path: root/drivers/net/tsi108_eth.c
2012-05-22drivers/net/tsi108_eth.c: Fix compile warningJoe Hershberger
Fix this: tsi108_eth.c: In function 'tsi108_eth_initialize': tsi108_eth.c:745:13: warning: assignment from incompatible pointer type tsi108_eth.c: In function 'tsi108_eth_recv': tsi108_eth.c:989:4: warning: passing argument 1 of 'NetReceive' discards qualifiers from pointer target type Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2010-11-14net: tsi108_eth: Add initialized eth_device structureNobuhiro Iwamatsu
tsi108_eth driver does not have write_hwaddr function. However, eth stuff executes write_hwaddr function because eth_device structure has not been initialized. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Ben Warren <biggerbadderben@gmail.com>
2008-09-02Moved initialization of TSI108 Ethernet controller to board_eth_init()Ben Warren
Affected boards: mpc7448hpc2 Removed initialization of the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-07-11Fix some more printf() format issues.Wolfgang Denk
2008-06-09net: Conditional COBJS inclusion of network driversShinya Kuribayashi
Replace COBJS-y with appropriate driver config names. Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-01-10Fix Ethernet init() return codesBen Warren
Change return values of init() functions in all Ethernet drivers to conform to the following: >=0: Success <0: Failure All drivers going forward should return 0 on success. Current drivers that return 1 on success were left as-is to minimize changes. Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Kim Phillips <kim.phillips@freescale.com> Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Acked-By: Timur Tabi <timur@freescale.com>
2007-11-25drivers/net : move net drivers to drivers/netJean-Christophe PLAGNIOL-VILLARD
