path: root/drivers/net/mcfmii.c
2016-08-15net: mii: Changes not made by spatchJoe Hershberger
If the functions passed to the registration function are not in the same C file (extern) then spatch will not handle the dependent changes. Make those changes manually. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> For the 4xx related files: Acked-by: Stefan Roese <sr@denx.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2013-08-19net: Use ARRAY_SIZE at appropriate placesAxel Lin
Use ARRAY_SIZE instead of having similar implementation in each drivers. The NUMELEMS defined in drivers/net/npe/include/IxOsalTypes.h is not used at all, so this patch removes it instead of converting it to use ARRAY_SIZE. Signed-off-by: Axel Lin <axel.lin@ingics.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Ben Warren <biggerbadderben@gmail.com> Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Marek Vasut <marex@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Cc: TsiChungLiew <Tsi-Chung.Liew@freescale.com> Cc: Wolfgang Denk <wd@denx.de> Cc: York Sun <yorksun@freescale.com>
2012-10-19m68k: net: Fix unused variable in mcfmii.cMarek Vasut
The following warning was produced, fix it: mcfmii.c: In function 'mcffec_miiphy_write': mcfmii.c:318:8: warning: variable 'rdreg' set but not used [-Wunused-but-set-variable] Signed-off-by: Marek Vasut <marex@denx.de> Cc: "Jin Zhengxiong-R64188" <R64188@freescale.com> Cc: Jason Jin <jason.jin@freescale.com>
2011-10-05net: drop !NET_MULTI codeMike Frysinger
This is long over due. All but two net drivers have been converted, but those have now been dropped. The only thing left to do is actually delete all references to NET_MULTI and code that is compiled when that is not defined. So here we scrub the core code. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-01-09miiphy: convert to linux/mii.hMike Frysinger
The include/miiphy.h header duplicates a lot of things from linux/mii.h. So punt all the things that overlap to keep the API simple and to make merging between U-Boot and Linux simpler. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-08-09miiphy: constify device nameMike Frysinger
The driver name does not need to be writable, so constify it. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-05-03fix lockup in mcfmii/mii_discover_phy() in case communication failsWolfgang Wegner
Signed-off-by: Wolfgang Wegner <w.wegner@astro-kom.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-06-15Subject: [PATCH] [repost] Standardize the use of MCFFEC_TOUT_LOOP as a ↵Richard Retanubun
udelay(1) loop counter. From 584b5fbd4abfc43f920cc1c329633e03816e28be Mon Sep 17 00:00:00 2001 From: Richard Retanubun <RichardRetanubun@RuggedCom.com> Date: Wed, 20 May 2009 18:26:01 -0400 Subject: [PATCH] Standardize the use of MCFFEC_TOUT_LOOP as a udelay(1) loop counter. Signed-off-by: Richard Retanubun <RichardRetanubun@RuggedCom.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-02-06Coldfire: mcfmii: Allow non-autonegotiating PHYs to use mii commandRichard Retanubun
Modified mii_init to support boards with PHYs that are not set to autonegotiate, but still want to use u-boot's mii commands to probe the smi bus. Such PHYs will not set the Autonegotiate-done bit. Signed-off-by: Richard Retanubun <RichardRetanubun@RuggedCom.com>
2008-11-09ColdFire: Add mii driver in drivers/netTsiChung Liew
All CF platforms' mii.c are consolidated into one Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
