path: root/drivers/net/macb.c
2014-11-17net: macb: enable GMAC IP without GE feature supportBo Shen
The User Register in GMAC IP is used to select interface type. When with GE feature, it is used to select interface between RGMII and GMII. If without GE feature, it is used to select interface between MII and RMII. Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-11-17net: macb: write mac address when initializationBo Shen
When boot up without mac address setting, it will give the warning message like: "Warning: failed to set MAC address", however when execute network related command, it still execute them without any warning information. With this patch, it will exit directly with following information: "gmac0: mac address is not valid" It also solve the problem after bootup then set mac address and the mac address won't set to net device issue. Signed-off-by: Bo Shen <voice.shen@atmel.com> Tested-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-10-10macb: simplify gmac initialisationAndreas Bießmann
Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Bo Shen <voice.shen@atmel.com>
2014-06-14net: macb: enable dcache in macbWu, Josh
Add to code to flush the dcache after we writing in DMA buffer. Also we need invalidate the dcache before we check the status in the DMA buffer. Tested in SAMA5D3x-EK with gmac0. Tftp download speed shows in below: Disable DCache: 1.1 MiB/s Enable DCache: 1.6 MiB/s Increase speed with about 40%. The code should have no impact with the boards which are not enable_dcache(). Tested in AT91SAM9M10G45EK. Signed-off-by: Josh Wu <josh.wu@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-06-14macb: make checkpatch cleanAndreas Bießmann
This also renames the CONFIG_SYS_MACB_xx defines. They are used just local and therefore don't need the CONFIG_SYS_ prefix. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Reviewed-by: Josh Wu <josh.wu@atmel.com>
2013-11-04net: macb: get DMA bus width from design config registerBo Shen
Get DMA bus width from design config register Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-08-22net: macb: fix the following building warningBo Shen
fix the following building warning ---8>--- macb.c: In function 'macb_init': macb.c:400:14: warning: 'phydev' may be used uninitialized in this function macb.c:377:21: note: 'phydev' was declared here ---<8--- Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-06-24net: macb: add support for gigabit MACBo Shen
Add gigabit MAC support in macb driver - using IP version to distinguish whether MAC is GMAC Signed-off-by: Bo Shen <voice.shen@atmel.com>
2013-06-24net: macb: using phylib to configure phy deviceBo Shen
using phylib to configure phy device in macb driver Signed-off-by: Bo Shen <voice.shen@atmel.com>
2013-06-24net: macb: using AT91FAMILY replace #ifdeferryBo Shen
Using CONFIG_AT91FAMILY replace #ifdeferry for atmel SoC Signed-off-by: Bo Shen <voice.shen@atmel.com> Acked-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-06-24net: Fix build regression in macb.cJoe Hershberger
The added weak symbol must not be static. This was introduced in 416ce623fbad51af57660346ebb6f7befb88b3c9 Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2013-06-24net/macb: Add arch specific routine to get mdio controlShiraz Hashim
SPEAr310 and SPEAr320 Ethernet interfaces share same MDIO lines to control their respective phys. Currently there is a fixed configuration in which only a particular MAC can use the MDIO lines. Call an arch specific function to take control of specific mdio lines at runtime. Signed-off-by: Shiraz Hashim <shiraz.hashim@st.com> Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Acked-by: Stefan Roese <sr@denx.de>
2012-11-04include/linux/byteorder: import latest endian definitions from linuxKim Phillips
u-boot's byteorder headers did not contain endianness attributions for use with sparse, causing a lot of false positives. Import the kernel's latest definitions, and enable them by including compiler.h and types.h. They come with 'const' added for some swab functions, so fix those up, too: include/linux/byteorder/big_endian.h:46:2: warning: passing argument 1 of '__swab64p' discards 'const' qualifier from pointer target type [enabled by default] Also, note: u-boot's historic __BYTE_ORDER definition has been preserved (for the time being at least). We also remove ad-hoc barrier() definitions, since we're including compiler.h in files that hadn't in the past: macb.c:54:0: warning: "barrier" redefined [enabled by default] In addition, including compiler.h in byteorder changes the 'noinline' definition to expand to __attribute__((noinline)). This fixes arch/powerpc/lib/bootm.c: bootm.c:329:16: error: attribute '__attribute__': unknown attribute bootm.c:329:16: error: expected ')' before '__attribute__' bootm.c:329:25: error: expected identifier or '(' before ')' token powerpc sparse builds yield: include/common.h:356:22: error: marked inline, but without a definition the unknown-reason inlining without a definition is considered obsolete given it was part of the 2002 initial commit, and no arm version was 'fixed.' also fixed: ydirectenv.h:60:0: warning: "inline" redefined [enabled by default] and: Configuring for devconcenter - Board: intip, Options: DEVCONCENTER make[1]: *** [4xx_ibm_ddr2_autocalib.o] Error 1 make: *** [arch/powerpc/cpu/ppc4xx/libppc4xx.o] Error 2 powerpc-fsl-linux-size: './u-boot': No such file 4xx_ibm_ddr2_autocalib.c: In function 'DQS_autocalibration': include/asm/ppc4xx-sdram.h:1407:13: sorry, unimplemented: inlining failed in call to 'ppc4xx_ibm_ddr2_register_dump': function body not available 4xx_ibm_ddr2_autocalib.c:1243:32: sorry, unimplemented: called from here and: In file included from crc32.c:50:0: crc32table.h:4:1: warning: implicit declaration of function '___constant_swab32' [-Wimplicit-function-declaration] crc32table.h:4:1: error: initializer element is not constant crc32table.h:4:1: error: (near initialization for 'crc32table_le[0]') Signed-off-by: Kim Phillips <kim.phillips@freescale.com> [trini: Remove '#endif' in include/common.h around setenv portion] Signed-off-by: Tom Rini <trini@ti.com>
2012-09-04Merge branch 'master' of git://git.denx.de/u-boot-avr32Wolfgang Denk
* 'master' of git://git.denx.de/u-boot-avr32: net:macb: add line break avr32:portmux: fix setup for macb1 avr32: Remove redundant LDSCRIPT definition Signed-off-by: Wolfgang Denk <wd@denx.de>
2012-09-03net:macb: add line breakAndreas Bießmann
Without this patch we see annoying output like this: ---8<--- U-Boot> dhcp macb1: PHY not foundmacb0: PHY present at 1 macb0: Starting autonegotiation... --->8--- Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> cc: Joe Hershberger <joe.hershberger@gmail.com>
2012-09-01arm : Atmel : add at91sam9x5ek board supportBo Shen
Add at91sam9x5ek board support, this board support the following SoCs AT91SAM9G15, AT91SAM9G25, AT91SAM9G35, AT91SAM9X25, AT91SAM9X35 Using at91sam9x5ek_nandflash to configure for the board Now only supports NAND with software ECC boot up Signed-off-by: Bo Shen <voice.shen@atmel.com> [move MAINTAINERS entry to right place] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-05-22drivers/net/macb.c: Fix compile warningJoe Hershberger
Fix this: macb.c: In function 'macb_eth_initialize': macb.c:564:15: warning: assignment from incompatible pointer type Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com>
2011-06-21macb: fix compile warningandreas.devel@googlemail.com
This patch fixes following compile warning: ---8<--- macb.c: In function 'macb_write_hwaddr': macb.c:525:2: warning: dereferencing type-punned pointer will break strict-aliasing rules --->8--- Signed-off-by: Andreas Bießmann <andreas.devel@gmail.com>
2011-05-18ATMEL: fix related common atmel driver filesReinhard Meyer
Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-08-09miiphy: constify device nameMike Frysinger
The driver name does not need to be writable, so constify it. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-07-12Write MAC address automatically on MACB-based boardsBen Warren
Also, remove all calls to eth_init() in boards that use MACB Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-01-31macb: Fix mii_phy_read and mii_phy_write functionsSemih Hazar
Enabling CONFIG_CMD_MII in AVR32 boards was not possible due to compile errors. This patch fixes miiphy_read and miiphy_write functions and registers them properly. Signed-off-by: Semih Hazar <semih.hazar@indefia.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-07-12at91: Introduction of at91sam9g45 SOC.Sedji Gaouaou
AT91sam9g45 series is an ARM 926ej-s SOC family clocked at 400/133MHz. It embeds USB high speed host and device, LCD, DDR2 RAM, and a full set of peripherals. The first board that embeds at91sam9g45 chip is the AT91SAM9G45-EKES. On the board you can find 2 USART, USB high speed, a 480*272 LG lcd, ethernet, gpio/joystick/buttons. Signed-off-by: Sedji Gaouaou <sedji.gaouaou@atmel.com>
2009-03-22at91: Support for the at91sam9g20 : Atmel 400Mhz ARM 926ej-s SOC.Nicolas Ferre
AT91sam9g20 is an evolution of the at91sam9260 with a faster clock speed. The AT91SAM9G20-EK board is an updated revision of the AT91SAM9260-EK board. It is essentially the same, with a few minor differences. Here is the chip page on Atmel website: http://www.atmel.com/dyn/products/product_card.asp?part_id=4337 Signed-off-by: Justin Waters <justin.waters@timesys.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-01-28AVR32: macb - Search for PHY idGunnar Rangoy
This patch adds support for searching through available PHY-addresses in the macb-driver. This is needed for the ATEVK1100 evaluation board, where the PHY-address will be initialized to either 1 or 7. This patch adds a config option, CONFIG_MACB_SEARCH_PHY, which when enabled tells the driver to search for the PHY address. Signed-off-by: Gunnar Rangoy <gunnar@rangoy.com> Signed-off-by: Paul Driveklepp <pauldriveklepp@gmail.com> Signed-off-by: Olav Morken <olavmrk@gmail.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02Introduce netdev.h header file and remove externsBen Warren
This addresses all drivers whose initializers have already been moved to board_eth_init()/cpu_eth_init(). Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-06-09net: Conditional COBJS inclusion of network driversShinya Kuribayashi
Replace COBJS-y with appropriate driver config names. Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-05-10AT91SAM9263EK supportStelian Pop
This patch adds support for the AT91SAM9263 chip and the AT91SAM9263EK board. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-04-01Add support for AT91SAM9260EKStelian Pop
Support for booting from internal DataFlash, external DataFlash card or NAND flash is available. Signed-off-by: Stelian Pop <stelian@popies.net>
2008-02-14AT91CAP9 support : MACB changesStelian Pop
Signed-off-by: Stelian Pop <stelian <at> popies.net> Acked-by: Haavard Skinnemoen <hskinnemoen <at> atmel.com>
2008-01-10Fix Ethernet init() return codesBen Warren
Change return values of init() functions in all Ethernet drivers to conform to the following: >=0: Success <0: Failure All drivers going forward should return 0 on success. Current drivers that return 1 on success were left as-is to minimize changes. Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Kim Phillips <kim.phillips@freescale.com> Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Acked-By: Timur Tabi <timur@freescale.com>
2007-11-25drivers/net : move net drivers to drivers/netJean-Christophe PLAGNIOL-VILLARD
