path: root/drivers/net/ne2000.c
2013-08-19net: Use ARRAY_SIZE at appropriate placesAxel Lin
Use ARRAY_SIZE instead of having similar implementation in each drivers. The NUMELEMS defined in drivers/net/npe/include/IxOsalTypes.h is not used at all, so this patch removes it instead of converting it to use ARRAY_SIZE. Signed-off-by: Axel Lin <axel.lin@ingics.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Ben Warren <biggerbadderben@gmail.com> Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Marek Vasut <marex@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Cc: TsiChungLiew <Tsi-Chung.Liew@freescale.com> Cc: Wolfgang Denk <wd@denx.de> Cc: York Sun <yorksun@freescale.com>
2011-10-22consolidate mdelay by providing a common function for all usersAnatolij Gustschin
There are several mdelay() definitions in the driver and board code. Remove them all and provide a common mdelay() in lib/time.c. Signed-off-by: Anatolij Gustschin <agust@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-02-15net: ne2000: Add spport RTL-8019ASNobuhiro Iwamatsu
Add infomation of RTL-8016AS to hw_info. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Ben Warren <biggerbadderben@gmail.com>
2008-10-13net: ne2000: Divided a function of NE2000 driverNobuhiro Iwamatsu
get_prom function was used __attriute__ , but it is not enable. ax88796.o does not do link besides ne2000.o. When ld is carried out, get_prom function of ax88796.c is ignored. This problem is a thing by specifications of ld. I checked and test this patch on SuperH and MIPS. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-07-06net: ne2000: Move dev_addr variable from grobal to local.Nobuhiro Iwamatsu
Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-07-06net: ne2000: Fix compile error of NE2000Nobuhiro Iwamatsu
If enable DEBUG, can not compile ne2000 driver. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-04-28NE2000: Fix regresssion introduced by e710185aae90 on non AX88796Jean-Christophe PLAGNIOL-VILLARD
Move non-inlied functions into specific drivers file Set get_prom as weak Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Vlad Lungu <vlad@comsys.ro> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-04-25NE2000: coding style cleanupJean-Christophe PLAGNIOL-VILLARD
2008-03-26Coding Style cleanyp; update CHANGELOGWolfgang Denk
2008-03-25net: Add support AX88796L ethernet devicegoda.yusuke
AX88796L is device of NE2000 compatible. This patch support AX88796L ethernet device. Signed-off-by: Yusuke Goda <goda.yusuke@renesas.com> Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-03-25ne2000 driver: change #ifdef to Makefile conditional compilationWolfgang Denk
2008-03-25net: Divided code of NE2000 ethernet drivergoda.yusuke
There are more devices of the NE2000 base. A present code is difficult for us to support more devices. To support more NE2000 clone devices, separated the function. Signed-off-by: Yusuke Goda <goda.yusuke@renesas.com> Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-01-09fix various commentsMarcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
2007-11-25drivers/net : move net drivers to drivers/netJean-Christophe PLAGNIOL-VILLARD
