path: root/drivers/net/macb.h
2019-07-25net: macb: add support for faster clk ratesRamon Fried
add support for clock rates higher than 2.4Mhz Signed-off-by: Ramon Fried <rfried.dev@gmail.com> Reviewed-by: Anup Patel <anup.patel@wdc.com> Tested-by: Anup Patel <anup.patel@wdc.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2019-07-25net: macb: sync header definitions as taken from LinuxRamon Fried
Few registers and bits were added by Cadence and they were not updated in the headers. Take the latest definitions as defined in Linux header (5.1) that also includes some comments about existing registers. One register was improperly named (UR), fix that. Signed-off-by: Ramon Fried <rfried.dev@gmail.com> Reviewed-by: Anup Patel <anup.patel@wdc.com> Tested-by: Anup Patel <anup.patel@wdc.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-01-15net: macb: Add support for Xilinx Zynq SoCWilson Lee
Although Xilinx Zynq SoC was using MACB similar hardware. However, U-boot MACB driver was not supporting Xilinx Zynq SoC. This patch is to add support for the Xilinx Zynq SoC to the existing MACB network driver. This patch is to add Zynq GEM DMA Config, provide callback function for different linkspeed for case of using Xilinx Zynq Programmable Logic as GMII to RGMII converter. This patch convert the return value to use error codes. Signed-off-by: Wilson Lee <wilson.lee@ni.com> Cc: Chen Yee Chew <chen.yee.chew@ni.com> Cc: Keng Soon Cheah <keng.soon.cheah@ni.com> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Wenyou Yang <wenyou.yang@atmel.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-08-11net: macb: add gmac multi-queue supportWu, Josh
This patch refer to linux kernel commit: d8b763e1e79f net/macb: add TX multiqueue support for gem by: Cyrille Pitchen 1. macb driver will check the register to find how many queues support for this chip. 2. Then as we only use queue0 for tx, so we will set up all other queues use a dummy descriptor, which USED bit is set. So those queues are not used. Signed-off-by: Josh Wu <josh.wu@atmel.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2013-11-04net: macb: get DMA bus width from design config registerBo Shen
Get DMA bus width from design config register Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-06-24net: macb: add support for gigabit MACBo Shen
Add gigabit MAC support in macb driver - using IP version to distinguish whether MAC is GMAC Signed-off-by: Bo Shen <voice.shen@atmel.com>
2008-02-14AT91CAP9 support : MACB changesStelian Pop
Signed-off-by: Stelian Pop <stelian <at> popies.net> Acked-by: Haavard Skinnemoen <hskinnemoen <at> atmel.com>
2007-11-25drivers/net : move net drivers to drivers/netJean-Christophe PLAGNIOL-VILLARD
