path: root/drivers/net
2012-04-04net/designware: Change timeout loop implementationAmit Virdi
The new implementation changes the timeout loop implementation to avoid 1 ms delay in each failing test. It also configures the delay to 10usec. Signed-off-by: Amit Virdi <amit.virdi@st.com>
2012-04-04net/designware: Set ANAR to 0x1e1Armando Visconti
This patch forces the advertised capabilities during auto negotiation to always be 10/100 Mbps and half/full as duplexing. Signed-off-by: Armando Visconti <armando.visconti@st.com> Signed-off-by: Amit Virdi <amit.virdi@st.com>
2012-04-04net/designware: Program phy registers when auto-negotiation is ONVikas Manocha
If AN(auto-negotiation) is ON, speed bit of control register are not applicable. Also phy registers were not getting programmed as per the result of AN. This patch sets only AN bit & restart AN bit for AN ON selection & programs PHY registers as per AN result. Signed-off-by: Vikas Manocha <vikas.manocha@st.com> Signed-off-by: Amit Virdi <amit.virdi@st.com>
2012-04-04net/designware: Try configuring phy on each dw_eth_initVipin Kumar
Phy autonegotiation works only when the ethernet cable is plugged in. Since the phy was configured only at the init time, a plugged in cable was necessary to initialize the phy properly. This patch keeps a flag to check if the phy initialization has succeeded, and calls configure_phy routine at every init if this flag reports otherwise. Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Signed-off-by: Amit Virdi <amit.virdi@st.com>
2012-04-04net/designware: Consecutive writes must have delayArmando Visconti
This patch solves a TX/RX problem which happens at 10Mbps, due to the fact that we are not respecting 4 cyles of the phy_clk (2.5MHz) between two consecutive writes on the same register. Signed-off-by: Armando Visconti <armando.visconti@st.com> Signed-off-by: Amit Virdi <amit.virdi@st.com>
2012-04-04net/designware: Phy address fixVipin KUMAR
The code assumes the phy address to be > 0, which is not true, the phy address can be in the range 0-31. Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Signed-off-by: Amit Virdi <amit.virdi@st.com>
2012-04-04net/designware: Fix the max frame length sizeVipin KUMAR
The max frame length for normal descriptor can be 0x7FF i.e 2047. It was wrongly specified as 2048. Currently, the max descriptor length is around 1500, so redefining the mask to 1600 Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Signed-off-by: Amit Virdi <amit.virdi@st.com>
2012-04-04net/designware: Fix to restore hw mac addressVipin KUMAR
The network controller mac resets hardware address stored in MAC_HI and MAC_LO registers if mac is resetted. So, hw mac address needs to be restored in case mac is explicitly resetted from driver. Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Signed-off-by: Amit Virdi <amit.virdi@st.com>
2012-04-04net: ll_temac: Add LL TEMAC driver to u-bootStephan Linz
Xilinx LocalLink Tri-Mode Ether MAC driver can be used by Xilinx Microblaze or Xilinx ppc405/440 in SDMA and FIFO mode. DCR or XPS bus can be used. The driver uses and requires MII and PHYLIB. CP: 4 warnings: 'Use of volatile is usually wrong' I won't fix this, because it depends on the network driver subsystem. Reported-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Stephan Linz <linz@li-pro.net>
2012-04-03mvgbe: remove warning for unused methodsStefan Bigler
Some baords may use the GBE interface but they have no phy connected to the interface and a direct MAC/MAC interface. For them we need to get rid of compiler warnings. Signed-off-by: Stefan Bigler <stefan.bigler@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Acked-by: Prafulla Wadaskar <prafulla@marvell.com>
2012-03-30net/altera_tse: use flush_dcache_range instead of flush_dcacheStefan Kristiansson
flush_dcache is not declared in the common.h API, flush_dcache_range however is Signed-off-by: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi> Cc: Ben Warren <biggerbadderben@gmail.com> Cc: Thomas Chou <thomas@wytron.com.tw> Acked-by: Thomas Chou <thomas@wytron.com.tw>
2012-03-30net/ethoc: use flush_dcache_range instead of flush_dcacheStefan Kristiansson
2012-03-30Merge branch 'agust@denx.de' of git://git.denx.de/u-boot-stagingWolfgang Denk
* 'agust@denx.de' of git://git.denx.de/u-boot-staging: lzma: fix printf warnings Remove CONFIG_SYS_EXTBDINFO from snapper9260.h cmd_pxe.c: fix strict-aliasing warnings net: smc91111: use mdelay() doc: Fix some typos in different files disk/part.c: Fix device enumeration through API mkenvimage: Really set the redundant byte when applicable mkenvimage: Don't try to detect comments in the input file mkenvimage: Use mmap() when reading from a regular file mkenvimage: Read/Write from/to stdin/out by default or if the filename is "-" mkenvimage: More error handling mkenvimage: Correct an include and add a missing one mkenvimage: correct and clarify comments and error messages MAKEALL: display SPL size if present ARMV7/Vexpress: add missing get_ticks() and get_tbclk() mkenvimage: fix usage message cmd_fat: add FAT write command fs/fat/fat_write.c: Fix GCC 4.6 warnings FAT write: Fix compile errors
2012-03-29net: fec_mxc: allow use with cache enabledEric Nelson
Ensure that transmit and receive buffers are cache-line aligned. Invalidate cache for each packet as received, update receive buffer descriptors one cache line at a time, flush cache before transmitting. Original patch by Marek: http://lists.denx.de/pipermail/u-boot/2012-February/117695.html Signed-off-by: Eric Nelson <eric.nelson at boundarydevices.com> Acked-by: Marek Vasut <marex@denx.de> Tested-by: Marek Vasut <marex@denx.de>
2012-03-28net: calxedaxgmac: fix build due to missing __aligned definitionRob Herring
Include linux/compiler.h to fix build error due to missing __aligned definition. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-03-27net: smc91111: use mdelay()Mike Frysinger
We've already got a mdelay() func in common code, so use that instead. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-03-18net/miiphy/serial: drop duplicate "NAMESIZE" defineMike Frysinger
A few subsystems are using the same define "NAMESIZE". This has been working so far because they define it to the same number. However, I want to change the size of eth_device's NAMESIZE, so rather than tweak the define names, simply drop references to it. Almost no one does, and the handful that do can easily be changed to a sizeof(). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-03-08net: sh_eth: Remove unnecessary returnNobuhiro Iwamatsu
2012-03-08net: sh_eth: Collect up EDMR_INIT_CNT to TIMEOUT_CNTNobuhiro Iwamatsu
EDMR_INIT_CNT holds the check count of initialization. Since there were more same values (1000), this collected as TIMEOUT_CNT. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-03-08net: sh_eth: Remove SH_ETH_PHY_DELAYNobuhiro Iwamatsu
SH_ETH_PHY_DELAY is not used. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-03-08sh: sh_eth: Add support SH7724Nobuhiro Iwamatsu
2012-02-27net: phy: make board_phy_config responsible for calling drv->configTroy Kisky
Boards may have things they want done before or after normal phy config. Letting the boards call drv->config allows them more flexibilty. Boards affected by this change are corenet_ds and mpc8544ds. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com> Acked-by: Dirk Behme <dirk.behme@de.bosch.com>
2012-02-27net: phy: add support for Micrel's KSZ9021Troy Kisky
Add the gigabit phy KSZ9021. Also, add function ksz9021_phy_extended_write /_read for access to the phys extended registers. The environment variable "disable_giga" can be used to disable 1000baseTx. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com> Acked-by: Dirk Behme <dirk.behme@de.bosch.com>
2012-02-27net: fec_mxc: add PHYLIB supportTroy Kisky
Surround non PHYLIB routines miiphy_restart_aneg and miiphy_wait_aneg with ifndef CONFIG_PHYLIB. When later PHYLIB is required it is easy to delete the non-PHYLIB code. This separation idea came from Andy Fleming. fec_miiphy_read, and fec_miiphy_write changed to fec_phy_read, and fec_phy_write with argument changes. Deprecated miiphy_register is no longer used. Both old and new PHYLIB code now use mdio_register. Cleanup some debug prints. Inline function fec_miiphy_fec_to_eth is no longer necessary. Moved to the single call location. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2012-02-27net: fec_mxc: add 1000 Mbps selectionTroy Kisky
Define FEC_QUIRK_ENET_MAC and add to arch-mx6/imx-regs.h Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com> Acked-by: Dirk Behme <dirk.behme@de.bosch.com>
2012-01-16net: imx: Add multi-FEC support for imx_get_mac_from_fuseFabio Estevam
Add multi-FEC support for imx_get_mac_from_fuse by passing dev_id as a parameter. This feature is important on mx28 SoC for example that has two FEC ports. Cc: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2012-01-16fec: add the i.mx6q enet driver supportJason Liu
Cc: Stefano Babic <sbabic@denx.de> Signed-off-by: Jason Liu <jason.hui@linaro.org> Acked-by: Stefano Babic <sbabic@denx.de>
2012-01-05net: add Calxeda xgmac driverRob Herring
This adds ethernet driver for Calxeda xgmac found on Highbank SOC. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Fix: WARNING: __aligned(size) is preferred over __attribute__((aligned(size))) Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-12-23Merge branch 'next' of ../nextWolfgang Denk
* 'next' of ../next: mkenvimage: Add version info switch (-V) mkenvimage: Fix getopt() error handling mkenvimage: Fix some typos phy: add Micrel KS8721BL phy definition net: introduce per device index mvgbe: remove setting of ethaddr within the driver x86: Add support for specifying an initrd with the zboot command x86: Refactor the zboot innards so they can be reused with a vboot image x86: Add infrastructure to extract an e820 table from the coreboot tables x86: Add support for booting Linux using the 32 bit boot protocol x86: Clean up the x86 zimage code in preparation to extend it x86: Import code from coreboot's libpayload to parse the coreboot table x86: Initial commit for running as a coreboot payload CHECKPATCH: ./board/esd/hh405/logo_320_240_8bpp.c CHECKPATCH: ./board/esd/hh405/logo_1024_768_8bpp.c CHECKPATCH: ./board/esd/hh405/logo_320_240_4bpp.c CHECKPATCH: ./board/esd/hh405/logo_640_480_24bpp.c CHECKPATCH: ./board/esd/apc405/logo_640_480_24bpp.c CHECKPATCH: ./board/esd/voh405/logo_320_240_4bpp.c CHECKPATCH: ./board/esd/voh405/logo_640_480_24bpp.c CHECKPATCH: ./board/esd/hh405/fpgadata.c CHECKPATCH: ./board/esd/pci405/fpgadata.c CHECKPATCH: ./board/esd/tasreg/fpgadata.c CHECKPATCH: ./board/esd/apc405/fpgadata.c CHECKPATCH: ./board/esd/voh405/fpgadata.c CHECKPATCH: ./board/esd/ash405/fpgadata.c CHECKPATCH: ./board/esd/dasa_sim/fpgadata.c CHECKPATCH: ./board/esd/ar405/fpgadata_xl30.c CHECKPATCH: ./board/esd/ar405/fpgadata.c CHECKPATCH: ./board/esd/plu405/fpgadata.c CHECKPATCH: ./board/esd/wuh405/fpgadata.c CHECKPATCH: ./board/esd/cpci405/fpgadata_cpci405.c CHECKPATCH: ./board/esd/cpci405/fpgadata_cpci405ab.c CHECKPATCH: ./board/esd/cpci405/fpgadata_cpci4052.c CHECKPATCH: ./board/esd/canbt/fpgadata.c CHECKPATCH: ./board/esd/du405/fpgadata.c CHECKPATCH: ./board/esd/cpciiser4/fpgadata.c CHECKPATCH: ./board/dave/PPChameleonEVB/fpgadata.c avr32:mmu.c: fix printf() length modifier fat.c: fix printf() length modifier cmd_sf.c: fix printf() length modifier Make printf and vprintf safe from buffer overruns vsprintf: Move function documentation into header file Add safe vsnprintf and snprintf library functions Move vsprintf functions into their own header Conflicts: tools/mkenvimage.c Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-12-20phy: add Micrel KS8721BL phy definitionVladimir Zapolskiy
This adds support for the Micrel KS8721BL/SL PHY. The definition is taken from the correspondent datasheet. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2011-12-20drivers/net/e1000.c: Fix GCC 4.6 build warningsAnatolij Gustschin
Fix: e1000.c: In function 'e1000_read_mac_addr': e1000.c:1149:2: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing] e1000.c:1149:2: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing] Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Kyle Moffett <Kyle.D.Moffett@boeing.com> Acked-by: Kyle Moffett <Kyle.D.Moffett@boeing.com>
2011-12-20drivers/net/e1000_spi.c: Fix build warningsAnatolij Gustschin
Fix: e1000_spi.c: In function 'spi_free_slave': e1000_spi.c:115: warning: unused variable 'hw' e1000_spi.c: In function 'do_e1000_spi': e1000_spi.c:472: warning: 'checksum' may be used uninitialized in this function e1000_spi.c:472: note: 'checksum' was declared here Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Kyle Moffett <Kyle.D.Moffett@boeing.com> Acked-by: Kyle Moffett <Kyle.D.Moffett@boeing.com>
2011-12-20mvgbe: remove setting of ethaddr within the driverMichael Walle
A network driver should not touch the environment at all. This patch fixes this behaviour by removing the code for setting a default/randomized MAC address. Signed-off-by: Michael Walle <michael@walle.cc> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Prafulla Wadaskar <prafulla@marvell.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Valentin Longchamp <valentin.longchamp@keymile.com> Cc: Eric Cooper <ecc@cmu.edu> Cc: Jason Cooper <u-boot@lakedaemon.net> Cc: Siddarth Gore <gores@marvell.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Simon Guinot <simon.guinot@sequanux.org> Acked-by: Prafulla Wadaskar <prafulla@marvell.com>
2011-12-19Coding Style cleanupWolfgang Denk
Fix trailing white space, indentation by spaces instead of TABs, excessive blank lines, trailing blank lines. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-12-10drivers/net/at91_emac.c: Fix GCC 4.6 build warningsWolfgang Denk
Fix: at91_emac.c: In function 'at91emac_phy_init': at91_emac.c:244:20: warning: variable 'duplex' set but not used [-Wunused-but-set-variable] at91_emac.c:244:13: warning: variable 'speed' set but not used [-Wunused-but-set-variable] Use new debug_cond() to fix these warnings. In the result, anumber of inconsistent printf() formats are detected: at91_emac.c: In function 'at91emac_read': at91_emac.c:147:2: warning: format '%x' expects argument of type 'unsigned int', but argument 2 has type 'struct at91_emac_t *' [-Wformat] at91_emac.c: In function 'at91emac_write': at91_emac.c:157:2: warning: format '%x' expects argument of type 'unsigned int', but argument 2 has type 'struct at91_emac_t *' [-Wformat] at91_emac.c:157:2: warning: format '%x' expects argument of type 'unsigned int', but argument 4 has type 'short unsigned int *' [-Wformat] at91_emac.c: In function 'at91emac_recv': at91_emac.c:451:3: warning: format '%d' expects argument of type 'int', but argument 2 has type 'long unsigned int' [-Wformat] at91_emac.c:451:3: warning: format '%x' expects argument of type 'unsigned int', but argument 4 has type 'long unsigned int' [-Wformat] Fix these, too. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Jens Scharsig <js_at_ng@scharsoft.de> Cc: Andreas Bießmann <andreas.devel@gmail.com> Cc: Reinhard Meyer <u-boot@emk-elektronik.de>
2011-12-10drivers/net/ne2000_base.c: Fix GCC 4.6 build warningsWolfgang Denk
Fix: ne2000_base.c: In function 'dp83902a_send': ne2000_base.c:282:7: warning: variable 'tmp' set but not used [-Wunused-but-set-variable] ne2000_base.c: In function 'dp83902a_RxEvent': ne2000_base.c:376:5: warning: variable 'rsr' set but not used [-Wunused-but-set-variable] ne2000_base.c: In function 'dp83902a_TxEvent': ne2000_base.c:513:5: warning: variable 'tsr' set but not used [-Wunused-but-set-variable] ne2000_base.c: In function 'dp83902a_ClearCounters': ne2000_base.c:550:17: warning: variable 'cnt3' set but not used [-Wunused-but-set-variable] ne2000_base.c:550:11: warning: variable 'cnt2' set but not used [-Wunused-but-set-variable] ne2000_base.c:550:5: warning: variable 'cnt1' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-12-08ne2000: Convert to new net-multi model, fixes build of three boardsBernhard Kaindl
This fixes the build of the two sh boards shmin and r7780mp and qemu-mips which currently fail to build due to dropped pre-CONFIG_NET_MULTI code. This v2 patch minimizes the number of lines in the diff for easy review and to eliminate any possible accidential changes resulting from moving lines of code in the file. This also makes the register function very easy. Any cleanups and improvements are intentionally deferred to follow-up patches to keep this patch as simple and as easy to review as possible. A new driver register function, ne2k_register() calls the existing one-time setup part of the old init function and calls eth_register(). Changes to shmin, r7780mp and qemu-mips: - Call the new ne2k_register() from board_eth_init() of the boards. - Tested using qemu-mips board, - Tested the two renesas / sh boards r7780mp and shmin to compile again, and should work. checkpatch-clean when "--ignore VOLATILE" is added to .checkpatch.conf, and no warnings introduced in none of the three boards using this driver. Signed-off-by: Bernhard Kaindl <bernhard.kaindl@gmx.net>
2011-12-08drivers/net/inca-ip_sw.c: Fix GCC 4.6 build warningWolfgang Denk
Fix: inca-ip_sw.c: In function 'inca_switch_init': inca-ip_sw.c:210:6: warning: variable 'v' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-12-06ARM: davici_emac: Fix condition for number of phy detectsPrabhakar Lad
Fix the condition for number of phys in davinci_eth_phy_detect() function. CONFIG_SYS_DAVINCI_EMAC_PHY_COUNT indicates number of phys. From this commit id dc02badab480563b0bf9d3908046ea9d6b22ae63 davinci emac initilazed one less than the number of phy count. Signed-off-by: Prabhakar Lad <prabhakar.csengg@gmail.com> Acked-by: Heiko Schocher <hs@denx.de>
2011-12-06davinci_emac: hardcode 100Mbps for AM35xx and RMIIIlya Yanok
For some reason code setting the speed based on the PHY feedback causes troubles on AM3517 so hardcode 100Mbps for now. Signed-off-by: Ilya Yanok <yanok@emcraft.com>
2011-12-06davinci_emac: fix for running with dcache enabledIlya Yanok
DaVinci EMAC is present on TI AM35xx SoCs (ARMv7) which run with D-Cache enabled by default. So we have to take care and flush/invalidate the cache before/after the DMA operations. Please note that the receive buffer alignment to 32 byte boundary comes from the old driver version I don't know if it is really needed or alignment to cache line size is enough. Signed-off-by: Ilya Yanok <yanok@emcraft.com>
2011-12-06davinci_emac: conditionally compile specific PHY supportIlya Yanok
2011-12-06davinci_emac: use internal addresses in buffer descriptorsIlya Yanok
On AM35xx CPPI RAM had different addresses when accessed from the CPU and from the EMAC. We need to account this to deal with the buffer descriptors correctly. Signed-off-by: Ilya Yanok <yanok@emcraft.com>
2011-12-06davinci_emac: move arch-independent defines to separate headerIlya Yanok
DaVinci EMAC is found not only on DaVinci SoCs but on some OMAP3 SoCs also. This patch moves common defines from arch-davinci/emac_defs.h to drivers/net/davinci_emac.h DaVinci specific PHY drivers hacked to include the new header. We might want to switch to phylib in future. Signed-off-by: Ilya Yanok <yanok@emcraft.com>
2011-12-06PXA: Rename CONFIG_PXA2[57]X to CONFIG_CPU_PXA2[57]XMarek Vasut
2011-12-06net: Armada100: Fix compilation warningsAjay Bhargav
This patch fix compilation warnings for Armada100 FEC driver Ref: warning: dereferencing type-punned pointer will break strict-aliasing rules Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com> Acked-by: Anatolij Gustschin <agust@denx.de>
2011-12-05phy: Add support for SMSC LAN87xx PHYsNobuhiro Iwamatsu
This adds support for the SMSC LAN87xx PHYs. Following PHYs can be used by set CONFIG_PHY_SMSC to config. - SMSC LAN8700 - SMSC LAN8710/LAN8720 - SMSC LAN8710/LAN8720 A setup of PHY was copied from linux kenrel. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Fixed white space errors; modified commit message a bit. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-12-05drivers/net/mvgbe.c: Fix GCC 4.6 warningsAnatolij Gustschin
Fix: mvgbe.c: In function 'mvgbe_send': mvgbe.c:555:2: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing] mvgbe.c: In function 'mvgbe_recv': mvgbe.c:640:2: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing] Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Acked-By: Prafulla Wadaskar <prafulla@marvell.com>
2011-12-05Phy/Marvell: Rewrite the MV88E1111 phy config function based on kernel codeZang Roy-R61911
The original m88e1111s_config() does not do the SGMII mode initialization and is buggy. Rewrite the function according to 3.0.6 kernel function m88e1111_config_init() in drivers/net/phy/marvell.c Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Acked-by: Andy Fleming <afleming@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org>
2011-12-02net: sh_eth: use miiphybb instead of own mii functionsYoshihiro Shimoda
The sh_eth driver had an own mii functions. However the function didn't support the gigabit PHY. The U-Boot has the general phy driver and miiphybb driver, and they already support it. So this patch removes the own functions and uses the phy driver. Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
