path: root/drivers/net/npe
2014-02-06ARM: NET: Remove the IXP NPE ethernet driverMarek Vasut
This driver is no longer used, remove it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Michael Schwingen <michael@schwingen.org> Cc: Tom Rini <trini@ti.com>
2013-11-25drivers: delete unnecessary HOSTCFLAGSMasahiro Yamada
HOSTCFLAGS is meaningless because no host programs are compiled there. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-17drivers/net/npe: descend only when CONFIG_IXP4XX_NPE=yMasahiro Yamada
CONFIG_IXP4XX_NPE is defined only for CPU ixp. It is not necessary to filter by CPU ixp. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-08cosmetic: remove empty lines at the top of fileMasahiro Yamada
2013-10-31drivers: net: convert makefiles to Kbuild styleMasahiro Yamada
2013-09-20SPDX: fix IBM-pibs license identifierWolfgang Denk
The SPDX License List version 1.19 now contains an official entry for the IBM-pibs license. However, instead of our suggestion "ibm-pibs", the SPDX License List uses "IBM-pibs", with the following rationale: "The reason being that all other SPDX License List short identifiers tend towards using capital letters unless spelling a word. I'd prefer to be consistent to this end". Change the license IDs to use the official name. Signed-off-by: Wolfgang Denk <wd@denx.de>
2013-08-19SPDX-License-Identifier: convert BSD-3-Clause filesWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> [trini Don't remove some copyrights by accident] Signed-off-by: Tom Rini <trini@ti.com>
2013-08-19SPDX-License-Identifier: convert PIBS licensed filesWolfgang Denk
This commit adapts the files that were derived from PIBS (PowerPC Initialization and Boot Software) codeto using SPDX License Identifiers. So far, SPDX has not assigned an official License ID for the PIBS license yet, so this should be considered preliminary. Note that the following files contained incorrect license information: arch/powerpc/cpu/ppc4xx/4xx_uart.c arch/powerpc/cpu/ppc4xx/start.S arch/powerpc/include/asm/ppc440.h These files included, in addition to the GPL-2.0 / ibm-pibs dual license as inherited from PIBS, a GPL-2.0+ license header which was obviously incorrect. This has been removed. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Wolfgang Denk <wd@denx.de> Conflicts: Licenses/README Acked-by: Stefan Roese <sr@denx.de>
2013-08-19net: Use ARRAY_SIZE at appropriate placesAxel Lin
Use ARRAY_SIZE instead of having similar implementation in each drivers. The NUMELEMS defined in drivers/net/npe/include/IxOsalTypes.h is not used at all, so this patch removes it instead of converting it to use ARRAY_SIZE. Signed-off-by: Axel Lin <axel.lin@ingics.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Ben Warren <biggerbadderben@gmail.com> Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Marek Vasut <marex@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Cc: TsiChungLiew <Tsi-Chung.Liew@freescale.com> Cc: Wolfgang Denk <wd@denx.de> Cc: York Sun <yorksun@freescale.com>
2013-04-01Consolidate bool typeYork Sun
'bool' is defined in random places. This patch consolidates them into a single header file include/linux/types.h, using stdbool.h introduced in C99. All other #define, typedef and enum are removed. They are all consistent with true = 1, false = 0. Replace FALSE, False with false. Replace TRUE, True with true. Skip *.py, *.php, lib/* files. Signed-off-by: York Sun <yorksun@freescale.com>
2012-09-24dm: net: Move IXP NPE to drivers/net/Marek Vasut
Signed-off-by: Marek Vasut <marex@denx.de> Cc: Bryan Hundven <bryanhundven@gmail.com> Cc: Michael Schwingen <rincewind@discworld.dascon.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: U-Boot DM <u-boot-dm@lists.denx.de> Cc: Joe Hershberger <joe.hershberger@ni.com>
