Instead of directly calling the low-level invalidate_dcache_range() and
flush_cache() functions, provide thin wrappers that take into account
alignment requirements.
While at it, fix a case where the cache was flushed but should have been
invalidated, two cases where the buffer data was flushed instead of the
descriptor and a missing cache invalidation before reading the packet
data that the NIC just wrote to memory.
Signed-off-by: Thierry Reding <treding@nvidia.com>
Patch: 276474
Added d-cache support for zynq_gem.c,
Observed a difference of +0.8 MiB/s when downloading
a file of size of 3007944Bytes.
With d-cache OFF:
Filename 'uImage'.
Load address: 0x800
Loading: #################################################################
1.3 MiB/s
done
Bytes transferred = 3007944 (2de5c8 hex)
With d-cache ON:
Filename 'uImage'.
Load address: 0x800
2.1 MiB/s
done
Changes on zynq_gem for d-cache support:
- Tx and Rx buffers are cache-aligned
- Updated logic for invalidating Rx buffers and flushing Tx buffers.
- Tx and Rx BD's are allocated from non-cacheable region.
(When BDs are cached, we don't see a consistent link)
- Use TX BD status intead of txsr status checks.
Signed-off-by: Srikanth Thokala <sthokal@xilinx.com>
Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
Signed-off-by: David Dueck <davidcdueck@googlemail.com>
The current code incorrectly detects gigabit capabilities for some
100Mbit/s phys. (lan8720a)
When an unprogrammed EEPROM is attached to a dm9000, the dm9000 will
come up with a invalid MAC address of ff:ff:ff:ff:ff:ff. Add code that
gets enabled if CONFIG_RANDOM_MACADDR is enabled that generates a random
(and valid) locally administered MAC address that allows the system to
network boot until a real MAC address can be configured.
Signed-off-by: Andrew Ruder <andrew.ruder@elecsyscorp.com>
The e1000 driver expects to always have some kind of non-volatile memory
attached directly to the ethernet controller chip. This means that I would
have to add an additional separate flash chip to my custom board just to
store essentially the MAC address. Since I don't want to do that, this patch
introduces a new config option CONFIG_E1000_NO_NVM. If defined it disables
all accesses to the NVM. I have tested the patch with a 82574 controller.
Signed-off-by: Rojhalat Ibrahim <imr@rtschenk.de>
The masks were ignoring the last 4 bits which didn't allow detection differences
between the ar8031 and ar8035.
Signed-off-by: Jon Nettleton <jon.nettleton@gmail.com>
Patch: 288018
The both AR8031 and AR8035 belong to Atheros 803x serial PHY.
So the phy id mask of AR8031 is the same to the phy id mask
of AR8035. The right mask value is 0x4fffff.
This patch has been tested on the P1010 and P1023.
Signed-off-by: Chunhe Lan <Chunhe.Lan@freescale.com>
Cc: Joe Hershberger <joe.hershberger@gmail.com>
Patch: 287748
Fix the 32-bit memory access that is not "endianess safe",
i.e. not giving the desired byte layout for LE cpus:
tempval = *((uint *) (tmpbuf + 4)), where 'char tmpbuf[]'.
Free the stack from rendundant local vars:
tmpbuf[] and i.
Use a portable type (u32) for the 32bit tsec register value
holder: tempval.
Signed-off-by: Claudiu Manoil <claudiu.manoil@freescale.com>
Use cross arch portable u32 instead of uint for the
tsec registers. Remove the typedefs for the register
struct definitions in the process. Fix long lines.
Currently, the buffer descriptor (BD) fields cannot be
correctly accessed by a little endian processor. This
patch fixes the issue by making the access of BDs to be
portable among different cpu architectures.
Use portable data types for the Rx/Tx buffer descriptor
fields. Use portable I/O accessors to insure that the
big endian BDs are correctly accessed by little endian
cpus too, and to insure proper sync with the H/W.
Removed the redundant RTXBD "volatile" type, as proper
synchronization around BD data accesses is provided by
the I/O accessors now.
The "sparse" tool was also used to verify the correctness
of these changes.
Cc: Scott Wood <scottwood@freescale.com>
Fix bufPtr and the rxIdx/ txIdx occurrences to
solve the related checkpatch warnings for the
coming patches.
Add the __iomem address space marker for the tsec pointers
to struct tsec_mii_mng memory mapped register regions.
This solves the sparse warnings for mixig normal pointers with
__iomem pointers for tsec. E.g.:
fsl_mdio.c:34:19: warning: incorrect type in argument 1 (different
address spaces)
fsl_mdio.c:34:19: expected unsigned int volatile [noderef]
<asn:2>*addr
fsl_mdio.c:34:19: got unsigned int *<noident>
tsec.c:91:35: warning: incorrect type in argument 1 (different address
spaces)
tsec.c:91:35: expected struct tsec_mii_mng *phyregs
tsec.c:91:35: got struct tsec_mii_mng [noderef] <asn:2>*phyregs_sgmii
tsec.c:680:19: warning: incorrect type in assignment (different address
spaces)
tsec.c:680:19: expected struct tsec_mii_mng *regs
tsec.c:680:19: got struct tsec_mii_mng [noderef] <asn:2>*<noident>
Remove tsec_t typedef. Define macros as getters of
tsec and mdio register memory regions, for consistent
initialization of various 'regs' fields and also to
manage overly long initialization lines.
Use the __iomem address space marker to address sparse
warnings in tsec.c where IO accessors are used, like:
tsec.c:394:19: warning: incorrect type in argument 1 (different
address spaces)
tsec.c:394:19: expected unsigned int volatile [noderef]
<asn:2>*addr
tsec.c:394:19: got unsigned int *<noident>
with __iomem pointers for tsec.
Access to privlist[1] (hardcoded referece to the 2nd tsec's
priv area) is neither correct nor does it make sense in the
current context. Each tsec dev has access to its own priv
instance only, and hence to its own set of group address
registers (GADDR) to filter multicast addresses.
This fix leads to removal of the unused (faulty) privlist[]
and related global static vars. Note that mcast() can be
called only after eth_device allocation and init, and hence
after priv area allocation, so dev->priv is correctly
initialized upon mcast() call.
Patch: 278990
There are several implementation issues for tsec_mcast_addr()
addressed by this patch:
* unmanaged, not portable r/w access to registers; fixed with
setbits_be32()/ clrbits_be32()
* use of volatile pointers
* unnecessary forced cast to u8 for the ether_crc() result
* removed redundant parens
* corrected some comment slips
Patch: 279000
This fixes the following compiler warnings when activating
CONFIG_MCAST_TFTP:
tsec.c: In function 'tsec_mcast_addr':
tsec.c:130:2: warning: passing argument 2 of 'ether_crc' makes pointer
from integer without a cast [enabled by default]
In file included from /work/u-boot-net/include/common.h:874:0,
from tsec.c:15:
/work/u-boot-net/include/net.h:189:5: note: expected 'const unsigned
char *' but argument is of type 'u8'
tsec.c: In function 'tsec_initialize':
tsec.c:646:13: warning: assignment from incompatible pointer type
eth.c: In function 'eth_mcast_join':
eth.c:358:2: warning: passing argument 2 of 'eth_current->mcast' makes
integer from pointer without a cast [enabled by default]
eth.c:358:2: note: expected 'u32' but argument is of type 'u8 *'
In the eth_mcast_join() implementation, eth_current->mcast()
takes a u8 pointer to the multicast mac address and not a ip
address value as implied by its prototype.
Fix parameter type mismatch for tsec_macst_addr() (tsec.c):
ether_crc() takes a u8 pointer not a u8 value.
mcast() is given a u8 pointer to the multicats mac address.
Update parameter type for the rest of mcast() instances.
Patch: 278989
It's important that buffer descriptors are aligned in accordance to GMAC
data bus width (32/64/128-bit). It's safe to align to 128-bit (16-bytes)
for every bus width type.
If buffer descriptor is improperly aligned GMAC discards lower bits of
provided address and as a result reads from improper location that
doesn't match expected fields.
Commit ef76025a99247cdb8f927a2c9f15400678dfb599 "net: Multiple
updates/enhancements to designware.c" introduced another structure
member "link_printed" right before buffer descriptors while "padding"
member was left untouched. This together with alignment of structure
itself to 16-byte boundary forces buffer descriptoprs always to be
4-byte aligned that causes driver complete disfunction if GMAC bus width
is 64 or 128-bit.
Proposed change makes sure all buffer descriptors are 16-byte (128-bit)
aligned.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Patch: 277902
"bus mode" register contains lots of fields and some of them don't
expect to be written with 0 (zero). So since we're only interested in
resetting MAC (which is done with setting the least significant bit of
this register with "0") I believe it's better to modify only 1 bit of
the register.
Acked-by: Vipin Kumar <vipin.kumar@st.com>
Patch: 277864
R8A7791 has the same sh-ether IP core as other SH/rmobile.
This patch adds support of R8A7791.
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
CC: Joe Hershberger <joe.hershberger@gmail.com>
AR8035 driver will be never applied because of wrong mask for
AR8031 driver. Fix this.
Reported-by: Pavel Nakonechny <pavel.nakonechny@skitlab.ru>
Cc: Andy Fleming <afleming@freescale.com>
Patch: 276944
This chip is compatible with other RTL8168 chips and can be found on the
NVIDIA Cardhu and Beaver boards.
Patch: 276475
currticks() is defined as get_timer(0), which returns an unsigned long,
so use %lu instead of %d to print the result.
Patch: 276473
detected
The 'get_phy_driver' code in 'drivers/net/phy/phy.c' uses the following
method to determine which driver is to be loaded for a particular PHY
module:
list_for_each(entry, &phy_drivers) {
drv = list_entry(entry, struct phy_driver, list);
if ((drv->uid & drv->mask) == (phy_id & drv->mask))
return drv;
This means that a drv->mask of 0xfffff0 will return incorrect phy driver
for the logic above, even if the drv->uid is anything other than
something ending with a 0x0.
For e.g. if the RTL8211E drv->uid is 0x1cc915 and drv->mask is 0xffffff
and the RTL8211B drv->uid is 0x1cc910 and drv->mask is 0xffffff0, then
the phy driver selected will always be RTL8211B even though the
underlying phy connected on the board is a 8211E module.
This patch fixes this issue.
Signed-off-by: Bhupesh Sharma <bhupesh.sharma@freescale.com>
This patch adds support for VSC8514 PHY module which can be
found on Freescale's T1040RDB boards.
Signed-off-by: Arpit Goel <B44344@freescale.com>
R8A7790 has the same sh-ether IP core as other SH/rmobile.
This patch adds support of R8A7790.
Signed-off-by: Hisashi Nakamura <hisashi.nakamura.ak@renesas.com>
The sh-eth of rmobile needs to use invalidate_cache* function.
This patch adds invalidate_cache* function.
Patch: 268948
sh-eth can change the alignment size of a packet descriptor according to BUS
size. This patch adds this function.
The cache API of SH was changed from dcache_wback_range to flush_dcache_range.
sh-eth uses dcache_wback_range. This patch changes to flush_dcache_range.
Avoid a recently introduced unused variable warning for boards that
use mvgbe but not phylib.
Signed-off-by: Sascha Silbe <t-uboot@infra-silbe.de>
Patch: 266334
As AR8031 and AR8033 have same PHY ID 0x4dd074, they use the
common driver. Currently AR8031_driver didn't work for AR8033,
hence updated it to have it work on AR8031/AR8033.
Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com>
CONFIG_IXP4XX_NPE is defined only for CPU ixp.
It is not necessary to filter by CPU ixp.
CONFIG_FMAN_ENET is defined only for CPU mpc85xx.
We do not need to filter by CPU mpc85xx.
T1040 Soc has four personalities:
-T1040 (4 cores with L2 switch)
-T1042:Reduced personality of T1040 without L2 switch
-T1020:Reduced personality of T1040 with less cores(2 cores)
-T1022:Reduced personality of T1040 with 2 cores and without L2 switch
Update defines in arch/powerpc header files, Makefiles and in
driver/net/fm/Makefile to support all T1040 personalities
Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com>
Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
[York Sun: fixed Makefiles]
Acked-by: York Sun <yorksun@freescale.com>
The MPC824x processors have long reached EOL, and the PN62 board has
not seen any board-specific updates for more than a decade. It is now
causing build issues. Instead of wasting time on things nobody is
interested in any more, we rather drop this board.
Cc: Wolfgang Grandegger <wg@grandegger.com>
cc: Tom Rini <trini@ti.com>
arch/arm/cpu/arm926ejs/mxs/Makefile
board/compulab/cm_t35/Makefile
board/corscience/tricorder/Makefile
board/ppcag/bg0900/Makefile
drivers/bootcount/Makefile
include/configs/omap4_common.h
include/configs/pdnb3.h
Makefile conflicts are due to additions/removals of
object files on the ARM branch vs KBuild introduction
on the main branch. Resolution consists in adjusting
the list of object files in the main branch version.
This also applies to two files which are not listed
as conflicting but had to be modified:
board/compulab/common/Makefile
board/udoo/Makefile
include/configs/omap4_common.h conflicts are due to
the OMAP4 conversion to ti_armv7_common.h on the ARM
side, and CONFIG_SYS_HZ removal on the main side.
Resolution is to convert as this icludes removal of
CONFIG_SYS_HZ.
include/configs/pdnb3.h is due to a removal on ARM side.
Trivial resolution is to remove the file.
Note: 'git show' will also list two files just because
they are new:
include/configs/am335x_igep0033.h
include/configs/omap3_igep00x0.h
On relatively slow boards (such as the MIPS Malta with an FPGA core
card) it can be extremely common for transmits to underflow - to the
point where it appears they simply do not work at all. Setting the
NOUFLO bit causes the ethernet controller to not begin transmission on
the wire until a transmit start point is reached. Setting that transmit
start point to the full packet will cause the controller to only
transmit the packet once it has buffered it entirely thus preventing any
transmit underflows from occuring and allowing the controller to
function on slower boards.
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
Ensure that the view of memory from the CPU & the ethernet controller is
coherent at the various points where they exchange data. This prevents
stale data from being transmitted or received, and prevents the driver
from getting stuck waiting for the ethernet controller to update
descriptors when in reality it has but the old values are being read
from cache.
This should cause no change to the generated code, but is semantically
correct.
Fix up the code to match Documentation/CodingStyle. This is mostly
removing extraneous spaces.
No functional change is intended.
Netconsole loses the second character when used as input by
either setenv stdin nc or setenv stdin serial,nc if using CONSOLE_CONSOLE_MUX
Before a nc_send_packet() to echo the input, a check is done to see if
nc_ether is valid. If its not, it waits for an arp request and then sends
the packet (which contains the first character of line to be displayed as
output). As part of reaping the arp request, the second character is consumed.
We protect this by making the call to NetLoop(NETCONS) between
input_recursion.
Signed-off-by: Suriyan Ramasami <suriyan.r@gmail.com>
Get DMA bus width from design config register
Signed-off-by: Bo Shen <voice.shen@atmel.com>
This can be useful if one wants to disable an interface in u-boot
because u-boot should not manage it but then later reenable it for FDT
fixing or if the kernel uses this interface.
Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
[York Sun: fix conflict in fm_eth.h]
T1040QDS is a high-performance computing evaluation, development and
test platform supporting the T1040 QorIQ Power Architecture™ processor.
T1040QDS board Overview
- Four e5500 cores, each with a private 256 KB L2 cache
- 256 KB shared L3 CoreNet platform cache (CPC)
- Interconnect CoreNet platform
- 32-/64-bit DDR3L/DDR4 SDRAM memory controller with ECC and interleaving
support
- Data Path Acceleration Architecture (DPAA) incorporating acceleration
for the following functions:
- Packet parsing, classification, and distribution
- Queue management for scheduling, packet sequencing, and congestion
management
- Cryptography Acceleration
- RegEx Pattern Matching Acceleration
- IEEE Std 1588 support
- Hardware buffer management for buffer allocation and deallocation
- Ethernet interfaces
- Integrated 8-port Gigabit Ethernet switch
- Four 1 Gbps Ethernet controllers
- SERDES Connections, 8 lanes supporting:
— PCI Express: supporting Gen 1 and Gen 2;
— SGMII
— QSGMII
— SATA 2.0
— Aurora debug with dedicated connectors
- DDR Controller 32-/64-bit DDR3L/DDR4 SDRAM memory controller with ECC and
Interleaving
-IFC/Local Bus
- NAND flash: 8-bit, async, up to 2GB.
- NOR: 8-bit or 16-bit, non-multiplexed, up to 512MB
- GASIC: Simple (minimal) target within Qixis FPGA
- PromJET rapid memory download support
- Ethernet
- Two on-board RGMII 10/100/1G ethernet ports.
- PHY #0 remains powered up during deep-sleep
- QIXIS System Logic FPGA
- Clocks
- System and DDR clock (SYSCLK, “DDRCLK”)
- SERDES clocks
- Power Supplies
- Video
- DIU supports video at up to 1280x1024x32bpp
- USB
- Supports two USB 2.0 ports with integrated PHYs
— Two type A ports with 5V@1.5A per port.
— Second port can be converted to OTG mini-AB
- SDHC
- SDHC port connects directly to an adapter card slot, featuring:
- Supporting SD slots for: SD, SDHC (1x, 4x, 8x) and/or MMC
— Supporting eMMC memory devices
- SPI
- On-board support of 3 different devices and sizes
- Other IO
- Two Serial ports
- ProfiBus port
- Four I2C ports
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
[York Sun: fix conflict in boards.cfg]
Acked-by-by: York Sun <yorksun@freescale.com>
Fix PHY addresses for QSGMII Riser Card working in
SGMII mode on board P3041/P5020/P4080/P5040/B4860.
QSGMII Riser Card can work in SGMII mode, but
having the different PHY addresses.
So the following steps should be done:
1. Confirm whether QSGMII Riser Card is used.
2. If yes, set the proper PHY address.
Generally, the function is_qsgmii_riser_card() is
for step 1, and set_sgmii_phy() for step 2.
However, there are still some special situations,
take P5040 and B4860 as examples, the PHY addresses
need to be changed when serdes protocol is changed,
so it is necessary to confirm the protocol before
setting PHY addresses.
Signed-off-by: Zhao Qiang <B45475@freescale.com>
