path: root/drivers/net/mcffec.c
2016-08-15net: mii: Use spatch to update miiphy_registerJoe Hershberger
Run scripts/coccinelle/net/mdio_register.cocci on the U-Boot code base. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-04-18net: cosmetic: Fix var naming net <-> eth driversJoe Hershberger
Update the naming convention used in the network stack functions and variables that Ethernet drivers use to interact with it. This cleans up the temporary hacks that were added to this interface along with the DM support. This patch has a few remaining checkpatch.pl failures that would be out of the scope of this patch to fix (drivers that are in gross violation of checkpatch.pl). Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2013-08-19net: Use ARRAY_SIZE at appropriate placesAxel Lin
Use ARRAY_SIZE instead of having similar implementation in each drivers. The NUMELEMS defined in drivers/net/npe/include/IxOsalTypes.h is not used at all, so this patch removes it instead of converting it to use ARRAY_SIZE. Signed-off-by: Axel Lin <axel.lin@ingics.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Ben Warren <biggerbadderben@gmail.com> Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Marek Vasut <marex@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Cc: TsiChungLiew <Tsi-Chung.Liew@freescale.com> Cc: Wolfgang Denk <wd@denx.de> Cc: York Sun <yorksun@freescale.com>
2012-05-23net: Fix remaining API interface breakageJoe Hershberger
These are all the files which use the API incorrectly but did not get built using MAKEALL -a powerpc|arm. I have no compiler for them, but the remaining issues should be far less than without this patch. Any outstanding issues are left to the maintainers of boards that use these drivers. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2011-01-09miiphy: convert to linux/mii.hMike Frysinger
The include/miiphy.h header duplicates a lot of things from linux/mii.h. So punt all the things that overlap to keep the API simple and to make merging between U-Boot and Linux simpler. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-03-20drivers/net/: get mac address from environmentMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. The drivers that get converted here: 3c589 4xx_enet dc2114x dm9000x enc28j60 fsl_mcdmafec ks8695eth mcffec rtl8019 rtl8169 s3c4510b_eth xilinx_emac xilinx_emaclite Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com> CC: Rolf Offermanns <rof@sysgo.de> CC: Stefan Roese <sr@denx.de> CC: Sascha Hauer <saschahauer@web.de> CC: TsiChung Liew <Tsi-Chung.Liew@freescale.com> CC: Greg Ungerer <greg.ungerer@opengear.com> CC: Xue Ligong <lgxue@hotmail.com> CC: Masami Komiya <mkomiya@sonare.it> CC: Curt Brune <curt@cucy.com> CC: Michal SIMEK <monstr@monstr.eu>
2008-11-09ColdFire: Add mii driver in drivers/netTsiChung Liew
All CF platforms' mii.c are consolidated into one Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02Introduce netdev.h header file and remove externsBen Warren
This addresses all drivers whose initializers have already been moved to board_eth_init()/cpu_eth_init(). Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-08-26ColdFire: Add FEC Buffer descriptors in SRAMTsiChung Liew
Add FEC Buffer descriptors and data buffer in SRAM for faster execution and access. Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-08-26Fix ColdFire FEC warning messagesTsiChung Liew
Types mismatch and implicit declaration of icache_invalid() warning messages Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-08-26Moved initialization of MCFFEC Ethernet driver to CPU directoryBen Warren
Added a cpu_eth_init() function to coldfire CPU directories and removed code from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-06-09net: Conditional COBJS inclusion of network driversShinya Kuribayashi
Replace COBJS-y with appropriate driver config names. Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-06-02ColdFire: Add 10 base ethernet support for mcf5445xTsiChung Liew
2008-03-30ColdFire: Fix FEC transmit issue for MCF5275Tsi-Chung Liew
2007-08-19Fix some build errors.Wolfgang Denk
2007-08-16ColdFire: Add M54455EVB for MCF5445xTsiChungLiew
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
2007-08-16ColdFire: MCF5329 Update and cleanupTsiChungLiew
2007-08-08Declared attributes of void __mii_init(void) as an alias for int mii_init(void)TsiChungLiew
2007-07-10Cache update and added CFG_UNIFY_CACHETsiChung
Enabled cache in cpu_init_f() for faster flash to mem allocation. Updated cache handling in start.S. Applied cache invalidate in fec_send() and fec_recv(). Added CFG_UNIFY_CACHE for CF V3 only. Signed-off-by: TsiChung <tcliew@Goku.(none)>
2007-07-10Header file update, clean up and cache handlingTsiChungLiew
Replaced immap_5329.h and m5329.h with immap.h. Included cache_invalid. Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
2007-06-18Added M5329AFEE and M5329BFEE PlatformsTsiChung Liew
Added board/freescale/m5329evb, cpu/mcf532x, drivers/net, drivers/serial, immap_5329.h, m5329.h, mcfrtc.h, include/configs/M5329EVB.h, lib_m68k/interrupts.c, and rtc/mcfrtc.c Modified CREDITS, MAKEFILE, Makefile, README, common/cmd_bdinfo.c, common/cmd_mii.c, include/asm-m68k/byteorder.h, include/asm-m68k/fec.h, include/asm-m68k/io.h, include/asm-m68k/mcftimer.h, include/asm-m68k/mcfuart.h, include/asm-m68k/ptrace.h, include/asm-m68k/u-boot.h, lib_m68k/Makefile, lib_m68k/board.c, lib_m68k/time.c, net/eth.c and rtc/Makefile Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
