path: root/drivers/net
2009-03-29cs8900 compile fixLadislav Michl
cs8900.c: In function 'eth_init': cs8900.c:164: warning: passing argument 2 of 'eth_getenv_enetaddr' from incompatible pointer type cs8900.c:165: error: invalid operands to binary << cs8900.c:166: error: invalid operands to binary << cs8900.c:167: error: invalid operands to binary << Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-03-22at91: Support for the at91sam9g20 : Atmel 400Mhz ARM 926ej-s SOC.Nicolas Ferre
AT91sam9g20 is an evolution of the at91sam9260 with a faster clock speed. The AT91SAM9G20-EK board is an updated revision of the AT91SAM9260-EK board. It is essentially the same, with a few minor differences. Here is the chip page on Atmel website: http://www.atmel.com/dyn/products/product_card.asp?part_id=4337 Signed-off-by: Justin Waters <justin.waters@timesys.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-03-20lan91c96/smc91111/smc911x: get mac address from environmentMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. Also, do not bother checking the EEPROM if the env is setup. This simplifies the code greatly. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Wolfgang Dnek <wd@denx.de> CC: Ben Warren <biggerbadderben@gmail.com> CC: Rolf Offermanns <rof@sysgo.de> CC: Erik Stahlman <erik@vt.edu> CC: Daris A Nevil <dnevil@snmc.com> CC: Sascha Hauer <s.hauer@pengutronix.de>
2009-03-20sh_eth: get mac address from environmentMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. The sh_eth driver can also be simplified a bit by using enetaddr member of the eth_device structure. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Carlos Munoz <carlos@kenati.com> CC: Ben Warren <biggerbadderben@gmail.com>
2009-03-20cs8900: get mac address from environmentMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. The cs8900 driver also changes slightly in that the hardware is not consulted if the mac address in the env is sane. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Marius Groeger <mgroeger@sysgo.de> CC: Ben Warren <biggerbadderben@gmail.com>
2009-03-20bcm570x: get mac address from environmentMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. Since the address is in the PLM_DEVICE_BLOCK structure already, there is no need to pass the NodeAddress as a second parameter. So drop the second argument to the LM_SetMacAddress() function (and update the tigon3 driver accordingly). Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-03-20drivers/net/: get mac address from environmentMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. The drivers that get converted here: 3c589 4xx_enet dc2114x dm9000x enc28j60 fsl_mcdmafec ks8695eth mcffec rtl8019 rtl8169 s3c4510b_eth xilinx_emac xilinx_emaclite Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com> CC: Rolf Offermanns <rof@sysgo.de> CC: Stefan Roese <sr@denx.de> CC: Sascha Hauer <saschahauer@web.de> CC: TsiChung Liew <Tsi-Chung.Liew@freescale.com> CC: Greg Ungerer <greg.ungerer@opengear.com> CC: Xue Ligong <lgxue@hotmail.com> CC: Masami Komiya <mkomiya@sonare.it> CC: Curt Brune <curt@cucy.com> CC: Michal SIMEK <monstr@monstr.eu>
2009-03-20Blackfin: bfin_mac: force boards to setup the MAC themselvesMike Frysinger
Since the on-chip MAC does not have an eeprom or similar interface, force all Blackfin boards that use this driver to setup the board data with a proper MAC. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-03-20net: sh_eth: Remove sh_eth_reset() from halt functionNobuhiro Iwamatsu
sh_eth_reset is function to reset Ether IP. The MAC address is stored in IP, but it is initialized by this function. OS (e.g. Linux Kernel) can not use this device when initialized. This revises this problem. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com>
2009-03-13MPC5200 FEC MII speed registerJon Smirl
Set a non-zero speed in the MII register so that MII commands will work. Signed-off-by: Jon Smirl <jonsmirl@gmail.com>
2009-03-09tsec: report when there is no vendor specific PHY supportPaul Gortmaker
Commit af1c2b84 added a generic phy support, with an ID of zero and a 32 bit mask; meaning that it will match on any PHY ID. The problem is that there is a test that checked if a matching PHY was found, and if not, it printed the non-matching ID. But since there will always be a match (on the generic PHY, worst case), this test will never trip. In the case of a misconfigured PHY address, or of a PHY that isn't explicitly supported outside of the generic support, you will never see the ID of 0xffffffff, or the ID of the real (but unsupported) chip. It will silently fall through onto the generic support. This change makes that test useful again, and ensures that the selection of generic PHY support doesn't happen without some sort of notice. It also makes it explicitly clear that the generic PHY must be last in the PHY table. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Acked-by: Andy Fleming <afleming@freescale.com>
2009-02-25smc911x: split out useful defines/functions into local headerMike Frysinger
The smc911x driver has a lot of useful defines/functions which can be used by pieces of code (such as example eeprom programmers). Rather than forcing each place to duplicate these defines/functions, split them out of the smdc911x driver into a local header. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Ben Warren <biggerbadderben@gmail.com> CC: Sascha Hauer <s.hauer@pengutronix.de> CC: Guennadi Liakhovetski <lg@denx.de> CC: Magnus Lilja <lilja.magnus@gmail.com> CC: Ben Warren <biggerbadderben@gmail.com>
2009-02-22Added Vitesse VSC8211 definitions to TSEC driverPieter Henning
Added the struct containing PHY settings for the Vitesse VSC8211 phy to the phy_info list in tsec.c Signed-off-by: Pieter Henning <phenning@vastech.co.za> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-02-22Coding Style cleanup; update CHANGELOGWolfgang Denk
2009-02-19Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2009-02-09net: removed board-specific CONFIGs from MPC5xxx FEC driverBen Warren
Added new CONFIG options for the three type of MAC-PHY interconnect and applied them all relevant board config files Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-02-09tsec: Fix a bug in soft-resettingAndy Fleming
SOFT_RESET must be asserted for at least 3 TX clocks. Usually, that's about 30 clock cycles, so it's been mostly working. But we had no guarantee, and at slower bitrates, it's just over a microsecond (over 1000 clock cycles). This enforces a 2 microsecond gap between assertion and deassertion. Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-02-09Fix 100Mbs ethernet operation on sh7763 based boardsSimon Munton
100Mbs ethernet does not work on sh7763 chips due to the wrong value being used in the GECMR register. Following diff fixes the problem Signed-off-by: Simon Munton <simon@nidoran.m5data.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-02-10dnet: driver for Dave DNET ethernet controllerIlya Yanok
Driver for Dave DNET ethernet controller (used on Dave/DENX QongEVB-LITE board). Signed-off-by: Ilya Yanok <yanok@emcraft.com> Acked-by: Ben Warren <biggerbadderben@gmail.com>
2009-02-06Coldfire: mcfmii: Allow non-autonegotiating PHYs to use mii commandRichard Retanubun
Modified mii_init to support boards with PHYs that are not set to autonegotiate, but still want to use u-boot's mii commands to probe the smi bus. Such PHYs will not set the Autonegotiate-done bit. Signed-off-by: Richard Retanubun <RichardRetanubun@RuggedCom.com>
2009-02-02Blackfin: bfin_mac: cleanup pointer/casts for aliasing issuesMike Frysinger
Redo how pointers are managed to get rid of ugly casts and strict pointer aliasing issues that are highlighted by gcc 4.3. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Ben Warren <biggerbadderben@gmail.com>
2009-02-02Blackfin: bfin_mac: convert CONFIG_BFIN_MAC_RMII to CONFIG_RMIIMike Frysinger
No point in having a Blackfin-specific define "CONFIG_BFIN_MAC_RMII" that does exactly the same thing as common "CONFIG_RMII". Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Ben Warren <biggerbadderben@gmail.com>
2009-02-02Blackfin: bfin_mac: use common debug()Mike Frysinger
Rather then defining our own DEBUGF(), just use the common debug(). Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Ben Warren <biggerbadderben@gmail.com>
2009-02-02Blackfin: bfin_mac: respect CONFIG_PHY_{ADDR,CLOCK_FREQ}Mike Frysinger
Rather than having the on-chip MAC hardcoded to phy address 1 and a speed of 2.5mhz, use these as defaults if the board doesn't specify otherwise. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Ben Warren <biggerbadderben@gmail.com>
2009-02-02Blackfin: bfin_mac: cleanup MII/PHY functionsMike Frysinger
Cleanup and rewrite the MII/PHY related functions so that we can reuse the existing common linux/miiphy.h code and hook into the `mii` command. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Ben Warren <biggerbadderben@gmail.com>
2009-02-02Blackfin: bfin_mac: set MDCDIV based on SCLKMike Frysinger
Rather than hardcoding MDCDIV to 24 (which is correct for ~125mhz SCLK), use the real algorithm so it gets set correctly regardless of SCLK. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Ben Warren <biggerbadderben@gmail.com>
2009-02-01Merge branch 'master' of git://git.denx.de/u-boot-netWolfgang Denk
2009-01-28AVR32: macb - Search for PHY idGunnar Rangoy
This patch adds support for searching through available PHY-addresses in the macb-driver. This is needed for the ATEVK1100 evaluation board, where the PHY-address will be initialized to either 1 or 7. This patch adds a config option, CONFIG_MACB_SEARCH_PHY, which when enabled tells the driver to search for the PHY address. Signed-off-by: Gunnar Rangoy <gunnar@rangoy.com> Signed-off-by: Paul Driveklepp <pauldriveklepp@gmail.com> Signed-off-by: Olav Morken <olavmrk@gmail.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-01-28Marvell 88E1118 interrupt fixRon Madrid
This patch adjusts the LED control so that interrupt lines are not reading LEDs and effectively causing indefinite interrupts to the controller. Signed-off-by: Ron Madrid <ron_madrid@sbcglobal.net> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-01-28net: smc911x.c: Add LAN9211 to chip_ids[] arrayStefan Roese
Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-01-28net: Sort Makefile labelsMichal Simek
Signed-off-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-01-28Blackfin: bfin_mac: update port muxingMike Frysinger
Adds support more Blackfin parts and fixes broken muxing for older ones. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-01-27drivers/net/e1000.c: missing terminator for supported devicesStefan Althoefer
Signed-off-by: Stefan Althoefer <stefan.althoefer@web.de>
2009-01-24sh: sh_eth: Change new network APINobuhiro Iwamatsu
sh_eth used old network API. This patch changed new API. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-01-24net: smc911x: Make register read/write functions weakStefan Roese
This patch changes the reg_read/_write to smc911x_reg_read/_write and defines then as weak so that they can be overridden by board specific version. This will be used by the upcoming VCTH board support. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-12-04net: tsec: Fix Marvell 88E1121R phy initAnatolij Gustschin
This patch tries to ensure that phy interrupt pin won't be asserted after booting. We experienced following issues with current 88E1121R phy init: Marvell 88E1121R phy can be hardware-configured to share MDC/MDIO and interrupt pins for both ports P0 and P1 (e.g. as configured on socrates board). Port 0 interrupt pin will be shared by both ports in such configuration. After booting Linux and configuring eth0 interface, port 0 phy interrupts are enabled. After rebooting without proper eth0 interface shutdown port 0 phy interrupts remain enabled so any change on port 0 (link status, etc.) cause assertion of the interrupt. Now booting Linux and configuring eth1 interface will cause permanent phy interrupt storm as the registered phy 1 interrupt handler doesn't acknowledge phy 0 interrupts. This of course should be fixed in Linux driver too. Signed-off-by: Anatolij Gustschin <agust@denx.de> Acked-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-11-09ColdFire: Add mii driver in drivers/netTsiChung Liew
All CF platforms' mii.c are consolidated into one Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-11-09Moved PPC4xx EMAC driver to drivers/netBen Warren
Also changed path in all linker scripts that reference this driver Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Acked-by: Stefan Roese <sr@denx.de>
2008-11-09xilinx_emaclite buffer overrunClive Stubbings
Patch to fix buffer allocation size and alignment. Buffer needs to be u32 aligned and PKTSIZE_ALIGN bytes long. Acked-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-10-21Cleanup: fix "MHz" spellingWolfgang Denk
2008-10-18Merge 'next' branchWolfgang Denk
Conflicts: board/freescale/mpc8536ds/mpc8536ds.c include/configs/mgcoge.h Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-10-15Coding Style cleanup, update CHANGELOG, prepare 2008.10-rc3v2008.10-rc3Wolfgang Denk
2008-10-13AX88180: new gigabit network driverLouis Su
Signed-off-by: Louis Su <louis@asix.com.tw> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-10-13enable 10/100M at VSC8601 at tsec driverAndre Schwarz
Currently VSC8601 doesn't link with 10/100M partners if the EEPROM/Strapping is not set up. Setting the auto-neg register fixes this. Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-10-13net: ne2000: Divided a function of NE2000 driverNobuhiro Iwamatsu
get_prom function was used __attriute__ , but it is not enable. ax88796.o does not do link besides ne2000.o. When ld is carried out, get_prom function of ax88796.c is ignored. This problem is a thing by specifications of ld. I checked and test this patch on SuperH and MIPS. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-16Support for multiple SGMII/TBI interfaces for TSEC ethernetPeter Tyser
Fix TBI PHY accesses to use the proper offset in CPU register space. The previous code would incorrectly access the TBI PHY by reading/writing to CPU register space at the same location as would be used to access external PHYs. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Acked-by: Andy Fleming <afleming@freescale.com>
2008-09-12Merge branch 'master' of /home/wd/git/u-boot/custodiansWolfgang Denk
2008-09-12MPC512x: reduce timeout waiting for Ethernet autonegotiation to 2.5sWolfgang Denk
2008-09-10rename CFG_ENV_IS_NOWHERE in CONFIG_ENV_IS_NOWHEREJean-Christophe PLAGNIOL-VILLARD
