path: root/drivers/net/xilinx_ll_temac_sdma.h
2012-05-22drivers/net/xilinx_ll_temac.c: Fix compile warningStephan Linz
Fix this: xilinx_ll_temac.c: In function 'xilinx_ll_temac_initialize': xilinx_ll_temac.c:332: warning: assignment from incompatible pointer type xilinx_ll_temac.c:340: warning: assignment from incompatible pointer type Signed-off-by: Stephan Linz <linz@li-pro.net>
2012-04-04net: ll_temac: Add LL TEMAC driver to u-bootStephan Linz
Xilinx LocalLink Tri-Mode Ether MAC driver can be used by Xilinx Microblaze or Xilinx ppc405/440 in SDMA and FIFO mode. DCR or XPS bus can be used. The driver uses and requires MII and PHYLIB. CP: 4 warnings: 'Use of volatile is usually wrong' I won't fix this, because it depends on the network driver subsystem. Reported-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Stephan Linz <linz@li-pro.net>
