This patch enables the NAND controller on the Armada XP/38x and provides
a new function that returns the NAND controller input clock. This
function will be used by the MVEBU NAND driver.
As part of this patch, the multiple BIT macro definitions are moved
to a common place in soc.h.
Cc: Peter Morrow <peter@senient.com>
Cc: Luka Perkov <luka.perkov@sartura.hr>
Add support to specify the Ethernet buffer base address;
if none are supply by the board, the default value is use (from existing code).
Signed-off-by: Sylvain Lemieux <slemieux@tycoint.com>
The current 4.5 timeout for the autonegotiation are not enough to
complete it on my platform. Using the Intel E1000 PCIe card in the
Marvell db-mv784mp-gp eval board. So lets increase the timeout to
8 seconds.
Add Ethernet PHY for BCM Cygnus SoC
Signed-off-by: Jiandong Zheng <jdzheng@broadcom.com>
Signed-off-by: Steve Rae <srae@broadcom.com>
With commit e3a77218a256edbe201112a39beeed8adcabae3f the MII bus is only
reset if a reset handler is registered. If there is no reset handler there
is no need to wait for a device to come out of the reset.
Signed-off-by: Jörg Krause <joerg.krause@embedded.rocks>
phy_id is declared as u32 in create_phy_by_mask and in struct phy_device.
The rxbd is not correctly handled in case of a frame physical error
(FPE) or frame size error (FSE). The rxbd must be cleared and
advanced in case of an error to avoid receive stall.
Signed-off-by: Daniel Inderbitzin <daniel.inderbitzin@gmail.com>
LPC32xx MAC and clock control configuration requires some minor quirks
to deal with a phy connected by RMII.
It's worth to mention that the kernel and legacy BSP from NXP sets
SUPP_RESET_RMII == (1 << 11) bit, however the description of this bit is
missing in shared LPC32x0 User Manual UM10326 Rev. 3, July 22, 2011
and in LPC32x0 Draft User Mannual Rev. 00.27, November 20, 2008, also
in my tests an SMSC LAN8700 phy device connected over RMII seems to
work correctly without touching this bit.
Add support of RMII, if CONFIG_RMII is defined, this option is aligned
with a number of boards, which already define the same config value.
Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
Tested-by: Sylvain Lemieux <slemieux@tycoint.com>
This change rearranges general MAC configuration and PHY specific
configuration of MAC registers (duplex mode and speed), before this
change set bits related to PHY configuration in MAC2 and COMMAND
registers are rewritten by the following writing to the registers.
Without the change auto negotiation on boot quite often is not
completed in reasonable time:
Waiting for PHY auto negotiation to complete......... TIMEOUT !
Additionally MAC1_SOFT_RESET clear bit is removed since it is done in
preceding lpc32xx_eth_initialize() and in lpc32xx_eth_halt(), instead
added missing MCFG_RESET_MII_MGMT on device initialization.
The lpc32xx_eth_phylib_init() function is capable to connect LPC32XX
MAC to some specified phy by phy id, by chance the single user of
lpc32xx_eth has CONFIG_PHY_ADDR set to 0, however other boards may
have non-zero CONFIG_PHY_ADDR value, fix it.
Acked-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
According to LPC32x0 User Manual the following bits in Command
register 0x3106_0100 are defined:
Bit Symbol
2 - Unused
3 RegReset
4 TxReset
5 RxReset
Fix wrong (1-bit shifted right) COMMAND_RESETS value, which sets
an unused bit, but neglects RxReset.
Tearing down an unitialized rx channel causes a pending address hole
event to be queued. When booting linux it will report this pending
as something like "Address Hole seen by USB_OTG at address 57fff584",
since u-boot did not handled this interrupt. Prevent that by not
tearing down the rx channel, when not receiving.
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
Support the 88E1510 PHY which is very similar to the 88E1518.
I also set the INTn output and configured the LEDs.
Signed-off-by: Clemens Gruber <clemens.gruber@pqgruber.com>
Cc: Hao Zhang <hzhang@ti.com>
Cc: Michal Simek <michal.simek@xilinx.com>
- The EEE fixup magic should also be enabled for RGMII
- Improved comments
This patch refer to linux kernel commit: d8b763e1e79f
net/macb: add TX multiqueue support for gem
by: Cyrille Pitchen
1. macb driver will check the register to find how many queues support for
this chip.
2. Then as we only use queue0 for tx, so we will set up all other queues
use a dummy descriptor, which USED bit is set. So those queues are not used.
Signed-off-by: Josh Wu <josh.wu@atmel.com>
Initialize LCR rigister to configure
green LED for Link, yellow LED for Active.
Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com>
remove unnecessary clearing of SWSM.SWSM_SMBI when obtaining the SW
semaphore. This was introduced in 951860634fdb557bbb58e0f99215391bc0c29779
while adding i210 support and should be now resolved by releasing the
semaphore when no longer needed.
Cc: Marcel Ziswiler <marcel@ziswiler.com>
Cc: Aneesh Bansal <aneesh.bansal@freescale.com>
Cc: Naveen Burmi <NaveenBurmi@freescale.com>
Cc: Po Liu <po.liu@freescale.com>
Cc: Bin Meng <bmeng.cn@gmail.com>
Cc: Alison Wang <alison.wang@freescale.com>
Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
Cc: Shengzhou Liu <Shengzhou.Liu@freescale.com>
Cc: York Sun <yorksun@freescale.com>
Signed-off-by: Tim Harvey <tharvey@gateworks.com>
Tested-by: Bin Meng <bmeng.cn@gmail.com>
Tested-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
This reverts commit 17da7120249bfdef877f46be5bbcb3cc01212eb9.
The i210/i211 do have the SW_FW_SYNC (0x5b5c) register and this is what should
be used when acquiring the semaphore.
I believe the issue that this patch was trying to resolve is now resolved
by properly releasing the semaphore once no longer needed.
Once the hwsw semaphore is acquired, it must be released when access to the
hw is completed. Without this subsequent calls to acquire will timeout
obtaining the semaphore.
The driver variable name is eth_sandbox, which is probably a copy-paste
mistake. Fix it.
Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
Add the OF compatible property to match the SoCFPGA GMAC.
MC firware version 8.0.0 contains new command flags. This patch
contains modifications in FLIB files to support the new command flags.
Signed-off-by: Itai Katz <itai.katz@freescale.com>
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
Reviewed-by: York Sun <yorksun@freescale.com>
Extend time for MDIO. (Because of zed board)
Setting up WRAP bit to indicate that this is the last TX BD in the
chain.
Increase the Rx Buffer descriptors to 32. This will avoid
Rx buffer descriptors overflow if more packets were received
at one shot before we process the received ones.
This fixes the issue of intermittent timeouts during tftp
on a 1Gb connection with tftp server running on windows.
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
Flush and invalidate the rx buffers while sending the
tx packet it self as armv8 does flush also while doing
invalidation.
Set the data bus width to 64-bit AMBA Databus width in config register.
The MCAST_TFTP support requires that network drivers has mcast functon
implemented. This commit adds dummy keystone2_eth_bcast_addr() to meet
the requirement. As far as the driver doesn't use ALE and doesn't filter
any incoming packets, the function is empty.
Signed-off-by: Vitaly Andrianov <vitalya@ti.com>
Some devices can take a long time to work out whether they have a new packet
or now. For example the ASIX USB Ethernet dongle can take 5 seconds to do
this, since it waits until it gets a new packet on the wire before allowing
the USB bulk read packet to be submitted.
At present with driver mode the Ethernet receive code reads 32 packets. This
can take a very long time if we must wait for all 32 packets. The old code
(before driver model) worked by reading a single set of packets from the USB
device, then processing all the packets with in. It would be nice to use
the same behaviour with driver model.
Add a flag to the receive method which indicates that the driver should try
to find a packet if available, by consulting the hardware. When the flag is
not set, it should just return any packet data it has already received. If
there is none, it should return -EAGAIN so that the loop will terminate.
This driver is used by the Intel Minnowmax board. Convert it to driver model
so it can use the new Ethernet implementation.
Change infinite loop mechanism to timer based polling for QBMAN release in
ldpaa_eth_rx.
Polling of TX conf frames is not a mandatory option.
Packets can be transferred via WRIOP without TX conf frame.
Configure ldpaa_eth driver to use TX path without confirmation frame
Volatile command does not return frame immidiately, need to wait till a frame
is available in DQRR. Ideally it should be a blocking call.
Add timeout handling for DQRR frame instead of retry counter.
Do not immediately return if the enqueue function returns -EBUSY; re-try
mulitple times.
if timeout occures, release the buffer.
delete any existing ICID pools in the DPC and create
a new one based on the stream ID partitioning for
the SoC
Signed-off-by: Stuart Yoder <stuart.yoder@freescale.com>
Stream IDs on ls2085a devices are not hardwired and are
programmed by sw. There are a limited number of stream IDs
available, and the partitioning of them is scenario dependent.
This header defines the partitioning between legacy, PCI,
and DPAA2 devices.
Management complex major version should match to the firmware present in flash.
Return error during mismatch of major version.
Update qbman driver
- As per latest available qbman driver
- Use of atomic APIs
CC: Geoff Thorpe <Geoff.Thorpe@freescale.com>
CC: Haiying Wang <Haiying.Wang@freescale.com>
CC: Roy Pledge <Roy.Pledge@freescale.com>
Update flibs changes to mc-0.6.0.1 for dpmang, dprc, dpni and dpio objects
Also rename qbman_portal_ce/ci_paddr to qbman_portal_ce/ci_offset in
dpio_attr. These are now offsets from the SoC QBMan portals base.
Signed-off-by: J. German Rivera <German.Rivera@freescale.com>
Load AIOP image from NOR flash into DDR so that the MC firmware
the MC fw can start it at boot time
Flush buffer before releasing to BMan after TX_conf to ensure, the core does
not have any cachelines that the WRIOP will DMA to.
Make it easier for the user to notice when the MC firmware
had problems booting.
This patch fixes the DDR hide logic for LS2085a, correcting the way
the Debug Server FW and MC FW images are placed on the top of system
DDR and how the rest of the system DDR space is made visibile to Linux.
Signed-off-by: Bhupesh Sharma <bhupesh.sharma at freescale.com>
Signed-off-by: Prabhakar Kushwaha <prabhakar at freescale.com>
This locally defined struct is actually only used once
and as an opaque type. Remove it for clarity.
Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
commit f566c99 "net: Update hardware MAC address if it changes in env"
removes writing MAC address to designware controller after soft reset.
This makes designware ethernet port fail to work. Actually the MAC
address should always be programmed after soft reset.
them from include/configs.
Remove the calls to net_random_ethaddr() that some boards and some
drivers are calling. This is now implemented inside of net/eth.c
Enable the feature for all boards that previously enabled it.
Acked-By: Michael Walle <michael@walle.cc> (for the lsxl board part)
Series-changes: 2
-Fixed bfin build errors
We really don't want boards defining fixed MAC addresses in their config
so we just remove the option to set it in a fixed way. If you must have
a MAC address that was not provisioned, then use the random MAC address
functionality.
