path: root/drivers/net/netconsole.c
2018-04-27Remove unnecessary instances of DECLARE_GLOBAL_DATA_PTRTom Rini
We have a large number of places where while we historically referenced gd in the code we no longer do, as well as cases where the code added that line "just in case" during development and never dropped it. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-01-15net: Fix buffer overrun error in netconsoleJoe Hershberger
Need to not access the byte after the input_buffer. Reported-by: Coverity (CID: 144423) Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2017-08-16env: Rename some other getenv()-related functionsSimon Glass
We are now using an env_ prefix for environment functions. Rename these other functions as well, for consistency: getenv_vlan() getenv_bootm_size() getenv_bootm_low() getenv_bootm_mapsize() env_get_default() Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2015-11-05video: Drop DEV_FLAGS_SYSTEM flagBin Meng
DEV_FLAGS_SYSTEM does not have any actual meaning, hence drop it. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-09-29net: fix netconsole when CONFIG_DM_ETH is setBernhard Nortmann
This patch uses the eth_is_active() function to work around issues that prevented compilation with the newer driver model. Signed-off-by: Bernhard Nortmann <bernhard.nortmann@web.de> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-04-18net: cosmetic: Fix checkpatch.pl failures in net.cJoe Hershberger
Finish eliminating CamelCase from net.c and other failures Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Clean up netconsole variables and functionsJoe Hershberger
Make a thorough pass through all variables and function names contained within netconsole.c and remove CamelCase and improve naming. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Cleanup internal packet buffer namesJoe Hershberger
This patch cleans up the names of internal packet buffer names that are used within the network stack and the functions that use them. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2015-04-18net: cosmetic: Name ethaddr variables consistentlyJoe Hershberger
Use "_ethaddr" at the end of variables and drop CamelCase. Make constant values actually 'const'. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Change IPaddr_t to struct in_addrJoe Hershberger
This patch is simply clean-up to make the IPv4 type that is used match what Linux uses. It also attempts to move all variables that are IP addresses use good naming instead of CamelCase. No functional change. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: Remove the bd* parameter from net stack functionsJoe Hershberger
This value is not used by the network stack and is available in the global data, so stop passing it around. For the one legacy function that still expects it (init op on old Ethernet drivers) pass in the global pointer version directly to avoid changing that interface. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reported-by: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> (Trival fix to remove an unneeded variable declaration in 4xx_enet.c)
2014-11-23linux/kernel.h: sync min, max, min3, max3 macros with LinuxMasahiro Yamada
U-Boot has never cared about the type when we get max/min of two values, but Linux Kernel does. This commit gets min, max, min3, max3 macros synced with the kernel introducing type checks. Many of references of those macros must be fixed to suppress warnings. We have two options: - Use min, max, min3, max3 only when the arguments have the same type (or add casts to the arguments) - Use min_t/max_t instead with the appropriate type for the first argument Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Pavel Machek <pavel@denx.de> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com> [trini: Fixup arch/blackfin/lib/string.c] Signed-off-by: Tom Rini <trini@ti.com>
2014-07-23stdio: Pass device pointer to stdio methodsSimon Glass
At present stdio device functions do not get any clue as to which stdio device is being acted on. Some implementations go to great lengths to work around this, such as defining a whole separate set of functions for each possible device. For driver model we need to associate a stdio_dev with a device. It doesn't seem possible to continue with this work-around approach. Instead, add a stdio_dev pointer to each of the stdio member functions. Note: The serial drivers have the same problem, but it is not strictly necessary to fix that to get driver model running. Also, if we convert serial over to driver model the problem will go away. Code size increases by 244 bytes for Thumb2 and 428 for PowerPC. 22: stdio: Pass device pointer to stdio methods arm: (for 2/2 boards) all +244.0 bss -4.0 text +248.0 powerpc: (for 1/1 boards) all +428.0 text +428.0 Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Marek Vasut <marex@denx.de> Reviewed-by: Marek Vasut <marex@denx.de>
2013-11-08netconsole loses 2nd character of inputSuriyan Ramasami
Netconsole loses the second character when used as input by either setenv stdin nc or setenv stdin serial,nc if using CONSOLE_CONSOLE_MUX Before a nc_send_packet() to echo the input, a check is done to see if nc_ether is valid. If its not, it waits for an arp request and then sends the packet (which contains the first character of line to be displayed as output). As part of reaping the arp request, the second character is consumed. We protect this by making the call to NetLoop(NETCONS) between input_recursion. Signed-off-by: Suriyan Ramasami <suriyan.r@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2012-09-24net: Filter incoming netconsole packets by IPJoe Hershberger
Check the incoming packets' source IP address... if ncip isn't set to a broadcast address, only listen to the client at ncip. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-09-24net: Allow netconsole settings to change after nc_startJoe Hershberger
Refresh the netconsole settings from the env before each packet instead of only on netconsole init. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-09-24net: Improve the speed of netconsoleJoe Hershberger
Previously u-boot would initialize the network interface for every network operation and then shut it down again. This makes sense for most operations where the network in not known to be needed soon after the operation is complete. In the case of netconsole, it will use the network for every interaction with the shell or every printf. This means that the network is being reinitialized very often. On many devices, this intialization is very slow. This patch checks for consecutive netconsole actions and leaves the ethernet hardware initialized between them. It will still behave the same old way for all other network operations and any time another network operation happens between netconsole operations. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2012-09-24net: Make the netconsole buffer size configurableJoe Hershberger
Allow a board to configure a larger buffer for netconsole, but leave the default. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Mike Frysinger <vapier@gentoo.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-09-24net: Make netconsole src and dest ports configurableJoe Hershberger
It is desirable to use different port numbers for sending and receiving packets with netconsole in the case where you have more than one device on the local subnet with netconsole enabled for broadcast. When they use the same port for both, any output from one will look like input to the other. This is typlically not desirable. This patch allows the input and output ports to be specified separately in the environment. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Mike Frysinger <vapier@gentoo.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-05-23net: Allow filtering on debug traces in the net subsystemJoe Hershberger
Add several levels of DEBUG prints so that you can limit the noise to the severety of your problem. DEBUG_LL_STATE = Link local state machine changes DEBUG_DEV_PKT = Packets or info directed to the device DEBUG_NET_PKT = Packets on info on the network at large DEBUG_INT_STATE = Internal network state changes Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-05-23net: Make sure NetLoop is initialized when using NetConsoleJoe Hershberger
Fix NetConsole bug that causes first packet header to claim a source IP address of 0.0.0.0 Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-05-23net: Refactor to separate the UDP handler from the ARP handlerJoe Hershberger
Call a built-in dummy if none is registered... don't require protocols to register a handler (eliminating dummies) NetConsole now uses the ARP handler when waiting on arp (instead of needing a #define hack in arp.c) Clear handlers at the end of net loop Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2012-05-23net: Refactor to protect access to the NetState variableJoe Hershberger
Changes to NetState now go through an accessor function called net_set_state() Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-05-23net: cosmetic: Un-typedef IP_tJoe Hershberger
Rename IP header related things to IP_UDP. The existing definition of IP_t includes UDP header, so name it to accurately describe the structure. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-05-15net: cosmetic: netconsole.c checkpatch complianceJoe Hershberger
Requires: --ignore CONSIDER_KSTRTO Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2011-10-09netconsole: support packets longer than 512 bytesMichael Walle
Esp. while printing the environment the output is usually longer than 512 bytes. Instead of cutting the message, send multiple 512 bytes packets. Signed-off-by: Michael Walle <michael@walle.cc> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-05-12NET: pass source IP address to packet handlersLuca Ceresoli
This is needed for the upcoming TFTP server implementation. This also simplifies PingHandler() and fixes rxhand_f documentation. Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-01-18netconsole: mark local funcs with staticMike Frysinger
2009-07-18stdio/device: rework function naming conventionJean-Christophe PLAGNIOL-VILLARD
So far the console API uses the following naming convention: ======Extract====== typedef struct device_t; int device_register (device_t * dev); int devices_init (void); int device_deregister(char *devname); struct list_head* device_get_list(void); device_t* device_get_by_name(char* name); device_t* device_clone(device_t *dev); ======= which is too generic and confusing. Instead of using device_XX and device_t we change this into stdio_XX and stdio_dev This will also allow to add later a generic device mechanism in order to have support for multiple devices and driver instances. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Edited commit message. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-06-09net: Conditional COBJS inclusion of network driversShinya Kuribayashi
Replace COBJS-y with appropriate driver config names. Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2007-11-25drivers/net : move net drivers to drivers/netJean-Christophe PLAGNIOL-VILLARD
