path: root/drivers/net/phy
2011-05-19Minor coding style cleanup.Wolfgang Denk
2011-04-20phylib: Add a bunch of PHY drivers from tsecAndy Fleming
The tsec driver had a bunch of PHY drivers already written. This converts them all into PHY Lib drivers, and serves as the first set of PHY drivers for PHY Lib. While doing that, cleaned up a number of magic numbers (though not all of them, as PHY vendors like to keep their numbers as magical as possible). Also, noticed that almost all of the vitesse/cicada PHYs had the same config/parse/startup functions, so those have been collapsed into one. Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Detlev Zundel <dzu@denx.de>
2011-04-20Create PHY Lib for U-BootAndy Fleming
Extends the mii_dev structure to participate in a full-blown MDIO and PHY driver scheme. The mii_dev structure and miiphy calls are modified in such a way to allow the original mii command and miiphy infrastructure to work as before, but also to support a new set of APIs which allow (among other things) sharing of PHY driver code and 10G support The mii command will continue to support normal PHY management functions (Clause 22 of 802.3), but will not be changed to support 10G (Clause 45). The basic design is similar to PHY Lib from Linux, but simplified for U-Boot's network and driver infrastructure. We now have MDIO drivers and PHY drivers An MDIO driver provides: read write reset A PHY driver provides: (optionally): probe config - initial setup, starting of auto-negotiation startup - waiting for AN, and reading link state shutdown - any cleanup needed The ethernet drivers interact with the PHY Lib using these functions: phy_connect() phy_config() phy_startup() phy_shutdown() Each PHY driver can be configured separately, or all at once using config_phylib_all_drivers.h (added in the patch which adds the drivers) We also provide generic drivers for Clause 22 (10/100/1000), and Clause 45 (10G) PHYs. We also implement phy_reset(), and call it in phy_connect(). Because phy_reset() is essentially the same as miiphy_reset, but: a) must support 10G PHYs, and b) should use the phylib primitives, we implement miiphy_reset, using phy_reset(), but only when CONFIG_PHYLIB is set. Otherwise, we just use the old version. In this way, we save on compile size, even if we don't manage to save code size. Pulled ethtool.h and mdio.h from: git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6 782d640afd15af7a1faf01cfe566ca4ac511319d With many, many deletions so as to enable compilation under u-boot Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Detlev Zundel <dzu@denx.de>
2011-01-09miiphy: convert to linux/mii.hMike Frysinger
The include/miiphy.h header duplicates a lot of things from linux/mii.h. So punt all the things that overlap to keep the API simple and to make merging between U-Boot and Linux simpler. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-29Replace CONFIG_RELOC_FIXUP_WORKS by CONFIG_NEEDS_MANUAL_RELOCWolfgang Denk
By now, the majority of architectures have working relocation support, so the few remaining architectures have become exceptions. To make this more obvious, we make working relocation now the default case, and flag the remaining cases with CONFIG_NEEDS_MANUAL_RELOC. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-08-09Fix compile warnings for const correctnessBen Warren
Commit 6e37b1a3a25004d3df5867de49fff6b3fc9c4f04 modifies several net calls to take a (const char *) parameter instead of (char *), but in some cases the modified functions call other functions taking (char *). The end result is warnings about discarding the const qualifier. This patch fixes these other function signatures. Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-10-28Coding Style cleanup; update CHANGELOG, prepare -rc1v2009.11-rc1Wolfgang Denk
2009-10-27drivers/net/phy/miiphybb.c: fix warning: no newline at end of fileWolfgang Denk
Add missing newline. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Luigi Mantellini <luigi.mantellini@idf-hit.com> Cc: Ben Warren <biggerbadderben@gmail.com>
2009-10-10Rewrite the miiphybb (Bit-banged MII bus driver) in order to support an ↵Luigi 'Comio' Mantellini
arbitrary number of mii buses. This feature is useful when your board uses different mii buses for different phys and all (or a part) of these buses are implemented via bit-banging mode. The driver requires that the following macros should be defined into the board configuration file: CONFIG_BITBANGMII - Enable the miiphybb driver CONFIG_BITBANGMII_MULTI - Enable the multi bus support If the CONFIG_BITBANGMII_MULTI is not defined, the board's config file needs to define at least the following macros: MII_INIT - Generic code to enable the MII bus (optional) MDIO_DECLARE - Declaration needed to access to the MDIO pin (optional) MDIO_ACTIVE - Activate the MDIO pin as out pin MDIO_TRISTATE - Activate the MDIO pin as input/tristate pin MDIO_READ - Read the MDIO pin MDIO(v) - Write v on the MDIO pin MDC_DECLARE - Declaration needed to access to the MDC pin (optional) MDC(v) - Write v on the MDC pin The previous macros make the driver compatible with the previous version (that didn't support the multi-bus). When the CONFIG_BITBANGMII_MULTI is also defined, the board code needs to fill the bb_miiphy_buses[] array with a record for each required bus and declare the bb_miiphy_buses_num variable with the number of mii buses. The record (struct bb_miiphy_bus) has the following fields/callbacks (see miiphy.h for details): char name[] - The symbolic name that must be equal to the MII bus registered name int (*init)() - Initialization function called at startup time (just before the Ethernet initialization) int (*mdio_active)() - Activate the MDIO pin as output int (*mdio_tristate)() - Activate the MDIO pin as input/tristate pin int (*set_mdio)() - Write the MDIO pin int (*get_mdio)() - Read the MDIO pin int (*set_mdc)() - Write the MDC pin int (*delay)() - Delay function void *priv - Private data used by board specific code The board code will look like: struct bb_miiphy_bus bb_miiphy_buses[] = { { .name = miibus#1, .init = b1_init, .mdio_active = b1_mdio_active, ... }, { .name = miibus#2, .init = b2_init, .mdio_active = b2_mdio_active, ... }, ... int bb_miiphy_buses_num = sizeof(bb_miiphy_buses) / sizeof(bb_miiphy_buses[0]); Signed-off-by: Luigi 'Comio' Mantellini <luigi.mantellini@idf-hit.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-10-04net: phy: mv88e61xx.c : fixed build warningPrafulla Wadaskar
following build warning was observed mv88e61xx.c: In function ‘mv88e61xx_busychk’: mv88e61xx.c:208: warning: dereferencing type-punned pointer will break strict-aliasing rules This patch fixes the same Patch tested for rd6281a board build Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-08-10net: phy: bugfixes: mv88E61xx compiler warnings fixedPrafulla Wadaskar
1. mv88E61xx driver compiler warnings fixed 2. idstr if-else statements changed to switch() construct and added default case too. This fixed idstr may be uninitialized warning Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-07-22net: phy: bugfixes: mv88E61xx multichip addressing supportPrafulla Wadaskar
With these fixes, this driver works properly for multi chip addressging mode Bugfixes: 1. Build error fixed for function mv88e61xx_busychk_multic-fixed 2. PHY dev address error detection- fixed 3. wrong busy bit was refered in function mv88e61xx_busychk -fixed 4. invalid data read ptr was refered for RD_PHY in case of multichip addressing mode -fixed The Multichip Address mode is tested with RD6281A board having MV88E6165 switch on it Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-07-22MIIPHYBB: Return 0xFFFF if the PHY is not asserting TA.Richard Retanubun
This patch sets the returned value to 0xFFFF if the PHY does not exist and does not assert Transfer Acknowledge. A NULL check for the value pointer is also added for buffer overflow protection. Without this patch 'mii info' will show 'phantom' devices because the value will be not be initialized and return with some random value. Signed-off-by: Richard Retanubun <RichardRetanubun@RuggedCom.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-06-15Marvell MV88E61XX Switch Driver supportPrafulla Wadaskar
Chips supported:- 1. 88E6161 6 port gbe swtich with 5 integrated PHYs 2. 88E6165 6 port gbe swtich with 5 integrated PHYs 2. 88E6132 3 port gbe swtich with 2 integrated PHYs Platform specific configuration supported for:- default or router port vlan configuration led_init configuration mdip/n polarity reversal configuration Note: This driver is supported and tested against kirkwood egiga interface Contributors: Yotam Admon <yotam@marvell.com> Michael Blostein <michaelbl@marvell.com Reviewed by: Ronen Shitrit <rshitrit@marvell.com> Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-08-29miiphyutil: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-08-29miiphybb: move to drivers/net/phyJean-Christophe PLAGNIOL-VILLARD
