path: root/drivers/net/rtl8169.c
2011-11-07drivers/net/rtl8169.c: Fix GCC 4.6 build warningWolfgang Denk
Fix: rtl8169.c: In function 'rtl_init': rtl8169.c:742:13: warning: variable 'printed_version' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-11-14net: rtl8169: Add initialized eth_device structureNobuhiro Iwamatsu
rtl8169 does not have write_hwaddr function. However, eth stuff executes write_hwaddr function because eth_device structure has not been initialized. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-06-08rtl8169: fix PCI system memory addressYoshihiro Shimoda
When PCI device use system memory, some PCI host controller should be set physical memory address. Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-04-28rtl8169: fix cache coherency problemYoshihiro Shimoda
Fix the problem that cannot access actual data when CPU data cache enabled. Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Tested-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Acked-by: Ben Warren <biggerbadderben@gmail.com>
2009-03-20drivers/net/: get mac address from environmentMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. The drivers that get converted here: 3c589 4xx_enet dc2114x dm9000x enc28j60 fsl_mcdmafec ks8695eth mcffec rtl8019 rtl8169 s3c4510b_eth xilinx_emac xilinx_emaclite Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com> CC: Rolf Offermanns <rof@sysgo.de> CC: Stefan Roese <sr@denx.de> CC: Sascha Hauer <saschahauer@web.de> CC: TsiChung Liew <Tsi-Chung.Liew@freescale.com> CC: Greg Ungerer <greg.ungerer@opengear.com> CC: Xue Ligong <lgxue@hotmail.com> CC: Masami Komiya <mkomiya@sonare.it> CC: Curt Brune <curt@cucy.com> CC: Michal SIMEK <monstr@monstr.eu>
2008-09-02Moved initialization of RTL8169 Ethernet controller to board_eth_init()Ben Warren
Affected boards: linkstation r7780mp Removed initialization of the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-08-18rtl8169: add support for RTL8110SCLYoshihiro Shimoda
This patch fixes a problem that RTL8110SCL started transfer with an incorrect memory address. Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-07-10Fix some more print() format errors.Wolfgang Denk
2008-06-09net: Conditional COBJS inclusion of network driversShinya Kuribayashi
Replace COBJS-y with appropriate driver config names. Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-04-28rtl8169: fix compiler warningsGuennadi Liakhovetski
Fix multiple compiler warnings related to argument type mismatch. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
2008-03-08net: rtl8169: Add processing when OWNbit did't enable in rtl_recv()Nobuhiro Iwamatsu
When rtl_recv() of rtl8169 is called, OWNbit of status register is not enable occasionally. rtl_recv() doesn't work normally when the driver doesn't do appropriate processing. This patch fix this problem. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-02-14Remove duplicate defines for ARRAY_SIZEKumar Gala
2008-01-10Fix Ethernet init() return codesBen Warren
Change return values of init() functions in all Ethernet drivers to conform to the following: >=0: Success <0: Failure All drivers going forward should return 0 on success. Current drivers that return 1 on success were left as-is to minimize changes. Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Kim Phillips <kim.phillips@freescale.com> Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Acked-By: Timur Tabi <timur@freescale.com>
2008-01-09Fix endianness conversions in rtl8169 driverGuennadi Liakhovetski
It is unclear on what platforms this driver has been tested, since noone up to now defines CONFIG_RTL8169 in the board configuration header. Now it has been fixed for a big-endian mpc8241 based linkstation platform. This patch presents the necessary endianness conversion fixes. Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2007-11-25drivers/net : move net drivers to drivers/netJean-Christophe PLAGNIOL-VILLARD
