path: root/drivers/net/natsemi.c
2012-05-22drivers/net/natsemi.c: Fix compile warningJoe Hershberger
Fix this: natsemi.c: In function 'natsemi_initialize': natsemi.c:338:13: warning: assignment from incompatible pointer type Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2011-07-28cleanup: Fix typos and misspellings in various files.Mike Williams
Recieve/Receive recieve/receive Interupt/Interrupt interupt/interrupt Addres/Address addres/address Signed-off-by: Mike Williams <mike@mikebwilliams.com>
2010-11-14net: natsemi: Add initialized eth_device structureNobuhiro Iwamatsu
natsemi driver does not have write_hwaddr function. However, eth stuff executes write_hwaddr function because eth_device structure has not been initialized. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-09-15drivers/net/natsemi.c: fix compile warningWolfgang Denk
Fix warning: natsemi.c:757: warning: dereferencing type-punned pointer will break strict-aliasing rules Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Ben Warren <biggerbadderben@gmail.com>
2008-10-21Cleanup: fix "MHz" spellingWolfgang Denk
2008-09-02Moved initialization of NATSEMI Ethernet controller to board_eth_init()Ben Warren
Affected boards: a3000 Removed initialization of the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-06-09net: Conditional COBJS inclusion of network driversShinya Kuribayashi
Replace COBJS-y with appropriate driver config names. Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2007-11-25drivers/net : move net drivers to drivers/netJean-Christophe PLAGNIOL-VILLARD
