path: root/drivers/net/mvgbe.c
2013-11-22NET: mvgbe: avoid unused variable warning when used without phylib supportSascha Silbe
Avoid a recently introduced unused variable warning for boards that use mvgbe but not phylib. Signed-off-by: Sascha Silbe <t-uboot@infra-silbe.de> Patch: 266334
2013-06-24NET: mvgbe: add support for DoveSebastian Hesselbarth
Marvell Dove also uses mvgbe as ethernet driver, therefore add support for Dove to reuse the current driver. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
2013-06-24NET: mvgbe: add phylib supportSebastian Hesselbarth
This add phylib support to the Marvell GBE driver. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
2012-05-23net: Fix remaining API interface breakageJoe Hershberger
These are all the files which use the API incorrectly but did not get built using MAKEALL -a powerpc|arm. I have no compiler for them, but the remaining issues should be far less than without this patch. Any outstanding issues are left to the maintainers of boards that use these drivers. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-04-03mvgbe: remove warning for unused methodsStefan Bigler
Some baords may use the GBE interface but they have no phy connected to the interface and a direct MAC/MAC interface. For them we need to get rid of compiler warnings. Signed-off-by: Stefan Bigler <stefan.bigler@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Acked-by: Prafulla Wadaskar <prafulla@marvell.com>
2012-03-18net/miiphy/serial: drop duplicate "NAMESIZE" defineMike Frysinger
A few subsystems are using the same define "NAMESIZE". This has been working so far because they define it to the same number. However, I want to change the size of eth_device's NAMESIZE, so rather than tweak the define names, simply drop references to it. Almost no one does, and the handful that do can easily be changed to a sizeof(). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-12-20mvgbe: remove setting of ethaddr within the driverMichael Walle
A network driver should not touch the environment at all. This patch fixes this behaviour by removing the code for setting a default/randomized MAC address. Signed-off-by: Michael Walle <michael@walle.cc> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Prafulla Wadaskar <prafulla@marvell.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Valentin Longchamp <valentin.longchamp@keymile.com> Cc: Eric Cooper <ecc@cmu.edu> Cc: Jason Cooper <u-boot@lakedaemon.net> Cc: Siddarth Gore <gores@marvell.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Simon Guinot <simon.guinot@sequanux.org> Acked-by: Prafulla Wadaskar <prafulla@marvell.com>
2011-12-05drivers/net/mvgbe.c: Fix GCC 4.6 warningsAnatolij Gustschin
Fix: mvgbe.c: In function 'mvgbe_send': mvgbe.c:555:2: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing] mvgbe.c: In function 'mvgbe_recv': mvgbe.c:640:2: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing] Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Acked-By: Prafulla Wadaskar <prafulla@marvell.com>
2011-11-03ARM: DockStar: fix compilationAnatolij Gustschin
Fix build problem: mvgbe.c: In function 'mvgbe_initialize': mvgbe.c:735: warning: implicit declaration of function 'get_random_hex' dockstar.c: In function 'board_early_init_f': dockstar.c:43: warning: implicit declaration of function 'kw_config_gpio' dockstar.c: In function 'board_init': dockstar.c:113: warning: implicit declaration of function 'kw_sdram_bar' dockstar.c: In function 'set_leds': dockstar.c:161: warning: implicit declaration of function 'readl' dockstar.c:161: error: dereferencing pointer to incomplete type dockstar.c:162: warning: implicit declaration of function 'writel' dockstar.c:162: error: dereferencing pointer to incomplete type dockstar.c:163: error: dereferencing pointer to incomplete type dockstar.c:164: error: dereferencing pointer to incomplete type make[1]: *** [dockstar.o] Error 1 make: *** [board/Seagate/dockstar/libdockstar.o] Error 2 Reported-by: Roland Kletzing <devzero@web.de> Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Prafulla Wadaskar <prafulla@marvell.com>
2011-10-27ARM: kirkwood: reduce dependence of including platform fileLei Wen
For files like the drivers/serial/serial.c, it must include the platform file, as the CONFIG_SYS_NS16550_COM1 must reference to the definition in the platform definition files. Include the platform definition file in the config file, so that it would decouple the dependence for the driver files. Signed-off-by: Lei Wen <leiwen@marvell.com>
2010-08-09miiphy: constify device nameMike Frysinger
The driver name does not need to be writable, so constify it. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-07-12mvgbe: add support for orion5x GbE controllerAlbert Aribaud
Add definitions and initialization in orion5x for mvgbe. Add orion5x in mvgbe SoC includes. Signed-off-by: Albert Aribaud <albert.aribaud@free.fr> Acked-by: Prafulla Wadaskar <prafulla@marvell.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-07-12mvgbe: support SoCs other than kirkwoodAlbert Aribaud
Rename all references to kirkwood in mvgbe symbols throughout the whole codebase. Signed-off-by: Albert Aribaud <albert.aribaud@free.fr> Acked-by: Prafulla Wadaskar <prafulla@marvell.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-07-12net: rename: kirkwood_egiga as mvgbeAlbert Aribaud
Rename kirkwood_egiga.* to mvgbe.* and adjust makefile and #include accordingly. Signed-off-by: Albert Aribaud <albert.aribaud@free.fr> Acked-by: Prafulla Wadaskar <prafulla@marvell.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
