Last user of this driver went away in June 2015 in commit
d928664f4101e24 ("powerpc: 74xx_7xx: remove 74xx_7xx cpu support")
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
Update the naming convention used in the network stack functions and
variables that Ethernet drivers use to interact with it.
This cleans up the temporary hacks that were added to this interface
along with the DM support.
This patch has a few remaining checkpatch.pl failures that would be out
of the scope of this patch to fix (drivers that are in gross violation
of checkpatch.pl).
[trini: Fixup common/cmd_io.c]
Fix this:
tsi108_eth.c: In function 'tsi108_eth_initialize':
tsi108_eth.c:745:13: warning: assignment from incompatible pointer type
tsi108_eth.c: In function 'tsi108_eth_recv':
tsi108_eth.c:989:4: warning: passing argument 1 of 'NetReceive' discards qualifiers from pointer target type
tsi108_eth driver does not have write_hwaddr function.
However, eth stuff executes write_hwaddr function
because eth_device structure has not been initialized.
CC: Ben Warren <biggerbadderben@gmail.com>
Affected boards:
mpc7448hpc2
Removed initialization of the driver from net/eth.c
Replace COBJS-y with appropriate driver config names.
Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
Change return values of init() functions in all Ethernet drivers to conform
to the following:
>=0: Success
<0: Failure
All drivers going forward should return 0 on success. Current drivers that
return 1 on success were left as-is to minimize changes.
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Acked-by: Kim Phillips <kim.phillips@freescale.com>
Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
Acked-By: Timur Tabi <timur@freescale.com>
