Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
A few subsystems are using the same define "NAMESIZE". This has been
working so far because they define it to the same number. However, I
want to change the size of eth_device's NAMESIZE, so rather than tweak
the define names, simply drop references to it. Almost no one does,
and the handful that do can easily be changed to a sizeof().
EDMR_INIT_CNT holds the check count of initialization.
Since there were more same values (1000), this collected as TIMEOUT_CNT.
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
SH_ETH_PHY_DELAY is not used.
Boards may have things they want done before or after normal phy config.
Letting the boards call drv->config allows them more flexibilty.
Boards affected by this change are corenet_ds and mpc8544ds.
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
Acked-by: Dirk Behme <dirk.behme@de.bosch.com>
Add the gigabit phy KSZ9021.
Also, add function ksz9021_phy_extended_write
/_read for access to the phys extended registers.
The environment variable "disable_giga"
can be used to disable 1000baseTx.
Surround non PHYLIB routines miiphy_restart_aneg
and miiphy_wait_aneg with ifndef CONFIG_PHYLIB.
When later PHYLIB is required it is easy to delete
the non-PHYLIB code. This separation idea
came from Andy Fleming.
fec_miiphy_read, and fec_miiphy_write changed to
fec_phy_read, and fec_phy_write with argument changes.
Deprecated miiphy_register is no longer used. Both
old and new PHYLIB code now use mdio_register.
Cleanup some debug prints.
Inline function fec_miiphy_fec_to_eth is no longer necessary.
Moved to the single call location.
Define FEC_QUIRK_ENET_MAC and add to
arch-mx6/imx-regs.h
Add multi-FEC support for imx_get_mac_from_fuse by passing dev_id as a parameter.
This feature is important on mx28 SoC for example that has two FEC ports.
Cc: Ben Warren <biggerbadderben@gmail.com>
Signed-off-by: Jason Liu <jason.hui@linaro.org>
This adds ethernet driver for Calxeda xgmac found on Highbank SOC.
Fix: WARNING: __aligned(size) is preferred over
__attribute__((aligned(size)))
* 'next' of ../next:
mkenvimage: Add version info switch (-V)
mkenvimage: Fix getopt() error handling
mkenvimage: Fix some typos
phy: add Micrel KS8721BL phy definition
net: introduce per device index
mvgbe: remove setting of ethaddr within the driver
x86: Add support for specifying an initrd with the zboot command
x86: Refactor the zboot innards so they can be reused with a vboot image
x86: Add infrastructure to extract an e820 table from the coreboot tables
x86: Add support for booting Linux using the 32 bit boot protocol
x86: Clean up the x86 zimage code in preparation to extend it
x86: Import code from coreboot's libpayload to parse the coreboot table
x86: Initial commit for running as a coreboot payload
CHECKPATCH: ./board/esd/hh405/logo_320_240_8bpp.c
CHECKPATCH: ./board/esd/hh405/logo_1024_768_8bpp.c
CHECKPATCH: ./board/esd/hh405/logo_320_240_4bpp.c
CHECKPATCH: ./board/esd/hh405/logo_640_480_24bpp.c
CHECKPATCH: ./board/esd/apc405/logo_640_480_24bpp.c
CHECKPATCH: ./board/esd/voh405/logo_320_240_4bpp.c
CHECKPATCH: ./board/esd/voh405/logo_640_480_24bpp.c
CHECKPATCH: ./board/esd/hh405/fpgadata.c
CHECKPATCH: ./board/esd/pci405/fpgadata.c
CHECKPATCH: ./board/esd/tasreg/fpgadata.c
CHECKPATCH: ./board/esd/apc405/fpgadata.c
CHECKPATCH: ./board/esd/voh405/fpgadata.c
CHECKPATCH: ./board/esd/ash405/fpgadata.c
CHECKPATCH: ./board/esd/dasa_sim/fpgadata.c
CHECKPATCH: ./board/esd/ar405/fpgadata_xl30.c
CHECKPATCH: ./board/esd/ar405/fpgadata.c
CHECKPATCH: ./board/esd/plu405/fpgadata.c
CHECKPATCH: ./board/esd/wuh405/fpgadata.c
CHECKPATCH: ./board/esd/cpci405/fpgadata_cpci405.c
CHECKPATCH: ./board/esd/cpci405/fpgadata_cpci405ab.c
CHECKPATCH: ./board/esd/cpci405/fpgadata_cpci4052.c
CHECKPATCH: ./board/esd/canbt/fpgadata.c
CHECKPATCH: ./board/esd/du405/fpgadata.c
CHECKPATCH: ./board/esd/cpciiser4/fpgadata.c
CHECKPATCH: ./board/dave/PPChameleonEVB/fpgadata.c
avr32:mmu.c: fix printf() length modifier
fat.c: fix printf() length modifier
cmd_sf.c: fix printf() length modifier
Make printf and vprintf safe from buffer overruns
vsprintf: Move function documentation into header file
Add safe vsnprintf and snprintf library functions
Move vsprintf functions into their own header
tools/mkenvimage.c
This adds support for the Micrel KS8721BL/SL PHY.
The definition is taken from the correspondent datasheet.
Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
Fix:
e1000.c: In function 'e1000_read_mac_addr':
e1000.c:1149:2: warning: dereferencing type-punned pointer
will break strict-aliasing rules [-Wstrict-aliasing]
Cc: Kyle Moffett <Kyle.D.Moffett@boeing.com>
Acked-by: Kyle Moffett <Kyle.D.Moffett@boeing.com>
Fix:
e1000_spi.c: In function 'spi_free_slave':
e1000_spi.c:115: warning: unused variable 'hw'
e1000_spi.c: In function 'do_e1000_spi':
e1000_spi.c:472: warning: 'checksum' may be used uninitialized in this function
e1000_spi.c:472: note: 'checksum' was declared here
A network driver should not touch the environment at all. This patch fixes
this behaviour by removing the code for setting a default/randomized MAC
address.
Signed-off-by: Michael Walle <michael@walle.cc>
Acked-by: Prafulla Wadaskar <prafulla@marvell.com>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Prafulla Wadaskar <prafulla@marvell.com>
Cc: Valentin Longchamp <valentin.longchamp@keymile.com>
Cc: Eric Cooper <ecc@cmu.edu>
Cc: Jason Cooper <u-boot@lakedaemon.net>
Cc: Siddarth Gore <gores@marvell.com>
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Cc: Simon Guinot <simon.guinot@sequanux.org>
Fix trailing white space, indentation by spaces instead of TABs,
excessive blank lines, trailing blank lines.
Fix:
at91_emac.c: In function 'at91emac_phy_init':
at91_emac.c:244:20: warning: variable 'duplex' set but not used
[-Wunused-but-set-variable]
at91_emac.c:244:13: warning: variable 'speed' set but not used
Use new debug_cond() to fix these warnings. In the result, anumber of
inconsistent printf() formats are detected:
at91_emac.c: In function 'at91emac_read':
at91_emac.c:147:2: warning: format '%x' expects argument of type
'unsigned int', but argument 2 has type 'struct at91_emac_t *'
[-Wformat]
at91_emac.c: In function 'at91emac_write':
at91_emac.c:157:2: warning: format '%x' expects argument of type
[-Wformat]
'unsigned int', but argument 4 has type 'short unsigned int *'
[-Wformat]
at91_emac.c: In function 'at91emac_recv':
at91_emac.c:451:3: warning: format '%d' expects argument of type
'int', but argument 2 has type 'long unsigned int' [-Wformat]
at91_emac.c:451:3: warning: format '%x' expects argument of type
'unsigned int', but argument 4 has type 'long unsigned int' [-Wformat]
Fix these, too.
Cc: Jens Scharsig <js_at_ng@scharsoft.de>
Cc: Andreas Bießmann <andreas.devel@gmail.com>
Cc: Reinhard Meyer <u-boot@emk-elektronik.de>
Fix:
ne2000_base.c: In function 'dp83902a_send':
ne2000_base.c:282:7: warning: variable 'tmp' set but not used
ne2000_base.c: In function 'dp83902a_RxEvent':
ne2000_base.c:376:5: warning: variable 'rsr' set but not used
ne2000_base.c: In function 'dp83902a_TxEvent':
ne2000_base.c:513:5: warning: variable 'tsr' set but not used
ne2000_base.c: In function 'dp83902a_ClearCounters':
ne2000_base.c:550:17: warning: variable 'cnt3' set but not used
ne2000_base.c:550:11: warning: variable 'cnt2' set but not used
ne2000_base.c:550:5: warning: variable 'cnt1' set but not used
This fixes the build of the two sh boards shmin and r7780mp and qemu-mips
which currently fail to build due to dropped pre-CONFIG_NET_MULTI code.
This v2 patch minimizes the number of lines in the diff for easy review
and to eliminate any possible accidential changes resulting from moving
lines of code in the file. This also makes the register function very easy.
Any cleanups and improvements are intentionally deferred to follow-up patches
to keep this patch as simple and as easy to review as possible.
A new driver register function, ne2k_register() calls the existing
one-time setup part of the old init function and calls eth_register().
Changes to shmin, r7780mp and qemu-mips:
- Call the new ne2k_register() from board_eth_init() of the boards.
- Tested using qemu-mips board,
- Tested the two renesas / sh boards r7780mp and shmin to compile again,
and should work.
checkpatch-clean when "--ignore VOLATILE" is added to .checkpatch.conf,
and no warnings introduced in none of the three boards using this driver.
Signed-off-by: Bernhard Kaindl <bernhard.kaindl@gmx.net>
Fix:
inca-ip_sw.c: In function 'inca_switch_init':
inca-ip_sw.c:210:6: warning: variable 'v' set but not used
Fix the condition for number of phys in
davinci_eth_phy_detect() function.
CONFIG_SYS_DAVINCI_EMAC_PHY_COUNT indicates number of
phys. From this commit id dc02badab480563b0bf9d3908046ea9d6b22ae63
davinci emac initilazed one less than the number of phy count.
Signed-off-by: Prabhakar Lad <prabhakar.csengg@gmail.com>
Acked-by: Heiko Schocher <hs@denx.de>
For some reason code setting the speed based on the PHY feedback causes
troubles on AM3517 so hardcode 100Mbps for now.
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
DaVinci EMAC is present on TI AM35xx SoCs (ARMv7) which run with D-Cache
enabled by default. So we have to take care and flush/invalidate the
cache before/after the DMA operations.
Please note that the receive buffer alignment to 32 byte boundary comes
from the old driver version I don't know if it is really needed or
alignment to cache line size is enough.
On AM35xx CPPI RAM had different addresses when accessed from the CPU
and from the EMAC. We need to account this to deal with the buffer
descriptors correctly.
DaVinci EMAC is found not only on DaVinci SoCs but on some OMAP3 SoCs
also. This patch moves common defines from arch-davinci/emac_defs.h to
drivers/net/davinci_emac.h
DaVinci specific PHY drivers hacked to include the new header. We might
want to switch to phylib in future.
This patch fix compilation warnings for Armada100 FEC driver
Ref:
warning: dereferencing type-punned pointer will break
Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com>
Acked-by: Anatolij Gustschin <agust@denx.de>
This adds support for the SMSC LAN87xx PHYs.
Following PHYs can be used by set CONFIG_PHY_SMSC to config.
- SMSC LAN8700
- SMSC LAN8710/LAN8720
A setup of PHY was copied from linux kenrel.
Fixed white space errors; modified commit message a bit.
Fix:
mvgbe.c: In function 'mvgbe_send':
mvgbe.c:555:2: warning: dereferencing type-punned pointer will
mvgbe.c: In function 'mvgbe_recv':
mvgbe.c:640:2: warning: dereferencing type-punned pointer will
Acked-By: Prafulla Wadaskar <prafulla@marvell.com>
The original m88e1111s_config() does not do the SGMII mode
initialization and is buggy. Rewrite the function according to
3.0.6 kernel function m88e1111_config_init() in drivers/net/phy/marvell.c
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
Acked-by: Andy Fleming <afleming@freescale.com>
Cc: Kumar Gala <galak@kernel.crashing.org>
The sh_eth driver had an own mii functions. However the function
didn't support the gigabit PHY. The U-Boot has the general phy driver
and miiphybb driver, and they already support it.
So this patch removes the own functions and uses the phy driver.
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Several macros are used to identify and locate the microcode binary image
that U-boot needs to upload to the QE or Fman. Both the QE and the Fman
use the QE Firmware binary format to package their respective microcode data,
which is why the same macros are used for both. A given SOC will only have
a QE or an Fman, so this is safe.
Unfortunately, the current macro definition and usage has inconsistencies.
For example, CONFIG_SYS_FMAN_FW_ADDR was used to define the address of Fman
firmware in NOR flash, but CONFIG_SYS_QE_FW_IN_NAND contains the address
of NAND. There's no way to know by looking at a variable how it's supposed
to be used.
In the future, the code which uploads QE firmware and Fman firmware will
be merged.
* 'hs@denx.de' of git://git.denx.de/u-boot-staging:
drivers/net/dnet.c: Fix GCC 4.6 warnings
board/xaeniax/flash.c: Fix GCC 4.6 warnings
net/bootp.c: Fix GCC 4.6 warning
common/cmd_bootm.c: Fix GCC 4.6 warnings
board/mx1ads/mx1ads.c: Fix GCC 4.6 warning
board/mx1ads/syncflash.c: Fix GCC 4.6 warnings
board/lubbock/flash.c: Fix GCC 4.6 warnings
drivers/net/cs8900.c: Fix GCC 4.6 warning
arch/arm/cpu/arm926ejs/omap/cpuinfo.c: Fix GCC 4.6 warnings
drivers/net/lan91c96.c: Fix GCC 4.6 warning
board/ronetix/pm9263/pm9263.c: Fix GCC 4.6 warning
drivers/mtd/onenand/samsung.c: Fix GCC 4.6 warning
drivers/usb/musb/musb_hcd.c: Fix GCC 4.6 warning
Fix:
dnet.c: In function 'dnet_send':
dnet.c:136:9: warning: variable 'len' set but not used
dnet.c: In function 'dnet_set_hwaddr':
dnet.c:209:2: warning: dereferencing type-punned pointer will
Fix:
cs8900.c: In function 'get_reg_init_bus':
cs8900.c:69:14: warning: variable 'c' set but not used
Fix:
lan91c96.c: In function 'dump_memory_info':
lan91c96.c:157:7: warning: variable 'mem_info' set but not used
lan91c96.c: In function 'smc_send_packet':
lan91c96.c:320:16: warning: variable 'ioaddr' set but not used
device is already in *normal* (D0) mode => it doesn't need to be wake-up.
With this patch, we only wake-up (writing on TEST_BYTE register) if PM_MODE
bits of PM_CTRL register is in sleep (D1/D2) mode.
Signed-off-by: Bertrand Cachet <bertrand.cachet@heig-vd.ch>
No one uses this driver, and it isn't converted to the NET_MULTI
framework (which we dropped recently), so drop this driver too.
Fix the following build warning in drivers/net/e1000.c
e1000.c: In function 'e1000_reset_hw':
e1000.c:1373:11: warning: variable 'icr' set but not used [-Wunused-but-set-variable]
e1000.c: In function 'e1000_phy_init_script':
e1000.c:4395:11: warning: variable 'ret_val' set but not used [-Wunused-but-set-variable]
Some of the EEPROM Word Offset macros, and a few others, are defined
twice in e1000.h.
Fix:
enc28j60.c: In function 'enc_receive':
enc28j60.c:435:5: warning: variable 'eir_reg' set but not used
enc28j60.c: In function 'enc_poll':
enc28j60.c:503:5: warning: variable 'estat_reg' set but not used
Fix:
at91_emac.c: In function 'at91emac_write_hwaddr':
at91_emac.c:477:15: warning: variable 'dev' set but not used
Fix:
4xx_enet.c: In function 'ppc_4xx_eth_init':
4xx_enet.c:875:6: warning: variable 'ethgroup' set but not used [-Wunused-but-set-variable]
I used "__maybe_unused" here intentionally, since all other
alternatives to fix this compilation warning would result in more
ifdef's.
* 'master' of git://git.denx.de/u-boot-arm:
arm, davinci: add DAVINCI_MMC_CLKID
arm, davinci_emac: fix driver bug if more then 3 PHYs are detected
arm, davinci: da850/dm365 lowlevel cleanup
omap5: Add omap5_evm board build support.
omap4/5: Add support for booting with CH.
omap5: emif: Add emif/ddr configurations required for omap5 evm
omap5: clocks: Add clocks support for omap5 platform.
omap5: Add minimal support for omap5430.
omap: Checkpatch fixes
omap4: make omap4 code common for future reuse
GCC4.6: Squash warnings in onenand_base.c
GCC4.6: Fix common/usb.c on xscale
OneNAND: Add simple OneNAND SPL
PXA: vpac270: Enable the new generic MMC driver
PXA: Cleanup serial_pxa
PXA: Drop csb226 and innokom boards (unmaintained)
m28evk: Fix comment about the number of RAM banks
mx31: Fix checkpatch warnings in generic.c
mx31: Use proper IO accessor for GPR register
mx31: Remove duplicate definition for GPR register
qong: Use generic function for configuring GPR register
M28EVK: Enable USB HOST support
iMX28: Add USB HOST driver
iMX28: Add USB and USB PHY register definitions
M28: Add memory detection into SPL
iMX28: Fix ARM vector handling
M28: Add doc/README.m28 documentation
M28: Add MMC SPL
iMX28: Add support for DENX M28EVK board
iMX28: Add u-boot.sb target to Makefile
iMX28: Add image header generator tool
iMX28: Add driver for internal RTC
iMX28: Add GPMI NAND driver
iMX28: Add APBH DMA driver
iMX28: Add SPI driver
iMX28: Add GPIO control
iMX28: Add I2C bus driver
iMX28: Add PINMUX control
FEC: Add support for iMX28 quirks
iMX28: Add SSP MMC driver
iMX28: Initial support for iMX28 CPU
MX25: zmx25: GCC4.6 fix build warnings
da850: add new config file for AM18xx
BeagleBoard: config: Switch to ttyO2
OMAP3: Change omap3_evm maintainer
devkit8000: Fix NAND SPL on boards with 256MB NAND
integrator: enable Vpp and disable flash protection
integrator: add system controller header
integrator: make flash writeable on boot
integrator: use io-accessors for board init
integrator: move text offset to config
integrator: pass configs for core modules
ARM: remove superfluous setting of arch_number in board specific code.
SPL: Allow ARM926EJS to avoid compiling in the CPU support code
integrator: do not test first part of the memory
arm: a320: fix broken timer
ARM: define CONFIG_MACH_TYPE for all ronetix boards
dm646x: pass board revision info to kernel
dm646x: add new configuration for dm6467T
arm, davinci: Fix setting of the SDRAM configuration register
arm, davinci: Remove the duplication of LPSC functions
arm, davinci: Rename AM1808 lowlevel functions to DA850
da8xxevm: fix build error
ARM: re-add MACH_TYPE_XXXXXX for VCMA9 board and add CONFIG_MACH_TYPE
since commits:
davinci: emac: add support for more than 1 PHYs
062fe7d332c28ede25626f448681e43d76bb312e
davinci: remove obsolete macro CONFIG_EMAC_MDIO_PHY_NUM
fb1d6332b5430b90a8fa8ebab709f33a60e9f816
I get following warning on the enbw_cmc board:
Err: serial
Net: 5 ETH PHY detected
miiphy_register: non unique device name 'KSZ8873 @ 0x01'
DaVinci-EMAC
Hit any key to stop autoboot: 0
Also I see some debug printfs:
=> run load
+ emac_close
+ emac_ch_teardown
- emac_ch_teardown
+ emac_ch_teardown
- emac_ch_teardown
- emac_close
+ emac_open
- emac_open
Using DaVinci-EMAC device
reason is 062fe7d332c28ede25626f448681e43d76bb312e new define MAX_PHY.
This is set to 3! I get on this board 5 active phys, so
this leads in wrong memory writes ...
so I changed:
- define CONFIG_SYS_DAVINCI_EMAC_PHY_COUNT to set
the MAX_PHY value, add a description in README
for the new CONFIG_SYS option.
- print an error message if more then MAX_PHYs are
detected.
- fill the active_phy_addr array in a for loop with
0xff
- changed printf() in debug_emac()
Cc: Sandeep Paulraj <s-paulraj@ti.com>
Cc: Manjunath Hadli <manjunath.hadli@ti.com>
Cc: Prabhakar Lad <prabhakar.csengg@gmail.com>
Cc: Tom Rini <tom.rini@gmail.com>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
Fix:
fm.c: In function 'fm_init_common':
fm.c:398:6: warning: variable 'n' set but not used [-Wunused-but-set-variable]
