path: root/drivers/net/fm
2019-05-26configs: Migrate CONFIG_FMAN_ENET and some related options to KconfigTom Rini
Move the main symbol for Freescale Fman Ethernet controller option to Kconfig. Also migrate the CONFIG_SYS_QE_FMAN_FW_IN_xxx macros and rename the SPIFLASH one to follow the same format as all of the others. To do this fully we need to migrate CONFIG_QC, do so. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-12-06net: fm: add TFABOOT supportRajesh Bhagat
Adds TFABOOT support and allows to pick FMAN firmware on basis of boot source. Signed-off-by: Pankit Garg <pankit.garg@nxp.com> Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> [YS: fix checkpatch issues] Reviewed-by: York Sun <york.sun@nxp.com>
2018-10-29powerpc: t1040: Correct RCW EC2 settingsBin Meng
Per T1040RM (Rev. 1, 08/2015), there are 2 issues with the RCW EC2 settings. - The value of FSL_CORENET_RCWSR13_EC2_FM1_GPIO is wrong and should be 0x04000000 (value of 1 in RCW bit [420:421]) - Value of 2/3 are reserved in RCW bit [420:421], hence there is no macro FSL_CORENET_RCWSR13_EC2_FM1_DTSEC5_MII. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Poonam Aggrwal <poonam.aggrwal@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-09-27net: fman: Support both new and legacy FMan CompatiblesZhao Qiang
Recently the FMan Port and MAC compatibles were changed. This patch aligns the FMan Port and MAC compatibles to the new FMan device tree binding document. The FMan device tree binding document can be found in the Linux kernel version 3.18.0, commit 297d35fd2a7d3fbd4e5c0f0c1c18213117ba11ba ./Documentation/devicetree/bindings/powerpc/fsl/fman.txt This patch doesn't affect legacy compatibles support. Signed-off-by: Zhao Qiang <qiang.zhao@nxp.com> [York S: reformatted commit message] Reviewed-by: York Sun <york.sun@nxp.com>
2018-09-27ppa/fm/qe: use block layer in ppa/fm/qe driverYinbo Zhu
At present the MMC subsystem maintains its own list of MMC devices. This cannot work with driver model when CONFIG_BLK is enabled, use blk_dread to replace previous mmc read interface, use mmc_get_blk_desc to get the mmc device property. Signed-off-by: Yinbo Zhu <yinbo.zhu@nxp.com> [York S: reformatted commit message] Reviewed-by: York Sun <york.sun@nxp.com>
2017-09-15blk: Remove various places that do flush cache after readBin Meng
All these places seem to inherit the codes from the MMC driver where a FIXME was put in the comment. However the correct operation after read should be cache invalidate, not flush. The underlying drivers should be responsible for the cache operation. Remove these codes completely. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: York Sun <york.sun@nxp.com> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: York Sun <york.sun@nxp.com>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename common functions related to setenv()Simon Glass
We are now using an env_ prefix for environment functions. Rename these commonly used functions, for consistency. Also add function comments in common.h. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-14net: fman: add support RGMII_TXID to memacMadalin Bucur
Signed-off-by: Madalin Bucur <madalin.bucur@nxp.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-07-11net: fm: use get_nand_dev_by_index()Grygorii Strashko
As part of preparation for nand DM conversion the new API has been introduced to remove direct access to nand_info array. So, use it here instead of accessing to nand_info array directly. Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2017-06-02armv8/ls1046a: RGMII PHY requires internal delay on TxMadalin Bucur
2017-06-02armv8/ls1043a: RGMII PHY requires internal delay on TxMadalin Bucur
2017-04-17armv8: ls1043a: Drop macro CONFIG_LS1043AYork Sun
Use CONFIG_ARCH_LS1043A instead. Signed-off-by: York Sun <york.sun@nxp.com>
2017-01-04powerpc: mpc85xx: Remove variant SoCs T1020/T1022/T1013/T1014York Sun
Remove these SoCs from Kconfig because they don't have individual configuration. Clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-12-08net: fman: fix 2.5G SGMII settingsshaohui xie
The settings for 2.5G SGMII are wrong, which the 2.5G case is missed in set_if_mode(), and the serdes PCS configuration are wrong, this patch uses the correct settings took from Linux. Signed-off-by: Shaohui Xie <Shaohui.Xie@nxp.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-11-23powerpc: T4080: Drop configuration for T4080York Sun
There is no T4080 target. Drop related macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T4240: Remove macro CONFIG_PPC_T4240York Sun
Use CONFIG_ARCH_T4240 from Kconfig instead. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T4160: Remove macro CONFIG_PPC_T4160York Sun
Use CONFIG_ARCH_T4160 instead. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T2080, T2081: Remove macro CONFIG_PPC_T2080 and CONFIG_PPC_T2081York Sun
Use CONFIG_ARCH_T2080 and CONFIG_ARCH_T2081 instead. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T1042: Remove macro CONFIG_PPC_T1042York Sun
Replace CONFIG_PPC_T1042 with ARCH_T1024 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T1040: Remove macro CONFIG_PPC_T1040York Sun
Replace CONFIG_PPC_T1040 with ARCH_T1040 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T1024: Remove macro CONFIG_PPC_T1024York Sun
Replace CONFIG_PPC_T1024 with ARCH_T1024 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T1023: Remove macro CONFIG_PPC_T1023York Sun
Replace CONFIG_PPC_T1023 with ARCH_T1023 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: B4420: Remove macro CONFIG_PPC_B4420York Sun
Replace CONFIG_PPC_B4420 with ARCH_B4420 in Kconfig and clean up existing macros.
2016-11-23powerpc: B4860QDS: Remove macro CONFIG_B4860QDSYork Sun
Use CONFIG_TARGET_B4860QDS instead. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: B4860: Remove macro CONFIG_PPC_B4860York Sun
Replace CONFIG_PPC_B4860 with ARCH_B4860 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P5040: Remove macro CONFIG_P5040York Sun
Replace CONFIG_P5040 with ARCH_P5040 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P5020: Remove macro CONFIG_PPC_P5020York Sun
Replace CONFIG_PPC_P5020 with ARCH_P5020 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P4080: Remove macro CONFIG_PPC_P4080York Sun
Replace CONFIG_PPC_P4080 with ARCH_P4080 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P3041: Remove macro CONFIG_PPC_P3041York Sun
Replace CONFIG_PPC_P3041 with ARCH_P3041 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P2041: Remove macro CONFIG_PPC_P2041York Sun
Replace CONFIG_PPC_P2041 with ARCH_P2041 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P1017: Drop configuration for P1017York Sun
P1017 is a single-core version of P1023. There is no P1017 target configured. Drop related macros. P1017 SoC is still supported. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P1023: Remove macro CONFIG_P1023York Sun
Replace CONFIG_P1023 with ARCH_P1023 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-09-26Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
trini: Drop local memset() from examples/standalone/mem_to_mem_idma2intr.c Signed-off-by: Tom Rini <trini@konsulko.com>
2016-09-26armv8: ls1046a: Convert CONFIG_LS1046A to Kconfig option ARCH_LS1046AYork Sun
Move this option to Kconfig and clean up existing uses. Signed-off-by: York Sun <york.sun@nxp.com> CC: Mingkai Hu <mingkai.hu@nxp.com> CC: Gong Qianyu <Qianyu.Gong@nxp.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-14net: fm: fix spi flash probe for using driver modelQianyu Gong
The current code would always use the speed and mode set by CONFIG_ENV_SPI_MAX_HZ and CONFIG_ENV_SPI_MODE. But if using SPI driver model it should get the values from DT. Signed-off-by: Gong Qianyu <Qianyu.Gong@nxp.com> Reviewed-by: Jagan Teki <jteki@openedev.com> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-08-22net/fm: Remove unused code of FMan QMIHou Zhiqiang
The QMan is not used in FMan IM mode, so no QMI enqueue or QMI dequeue are performed. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-07-26drivers: net/fm: Add Fman support for LS1046AMingkai Hu
The Fman module on LS1046A is similiar with that on LS1043A but LS1046A has one more XFI (10GbE) interface. Signed-off-by: Shaohui Xie <Shaohui.Xie@nxp.com> Signed-off-by: Mingkai Hu <mingkai.hu@nxp.com> Signed-off-by: Gong Qianyu <Qianyu.Gong@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-06-03nand: Embed mtd_info in struct nand_chipScott Wood
nand_info[] is now an array of pointers, with the actual mtd_info instance embedded in struct nand_chip. This is in preparation for syncing the NAND code with Linux 4.6, which makes the same change to struct nand_chip. It's in a separate commit due to the large amount of changes required to accommodate the change to nand_info[]. Signed-off-by: Scott Wood <oss@buserror.net>
2016-05-24powerpc:t4240: MAC9 and MAC10 should not be identified as 1G interface in ↵Ying Zhang
some case When using rcw protocols to support 10G on MAC9 and MAC10, these MACs should not be identified as 1G interface, otherwise, one MAC will be listed as two Ethernet ports. For example, MAC9 will be listed as FM1@TGEC1 and FM1@DTSEC9. Signed-off-by: Ying Zhang <b40530@freescale.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-02-24driver/fm: fdt.c: fix fdt_fixup_fman_firmware() to support ARM platformsQianyu Gong
Use fdt32_to_cpu() to convert the data correctly for both endianness platforms. Signed-off-by: Gong Qianyu <Qianyu.Gong@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-02-24fm: fdt: Move fman ucode fixup to driver codeQianyu Gong
Not only powerpc/mpc85xx but also Freescale Layerscape platforms will use fdt_fixup_fman_firmware() to insert Fman ucode blob into the device tree. So move the function to Fman driver code. Signed-off-by: Gong Qianyu <Qianyu.Gong@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-02-24qe: move drivers/qe/qe.h to include/fsl_qe.hQianyu Gong
As the QE firmware struct is shared with Fman, move the header file out of drivers/qe/. Signed-off-by: Gong Qianyu <Qianyu.Gong@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-01-14Fix GCC format-security errors and convert sprintfs.Ben Whitten
With format-security errors turned on, GCC picks up the use of sprintf with a format parameter not being a string literal. Simple uses of sprintf are also converted to use strcpy. Signed-off-by: Ben Whitten <ben.whitten@gmail.com> Acked-by: Wolfgang Denk <wd@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-01-13block: pass block dev not num to read/write/erase()Stephen Warren
This will allow the implementation to make use of data in the block_dev structure beyond the base device number. This will be useful so that eMMC block devices can encompass the HW partition ID rather than treating this out-of-band. Equally, the existence of the priv field is crying out for this patch to exist. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-12-17net: fm: disables unused FM1-DTSEC1 MAC node in DTSShaohui Xie
We don't disable unused FM1-DTSEC1 MAC node in FMAN v2 since it is used by MDIO. For FMAN v3, MDIO uses dedicated controller, so we can disable unused FM1-DTSEC1 MAC node to avoid being probed in Linux. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> [York Sun: revised commit message] Reviewed-by: York Sun <yorksun@freescale.com>
2015-12-17armv8/ls1043a: remove print infoMingkai Hu
Remove verbose message for FMan port. Signed-off-by: Mingkai Hu <Mingkai.Hu@freescale.com> [York Sun: Added commit message] Reviewed-by: York Sun <yorksun@freescale.com>
