path: root/drivers/net/smc91111.h
2015-09-11arm: Remove xaeniax boardSimon Glass
This board has not been converted to generic board by the deadline. Remove it. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-30Add MS7206SE ethernet supportYoshinori Sato
Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2014-02-21SMC91111: Fix compilation warningsBhupesh Sharma
This patch fixes the following warning messages coming out of 'drivers/net/smc91111.h' when compiled for 'vexpress_aemv8a': warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] Currently this issue seems to surface when SMSC is compiled for 64-bit ARMv8 platforms, so the change is protected under CONFIG_ARM64, so that it doesn't break other existing platforms. In addition this patch tries to fix some checkpatch errors and warnings (others related to camel-casing and volatile usage will be addressed by a later patch). This fix has been tested on both ARMv8 foundation model v1 and v2. Signed-off-by: Bhupesh Sharma <bhupesh.sharma@freescale.com>
2011-12-06PXA: Rename CONFIG_PXA2[57]X to CONFIG_CPU_PXA2[57]XMarek Vasut
2009-11-09SMC91111: Clean up SMC_inx macros on xsengine and xaeniaxBen Warren
This patch fixes the following warnings: Configuring for xaeniax board... smc91111_eeprom.c: In function 'print_macaddr': smc91111_eeprom.c:278: warning: suggest parentheses around + or - in operand of & smc91111_eeprom.c:281: warning: suggest parentheses around + or - in operand of & ... Configuring for xsengine board... smc91111_eeprom.c: In function 'print_macaddr': smc91111_eeprom.c:278: warning: suggest parentheses around + or - inside shift smc91111_eeprom.c:281: warning: suggest parentheses around + or - inside shift Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-10-04Convert SMC91111 Ethernet driver to CONFIG_NET_MULTI APIBen Warren
All in-tree boards that use this controller have CONFIG_NET_MULTI added Also: - changed CONFIG_DRIVER_SMC91111 to CONFIG_SMC91111 - cleaned up line lengths - modified all boards that override weak function in this driver - modified all eeprom standalone apps to work with new driver - updated blackfin standalone EEPROM app after testing Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-03-31SPARC: added SMC91111 driver in and out macros for LEON processors.Daniel Hellstrom
This patch makes SPARC/LEON processors able to read and write to the SMC91111 chip using the chip external I/O bus of the memory controller. This patchs defines the standard in and out macros expected by the SMC9111 driver. To access that I/O bus one must set up the memory controller (MCTRL or FTMCTRL) correctly. It is assumed that the user sets up this correctly when the other MCTRL parameters are set up. It can be set up from the board configuration header file. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-03-25smc91111: use SSYNC() rather than asm(ssync) for BlackfinMike Frysinger
Since the "ssync" instruction may have hardware anomalies associated with it, have the smc91111 driver use the SSYNC macro rather than invoking it directly. We workaround all the anomalies via this macro. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2007-11-25drivers/net : move net drivers to drivers/netJean-Christophe PLAGNIOL-VILLARD
