path: root/drivers/net/xilinx_axi_emac.c
2018-04-09axi: ethernet: Added support for 64 bit addressing for axi-ethernetVipul Kumar
This patch uses writeq() function to enable greater than 32 bit addressing of axi-ethernet for the ZynqMP devices. Signed-off-by: Vipul Kumar <vipulk@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-01-24wait_bit: use wait_for_bit_le32 and remove wait_for_bitÁlvaro Fernández Rojas
wait_for_bit callers use the 32 bit LE version Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-11-29net: xilinx_axi_emac: Use readl and writel for io opsSiva Durga Prasad Paladugu
This patch uses readl and writel instead of in_be32 and out_be32 for io ops as these internally uses readl, writel for microblaze and for Zynq, ZynqMP there is no need of endianness conversion and readl, writel should work straightaway. This patch starts supporting the driver for Zynq and ZynqMP platforms. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-11-29net: xilinx_axi_emac: Add support for non processor modeSiva Durga Prasad Paladugu
Add support for non processor mode, this mode doesn't have access to some of the registers and hence this patch bypasses it and also length has to be calculated from status instead of app4 in this mode. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
2017-11-28net: xilinx_axi_emac: Read dma address using fdtdec_get_addrSiva Durga Prasad Paladugu
Read dma address using fdtdec_get_addr as it checks for address cells and size cells and reads the address properly. fdtdec_get_int always assume address is of int size which goes wrong if using it on 64-bit architecture. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-11-28net: xilinx_axi_emac: Use wait_for_bit instead of while loopSiva Durga Prasad Paladugu
Use wait_for_bit instead while loop during init Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
2017-06-01dm: Rename dev_addr..() functionsSimon Glass
These support the flat device tree. We want to use the dev_read_..() prefix for functions that support both flat tree and live tree. So rename the existing functions to avoid confusion. In the end we will have: 1. dev_read_addr...() - works on devices, supports flat/live tree 2. devfdt_get_addr...() - current functions, flat tree only 3. of_get_address() etc. - new functions, live tree only All drivers will be written to use 1. That function will in turn call either 2 or 3 depending on whether the flat or live tree is in use. Note this involves changing some dead code - the imx_lpi2c.c file. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-02-08dm: core: Replace of_offset with accessorSimon Glass
At present devices use a simple integer offset to record the device tree node associated with the device. In preparation for supporting a live device tree, which uses a node pointer instead, refactor existing code to access this field through an inline function. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-12-20net: xilinx: Use mdio_register_seq() to support multiple instancesMichal Simek
axi_emac, emaclite and gem have the same issue with registering multiple instances with mdio busses. mdio bus name has to be uniq but drivers are setting up only one name for all. Use mdio_register_seq() and pass dev->seq number to allow multiple mdio instances registration. Reported-by: Phani Kiran Kara <phanikiran.kara@gmail.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-12-09Revert "Merge branch 'master' of git://www.denx.de/git/u-boot-microblaze"Tom Rini
This reverts commit 3edc0c252257e4afed163a3a74aba24a5509b198, reversing changes made to bb135a0180c31fbd7456021fb9700b49bba7f533.
2016-12-08net: xilinx: Use mdio_register_seq() to support multiple instancesMichal Simek
axi_emac, emaclite and gem have the same issue with registering multiple instances with mdio busses. mdio bus name has to be uniq but drivers are setting up only one name for all. Use mdio_register_seq() and pass dev->seq number to allow multiple mdio instances registration. Reported-by: Phani Kiran Kara <phanikiran.kara@gmail.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Series-to: u-boot Series-cc: Phani Kiran Kara <phanikiran.kara@gmail.com>
2016-04-04net: axi_emac: Report phy-node error message permanentlyMichal Simek
Do not use debug() when printing error message. Use printf instead. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-04-04net: xilinx_axi: Clear Isolate bit if found during phy setupSiva Durga Prasad Paladugu
In SGMII cases the isolate bit might set after DMA and ethernet resets and hence check and clear during setup_phy if it was set. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-04-04net: xilinx_axi: Use interface type instead of zeroSiva Durga Prasad Paladugu
Pass appropriate interface type to phy_connect instead of zero. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27net: Add axi emac to KconfigMichal Simek
Also add dependency on PHYLIB and MII which is required. Clean PHYLIB dependency from the driver too. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-01-27net: axi_emac: Rename start, stop, write_hwaddr functionsMichal Simek
Rename few functions to fit to the new name convention used by DM. Suggested-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27net: axi_emac: Split recv from free_pktMichal Simek
Call net_process_received_packet() by core. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-01-27net: axi_emac: Enable access to MDIO in probeMichal Simek
Detect phy when driver probes. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-01-27net: axi_emac: Move driver to DMMichal Simek
Move driver to DM. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-01-27net: axi_emac: Pass private structure where possibleMichal Simek
Use axidma_priv instead of ethdevice in preparation of the DM move. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27net: axi_emac: Pass private structure to phyread/phywriteMichal Simek
Prepare for move to DM. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-01-27net: axi_emac: Put iobase to private structureMichal Simek
Saving iobase directly to private structure helps with moving to DM. There is an option to load iobase from pdata but it is additional load. Pointer to private structure is available all the time. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-01-27net: axi_emac: Pass directly pointer to register spaceMichal Simek
Simplify mdio_wait function by passing regs directly. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-01-27net: axi_emac: Show phy address instead of register contentMichal Simek
Fix debug message. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-01-27net: axi_emac: Fix parentheses around operand !Michal Simek
Fix these compilation warning by proper grouping: In function 'axi_dma_init': drivers/net/xilinx_axi_emac.c:391:7: warning: suggest parentheses around operand of '!' or change '&' to '&&' or '!' to '~' [-Wparentheses] if (!(in_be32(&priv->dmatx->control) | ^ In function 'axiemac_send': drivers/net/xilinx_axi_emac.c:501:21: warning: suggest parentheses around operand of '!' or change '&' to '&&' or '!' to '~' [-Wparentheses] while (timeout && (!in_be32(&priv->dmatx->status) & Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-04-18net: cosmetic: Fix var naming net <-> eth driversJoe Hershberger
Update the naming convention used in the network stack functions and variables that Ethernet drivers use to interact with it. This cleans up the temporary hacks that were added to this interface along with the DM support. This patch has a few remaining checkpatch.pl failures that would be out of the scope of this patch to fix (drivers that are in gross violation of checkpatch.pl). Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-02-04net: axi_emac: Check if phy was correctly detectedMichal Simek
As tsec and fm drivers checking phydev->link ensure that u-boot don't try access device if link is not ready. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2012-07-11net: abort network initialization if the PHY driver failsTimur Tabi
Now that phy_startup() can return an actual error code, check for that error code and abort network initialization if the PHY fails. Signed-off-by: Timur Tabi <timur@freescale.com> Acked-by: Nobuhiro Iwamamatsu <nobuhiro.iwamatsu.yj@renesas.com> (sh_eth part) Acked-by: Stephan Linz <linz@li-pro.net> (Xilinx part, xilinx_axi_emac and xilinx_ll_temac) Reviewed-by: Marek Vasut <marex@denx.de> (FEC part)
2012-05-22drivers/net/xilinx_axi_emac.c: Fix compile warningStephan Linz
Fix this: xilinx_axi_emac.c: In function 'xilinx_axiemac_initialize': xilinx_axi_emac.c:646: warning: assignment from incompatible pointer type Signed-off-by: Stephan Linz <linz@li-pro.net>
2011-10-15net: axi_ethernet: Add driver to u-bootMichal Simek
Add axi_ethernet driver for little-endian Microblaze. RX/TX BDs and rxframe buffer are shared among all axi_ethernet MACs. Only one MAC can work in one time. Signed-off-by: Michal Simek <monstr@monstr.eu> Acked-by: Mike Frysinger <vapier@gentoo.org>
