path: root/drivers/net/vsc7385.c
2020-05-18common: Drop linux/delay.h from common headerSimon Glass
Move this uncommon header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop log.h from common headerSimon Glass
Move this header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-11-19Move console definitions into a new console.h fileSimon Glass
The console includes a global variable and several functions that are only used by a small subset of U-Boot files. Before adding more functions, move the definitions into their own header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-11-04drivers/net/: sparse fixesKim Phillips
phy.c:46:5: warning: symbol 'genphy_config_advert' was not declared. Should it be static? phy.c:121:5: warning: symbol 'genphy_setup_forced' was not declared. Should it be static? phy.c:468:5: warning: symbol 'phy_probe' was not declared. Should it be static? phy.c:491:19: warning: symbol 'get_phy_driver' was not declared. Should it be static? phy.c:508:19: warning: symbol 'phy_device_create' was not declared. Should it be static? phy.c:552:5: warning: symbol 'get_phy_id' was not declared. Should it be static? phy.c:584:19: warning: symbol 'get_phy_device' was not declared. Should it be sta vitesse.c:126:5: warning: symbol 'vsc8601_config' was not declared. Should it be static? vsc7385.c:33:5: warning: symbol 'vsc7385_upload_firmware' was not declared. Should it be static? tgec_phy.c:33:5: warning: symbol 'tgec_mdio_write' was not declared. Should it be static? tgec_phy.c:75:5: warning: symbol 'tgec_mdio_read' was not declared. Should it be static? tgec_phy.c:117:5: warning: symbol 'tgec_mdio_reset' was not declared. Should it be static? eth.c:48:6: warning: symbol 'dtsec_configure_serdes' was not declared. Should it be static? p4080.c:26:5: warning: symbol 'port_to_devdisr' was not declared. Should it be static? Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-06-09net: Conditional COBJS inclusion of network driversShinya Kuribayashi
Replace COBJS-y with appropriate driver config names. Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-03-26Cleanup coding style, update CHANGELOGWolfgang Denk
2008-03-25NET: Add Vitesse VSC7385 firmware uploadingTimur Tabi
The Vitesse VSC7385 is a 5-port switch found on the Freescale MPC8349E-mITX and other boards. A small firwmare must be uploaded to its on-board memory before it can be enabled. This patch adds the code which uploads firmware (but not the firmware itself). Previously, this feature was provided by a U-Boot application that was made available only on Freescale BSPs. The VSC7385 firmware must still be obtained separately, but at least there is no longer a need for a separate application. Signed-off-by: Timur Tabi <timur@freescale.com> Acked-by: Ben Warren <biggerbadderben@gmail.com>
