path: root/drivers/net/phy/marvell.c
2013-06-24NET: phy: add 88E1310 PHY initializationSebastian Hesselbarth
This adds PHY initialization for Marvell Alaska 88E1310 PHY. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
2013-04-30net: phy: Define Marvell 88e1518 phyMichal Simek
This phy is used on zedboard (xilinx zynq platform). Signed-off-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@ti.com>
2012-12-15phy: Add support for Marvell 88E1118RMichal Simek
Marvell 88E1118R has different uid then 88E1118. Signed-off-by: Michal Simek <monstr@monstr.eu> CC: Andy Fleming <afleming@freescale.com> CC: Zang Roy-R61911 <tie-fei.zang@freescale.com> CC: Kumar Gala <galak@kernel.crashing.org>
2011-12-05Phy/Marvell: Rewrite the MV88E1111 phy config function based on kernel codeZang Roy-R61911
The original m88e1111s_config() does not do the SGMII mode initialization and is buggy. Rewrite the function according to 3.0.6 kernel function m88e1111_config_init() in drivers/net/phy/marvell.c Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Acked-by: Andy Fleming <afleming@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org>
2011-04-20phylib: Add a bunch of PHY drivers from tsecAndy Fleming
The tsec driver had a bunch of PHY drivers already written. This converts them all into PHY Lib drivers, and serves as the first set of PHY drivers for PHY Lib. While doing that, cleaned up a number of magic numbers (though not all of them, as PHY vendors like to keep their numbers as magical as possible). Also, noticed that almost all of the vitesse/cicada PHYs had the same config/parse/startup functions, so those have been collapsed into one. Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Detlev Zundel <dzu@denx.de>
