path: root/drivers/net/mpc512x_fec.c
2012-05-22drivers/net/mpc512x_fec.c: Fix build warningAnatolij Gustschin
Fix: mpc512x_fec.c: In function 'mpc512x_fec_initialize': mpc512x_fec.c:634: warning: assignment from incompatible pointer type Tested on mpc5121ads board using tftp and nfs commands. Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com>
2011-10-05net: drop !NET_MULTI codeMike Frysinger
This is long over due. All but two net drivers have been converted, but those have now been dropped. The only thing left to do is actually delete all references to NET_MULTI and code that is compiled when that is not defined. So here we scrub the core code. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-08-09miiphy: constify device nameMike Frysinger
The driver name does not need to be writable, so constify it. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-08-09net ppc: fix ethernet device names with spacesHeiko Schocher
since commit 1384f3bb8a4f9066805b70c1418eda78ecb73fdd ethernet names with spaces drop a Warning: eth device name has a space! message. This patch fix it for: - "FEC ETHERNET" devices found on mpc512x, mpc5xxx, mpc8xx and mpc8220 boards. renamed to "FEC". - "SCC ETHERNET" devices found on mpc8xx, mpc82xx based boards. Renamed to "SCC". - "HDLC ETHERNET" devices found on mpc8xx boards Renamed to "HDLC" - "FCC ETHERNET" devices found on mpc8260 and mpc85xx based boards. Renamed to "FCC" Tested on the kup4k board. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-05-03mpc512x_fec: Move PHY initialization from probe into init routine.Detlev Zundel
This saves the autonegotation delay when not using ethernet in U-Boot Signed-off-by: Detlev Zundel <dzu@denx.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-05-03Remove unused "local_crc32" function.Detlev Zundel
For code archeologists, this is a nice example of copy and paste history. Signed-off-by: Detlev Zundel <dzu@denx.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-06-12MPC512x: remove include/mpc512x.hWolfgang Denk
Move needed definitions (register descriptions etc.) from include/mpc512x.h into include/asm-ppc/immap_512x.h. Instead of using a #define'd register offset, use a function that provides the PATA controller's base address. All the rest of include/mpc512x.h are register offset definitions which can be eliminated by proper use of C structures. There are only a few register offsets remaining that are needed in cpu/mpc512x/start.S; for these we provide cpu/mpc512x/asm-offsets.h which is intended as a temporary workaround only. In a later patch this file will be removed, too, and then auto-generated from the respective C structs. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: John Rigby <jcrigby@gmail.com>
2009-06-12MPC512x FEC: get rid of duplicated struct ethernet_regsWolfgang Denk
Use existing struct fec512x instead. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: John Rigby <jcrigby@gmail.com> Acked-by: Ben Warren <biggerbadderben@gmail.com>
2009-06-12MPC512x: use I/O accessors instead of pointer accessesWolfgang Denk
This commit changes the MPC512x code to use I/O accessor calls (i.e. out_*() and in_*()) instead of using deprecated pointer accesses. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: John Rigby <jcrigby@gmail.com>
2008-09-12MPC512x: reduce timeout waiting for Ethernet autonegotiation to 2.5sWolfgang Denk
2008-09-02Moved initialization of MPC512x_FEC Ethernet driver to CPU directoryBen Warren
Added a cpu_eth_init() function to MPC512x CPU directory and removed code from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-08-29Move MPC512x_FEC driver to drivers/netBen Warren
