Don't use physical base address of registers directly, ioremap it first.
Save pointer in private struct ethoc and use that struct in all internal
functions.
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
Add Kconfig entry for the driver, remove #define CONFIG_ETHOC from the
only board configuration that uses it and put it into that board's
defconfig.
Cc: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
When adding support for the driver model the SPI EEPROM feature had
been ignored. Fix the build with both CONFIG_DM_ETH and
CONFIG_E1000_SPI enabled.
Signed-off-by: Alban Bedel <alban.bedel@avionic-design.de>
Use the right phy_connect() prototype for CONFIGF_DM_ETH.
Support to get the phy interface from dt and set GMAC_UR.
Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com>
Some code may want to read reg values from DT, but from nodes that aren't
associated with DM devices, so using dev_get_addr_index() isn't
appropriate. In this case, fdtdec_get_addr_size_*() are the functions to
use. However, "translation" (via the chain of ranges properties in parent
nodes) may still be desirable. Add a function parameter to request that,
and implement it. Update all call sites to default to the original
behaviour.
Squashed in build fix from Stephen:
cpsw tries to flush dcache which is not in the range of PKTALIGN.
Because of this the following warning comes while flushing:
CACHE: Misaligned operation at range [dffecec0, dffed016]
Fix it by flushing cache of size aligned to PKTALIGN.
Keystone net can have multiple ethernet slaves, currently only
slave 1 is supported by the driver. Register multiple slaves as
individual ethernets to network framework.
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
Each line should be terminated by semi-colon. It was not caught
earlier as there is a proper statement. Fix it by changing the
comma with semi-colon.
On DRA72 EVM, cpsw slaves may be muxed with other modules. This
selection is controlled by a pcf gpio line. Add support for cpsw driver
to acquire mode-gpios and select the appropriate slave using gpio APIs.
Signed-off-by: Vignesh R <vigneshr@ti.com>
Reviewed-by: Mugunthan V N <mugunthanvnm@ti.com>
This fixes the following CACHE warnings when using sun8i_emac:
=> dhcp
BOOTP broadcast 1
BOOTP broadcast 2
CACHE: Misaligned operation at range [7bf594a8, 7bf59628]
BOOTP broadcast 3
CACHE: Misaligned operation at range [7bf59c90, 7bf59e10]
CACHE: Misaligned operation at range [7bf5a478, 7bf5a5f8]
DHCP client bound to address 10.42.43.80 (1009 ms)
Note this commit also changes the max rx size from 2024 to 2044,
matching what the kernel driver uses.
Cc: Chen-Yu Tsai <wens@csie.org>
Cc: Corentin LABBE <clabbe.montjoie@gmail.com>
Cc: Amit Singh Tomar <amittomer25@gmail.com>
Acked-by: Ian Campbell <ijc@hellion.org.uk>
This corrects a build error on zynqmp.
In sun8i_emac_board_setup, the driver partially configures the syscon
register for H3 EPHY. However, the settings are incomplete, and
completely unusable. The correct settings are later set in
sun8i_emac_set_syscon, but the incorrect CLK_SEL setting persists.
It is incorrect to use CLK_SEL to select 25 MHz, as the SoC does not
have a 25 MHz clock the EPHY can use.
This patch removes the setting of the syscon register in board_setup,
and also moves set_syscon above mdio_init. While mdio_init does not
access the PHY, it is better to have the PHY parameters setup before
the MDIO bus is registered.
Fixes: a29710c525ff ("net: Add EMAC driver for H3/A83T/A64 SoCs.")
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
The sun8i_emac driver erroneously configures the AHB2 clock when it
assumes it is configuring the AXI gates, which is not even documented
or ever appeared in either the WiP kernel driver or Allwinner's original
driver.
As a result, AHB2 clock mux is set to an invalid setting, making the
EPHY unusable.
The Fman module on LS1046A is similiar with that on LS1043A but
LS1046A has one more XFI (10GbE) interface.
Signed-off-by: Shaohui Xie <Shaohui.Xie@nxp.com>
Signed-off-by: Mingkai Hu <mingkai.hu@nxp.com>
Signed-off-by: Gong Qianyu <Qianyu.Gong@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
This patch add EMAC driver support for H3/A83T/A64 SoCs.
Tested on Pine64(A64-External PHY) and Orangepipc(H3-Internal PHY).
BIG Thanks to Andre for providing some of the DT code.
Signed-off-by: Amit Singh Tomar <amittomer25@gmail.com>
Acked-by: Hans de Goede <hdegoede@redhat.com>
If MAC is directly connected to another MAC (like a switch for example)
we don't need to probe for a phy, autoneogation and so on. We simply
have to setup speed.
Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at>
Return value of rtl_send_common propogates unmodified all the way
up to eth_send and further to API consumer if CONFIG_API is enabled.
Previously rtl_send_common returned number of bytes sent on success
which was erroneouly detected as error condition by API consumers
that checked for operation success by comparing return value with 0.
Switch rtl_send_common to use common convention: return 0 on success
and negative value for failure.
Cc: Stephen Warren <swarren@nvidia.com>
Signed-off-by: Oleksandr Tymoshenko <gonzo@bluezbox.com>
This patch adds support for aquantia AQR106/107 PHY.
Commit 90b7fc924adf "net: designware: support phy reset device-tree
bindings" made DW GMAC driver dependent on DM_GPIO by unconditional
usage of purely DM_GPIO stuff like:
* dm_gpio_XXX()
* gpio_request_by_name()
But since that driver as of today might be easily used without
DM_GPIO (that's the case for Synopsys AXS10x boards) we're
shielding all DM_GPIO things by ifdefs.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Cc: Beniamino Galvani <b.galvani@gmail.com>
Cc: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
Cc: Sonic Zhang <sonic.zhang@analog.com>
Cc: Bin Meng <bmeng.cn@gmail.com>
Commit a058052c "net: phy: do not read configuration register on reset",
changes the behaviour of the phy_reset function such that the state of
the BMCR register is not preserved during reset.
Change the config function for the m88e1310 so that it does not do a
reset after configuring auto-negotiation.
Signed-off-by: Nathan Rossi <nathan@nathanrossi.com>
Cc: Michal Simek <michal.simek@xilinx.com>
Cc: Stefan Roese <sr@denx.de>
Acked-by: Michal Simek <michal.simek@xilinx.com>
This patch adds a phy driver for the Micrel KSZ886x switches.
Similarly to the KSZ8895, SoC MAC is directly connected to the switch
MAC on the switch CPU port, so the link to the switch is always up.
KSZ886x switches can be used in the following configuration modes:
- Unmanaged mode with config stored in external EEPROM
- Managed mode over SPI
- Managed mode over I2C
- Managed mode over mdio/mdc (aka MIIM or SMI)
This patch supports only unmanaged and MIIM modes.
Based on Micrel KSZ886x driver from Linux kernel and
Micrel KSZ8895 driver from U-Boot.
Verified with the KSZ8863MLL.
Signed-off-by: Alexey Firago <alexey_firago@mentor.com>
The rtl8169 driver uses a global variable to store the register address
of the adapter being operated upon. This is updated to point at the
correct adapter when sending or receiving a packet, or shutting down the
adapter, but not when initializing the adapter. Consequently, switching
between different adapters within the same U-Boot runtime does not work
correctly since the driver programs the wrong registers during
rtl8169_eth_start() -> rtl8169_common_start() -> rtl8169_hw_start().
Note that since rtl8169_eth_stop() does set the global variable, the
second consecutive attempt to use the "new" adapter did work even before
this patch, because each time network usage is shut down, the network
core calls stop, which sets the variable so that the next start does
actually initialize the hardware, and the adapter works.
Equally, rtl8169_eth_probe() calls rtl_init() which sets the global, so
if using only a single device, or if picking the "right" device (based on
probe order) when multiple devices are present, ioaddr will already be set
correctly from the get-go, so the issue does not occur.
Add driver-model support to this driver. The old code remains for now so
that we can convert boards one at a time.
Tested-on: smartweb, corvus, taurus, axm
Tested-by: Heiko Schocher <hs@denx.de>
Reviewed-by: Andreas Bießmann <andreas@biessmann.org>
The end address of the cache flush must be cache-line-aligned since
otherwise (at least on ARM926-EJS) the request is ignored. When the cache
is enabled this means that packets are not sent.
Adjust this driver to avoid using struct netdev in functions that driver
model will call. Also refactor the receive function to be compatible with
driver model.
Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
nand_info[] is now an array of pointers, with the actual mtd_info
instance embedded in struct nand_chip.
This is in preparation for syncing the NAND code with Linux 4.6,
which makes the same change to struct nand_chip. It's in a separate
commit due to the large amount of changes required to accommodate the
change to nand_info[].
Signed-off-by: Scott Wood <oss@buserror.net>
Add ethernet driver for the AR933x and AR934x Atheros MIPS machines.
The driver could be easily extended to other WiSoCs.
Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Cc: Wills Wang <wills.wang@live.com>
[fixed Kconfig dependency]
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
If dev->iobase is 64 bits wide then writing the value of the BAR into a
pointer to iobase will not work on big endian systems, where the BAR
value will incorrectly get written to the upper 32 bits of the 64 bit
variable. Fix this by reading the BAR into a u32, matching the type
expected by pci_read_config_dword.
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
Fix the pcnet driver to build safely on 64 bit platforms, in preparation
for allowing MIPS64 builds for Malta boards.
Now that MIPS virt_to_phys can handle kseg1 addresses on MIPS32, stop
manually converting addresses to their kseg0 equivalents in the pcnet
driver.
All members of the DMA descriptor must be 32-bit, even on 64-bit
architectures: change the type to u32 to ensure this. Also, fix
other warnings.
Signed-off-by: Beniamino Galvani <b.galvani@gmail.com>
[trini: Use phys_addr_t not unsigned long long to test that we're within
DMA'able memory]
Add support for the snps,reset-gpio, snps,reset-active-low (optional) and
snps,reset-delays-us device-tree bindings. The combination of these
three define how the PHY should be reset to ensure it's in a sane state.
Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
some case
When using rcw protocols to support 10G on MAC9 and MAC10, these MACs
should not be identified as 1G interface, otherwise, one MAC will be
listed as two Ethernet ports. For example, MAC9 will be listed as
FM1@TGEC1 and FM1@DTSEC9.
Signed-off-by: Ying Zhang <b40530@freescale.com>
drivers/net/zynq_gem.c
The code assumed that if the interface is not RGMII configured
then it must be SGMII configured. This device has the ability
to support most of the MII interfaces. Therefore add the
helper for SGMII and only configure the device if the interface is
configured for SGMII.
Signed-off-by: Dan Murphy <dmurphy@ti.com>
Reviewed-by: Michal Simek <michal.simek@xilinx.com>
Move the phy_interface_is_rgmii to the phy.h
file for all phy's to be able to use the API.
This now aligns with the Linux kernel based on
commit e463d88c36d42211aa72ed76d32fb8bf37820ef1
Tested-by: Mugunthan V N <mugunthanvnm@ti.com>
Not all devices use the same internal delay or fifo depth.
Add the ability to set the internal delay for rx or tx and the
fifo depth via the devicetree. If the value is not set in the
devicetree then set the delay to the default.
If devicetree is not used then use the default defines within the
driver.
Add the ability to pass the phy-handle node offset
to the phy driver. This allows the phy driver
to access the DT subnode's data and parse accordingly.
Tested-by: Michal Simek <michal.simek@xilinx.com>
Add the ability to read the phy-handle node of the
cpsw slave. Upon reading this handle the phy-id
can be stored based on the reg node in the DT.
The phy-handle also needs to be stored and passed
to the phy to access any phy data that is available.
Different TI platforms has to read with different combination to
get the mac address from efuse. So add support to read mac address
based on machine/device compatibles.
The code is taken from Linux drivers/net/ethernet/ti/cpsw-common.c
done by Tony Lindgren.
Since dra7x platforms address bus is define as 64 bits to support
LAPE, fdtdec_get_addr() returns a invalid address for mdio based
and gmii_sel register address. Fixing this by using
fdtdec_get_addr_size_auto_noparent() which will derive address
cell and size cell from its parent.
On some boards number of slaves can be 1 when only one port
ethernet is pinned out. So do not break when slave_index and
num slaves check fails, instead continue to parse the next
child.
The previous mv88e61xx driver was a driver for configuring the
switch, but did not integrate with the PHY/networking system, so
it could not be used as a PHY by U-boot. This is a complete
rework to support this device as a PHY.
Signed-off-by: Kevin Smith <kevin.smith@elecsyscorp.com>
Acked-by: Prafulla Wadaskar <prafulla@marvell.com>
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
