM and non-DM
code. This is done in preparation for DM support, which handles
MAC address programming separately.
Split sh_eth_recv into two functions, one which checks whether
a packet was received and one which handles the received packet.
This is done in preparation for DM support, which handles these
two parts separately.
Pass sh_eth_dev structure around instead of eth_device, since the
later is specific to the legacy networking support. This change is
done in preparation for the DM addition.
