path: root/drivers/net/rtl8139.c
2010-11-14net: rtl8139: Add initialized eth_device structureNobuhiro Iwamatsu
rtl8139 driver does not have write_hwaddr function. However, eth stuff executes write_hwaddr function because eth_device structure has not been initialized. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Ben Warren <biggerbadderben@gmail.com>
2008-10-21Cleanup: fix "MHz" spellingWolfgang Denk
2008-09-02Moved initialization of RTL8139 Ethernet controller to board_eth_init()Ben Warren
Affected boards: hidden_dragon MPC8544DS MPC8610HPCN R2DPLUS TB0229 Removed initialization of the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-06-09net: Conditional COBJS inclusion of network driversShinya Kuribayashi
Replace COBJS-y with appropriate driver config names. Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-01-16drivers/net/rtl8139.c: rx_status should be le32_to_cpu(rx_status).Shinya Kuribayashi
rx_status on the memory is basically in LE, but needs to be handled in CPU endian. le32_to_cpu() takes up this mission. Even if on the sane hardware, it'll work fine. Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com> Cc: Masami Komiya <mkomiya@sonare.it> Cc: Lucas Jin <lucasjin@gmail.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-01-16drivers/net/rtl8139.c: Fix cache coherency issuesShinya Kuribayashi
Current driver is meant for cache coherent systems. This patch adds flush_cache() routines to support cache non-coherent systems. Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com> Cc: Masami Komiya <mkomiya@sonare.it> Cc: Lucas Jin <lucasjin@gmail.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-01-16drivers/net/rtl8139.c: Fix tx timeoutShinya Kuribayashi
"to = (currticks() + RTL_TIMEOUT)" has possibilities to wrap around. If it does, the condition "(currticks() < to)" becomes invalid and immediately leads to tx timeout error. This patch introduces the fine-graded udely(10) loops to ease the impact of wrapping around. Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com> Cc: Masami Komiya <mkomiya@sonare.it> Cc: Lucas Jin <lucasjin@gmail.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-01-10Fix Ethernet init() return codesBen Warren
Change return values of init() functions in all Ethernet drivers to conform to the following: >=0: Success <0: Failure All drivers going forward should return 0 on success. Current drivers that return 1 on success were left as-is to minimize changes. Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Kim Phillips <kim.phillips@freescale.com> Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Acked-By: Timur Tabi <timur@freescale.com>
2007-11-25drivers/net : move net drivers to drivers/netJean-Christophe PLAGNIOL-VILLARD
