path: root/drivers/net/xilinx_ll_temac.c
2012-07-11net: abort network initialization if the PHY driver failsTimur Tabi
Now that phy_startup() can return an actual error code, check for that error code and abort network initialization if the PHY fails. Signed-off-by: Timur Tabi <timur@freescale.com> Acked-by: Nobuhiro Iwamamatsu <nobuhiro.iwamatsu.yj@renesas.com> (sh_eth part) Acked-by: Stephan Linz <linz@li-pro.net> (Xilinx part, xilinx_axi_emac and xilinx_ll_temac) Reviewed-by: Marek Vasut <marex@denx.de> (FEC part)
2012-04-21net: ll_temac: drop obsolete "NAMESIZE" defineStephan Linz
... after commit "net/miiphy/serial: drop duplicate NAMESIZE define" (sha1:f6add13) was applied. The building of the new LL TEMAC network driver fails with error below: xilinx_ll_temac.c: In function 'xilinx_ll_temac_initialize': xilinx_ll_temac.c:301: error: 'NAMESIZE' undeclared (first use in this function) xilinx_ll_temac.c:301: error: (Each undeclared identifier is reported only once xilinx_ll_temac.c:301: error: for each function it appears in.) Signed-off-by: Stephan Linz <linz@li-pro.net> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-04-04net: ll_temac: Add LL TEMAC driver to u-bootStephan Linz
Xilinx LocalLink Tri-Mode Ether MAC driver can be used by Xilinx Microblaze or Xilinx ppc405/440 in SDMA and FIFO mode. DCR or XPS bus can be used. The driver uses and requires MII and PHYLIB. CP: 4 warnings: 'Use of volatile is usually wrong' I won't fix this, because it depends on the network driver subsystem. Reported-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Stephan Linz <linz@li-pro.net>
