path: root/drivers/net/designware.c
2016-09-06meson: odroid-c2: enable Ethernet support through the device treeBeniamino Galvani
Remove the device definition from board file, update the driver with the new compatible property and update config with necessary options. Signed-off-by: Beniamino Galvani <b.galvani@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-07-06net: designware: Make driver independent from DM_GPIO againAlexey Brodkin
Commit 90b7fc924adf "net: designware: support phy reset device-tree bindings" made DW GMAC driver dependent on DM_GPIO by unconditional usage of purely DM_GPIO stuff like: * dm_gpio_XXX() * gpio_request_by_name() But since that driver as of today might be easily used without DM_GPIO (that's the case for Synopsys AXS10x boards) we're shielding all DM_GPIO things by ifdefs. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Simon Glass <sjg@chromium.org> Cc: Beniamino Galvani <b.galvani@gmail.com> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Cc: Sonic Zhang <sonic.zhang@analog.com> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Marek Vasut <marex@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-05-27Merge git://git.denx.de/u-boot-rockchipTom Rini
2016-05-27net: designware: fix descriptor layout and warnings on 64-bit archsBeniamino Galvani
All members of the DMA descriptor must be 32-bit, even on 64-bit architectures: change the type to u32 to ensure this. Also, fix other warnings. Signed-off-by: Beniamino Galvani <b.galvani@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Use phys_addr_t not unsigned long long to test that we're within DMA'able memory] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-05-27net: designware: support phy reset device-tree bindingsSjoerd Simons
Add support for the snps,reset-gpio, snps,reset-active-low (optional) and snps,reset-delays-us device-tree bindings. The combination of these three define how the PHY should be reset to ensure it's in a sane state. Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-02-05net: designware: Use dm_pci_mem_to_phys() in the probe routineBin Meng
Convert to use native DM PCI API dm_pci_mem_to_phys(). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-01-28Merge branch 'master' of git://git.denx.de/u-boot-netTom Rini
2016-01-28net/designware: add support of max-speed device tree propertyAlexey Brodkin
This property allows to specify fastest connection mode supported by the MAC (as opposed to features of the phy). There are situations when phy may handle faster modes than the MAC (or even it's particular implementation or even due to CPU being too slow). This property is a standard one in Linux kernel these days and some boards do already use it in their device tree descriptions. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Sonic Zhang <sonic.zhang@analog.com> cc: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-01-28net/designware: do explicit port selection for 1Gb modeAlexey Brodkin
Current implementation only sets "port select" bit for non-1Gb mode. That works fine if GMAC has just exited reset state but we may as well change connection mode in runtime. Then we'll need to reprogram GMAC for that new mode of operation and if previous mode was 10 or 100 Mb and new one is 1 Gb we'll need to reset port mode bit. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Sonic Zhang <sonic.zhang@analog.com> cc: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-01-14Fix GCC format-security errors and convert sprintfs.Ben Whitten
With format-security errors turned on, GCC picks up the use of sprintf with a format parameter not being a string literal. Simple uses of sprintf are also converted to use strcpy. Signed-off-by: Ben Whitten <ben.whitten@gmail.com> Acked-by: Wolfgang Denk <wd@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-01-12dm: pci: Add a dm_ prefix to pci_get_bdf()Simon Glass
Most driver model PCI functions have a dm_ prefix. At some point, when the old code is converted to driver model and the old functions are removed, we will drop that prefix. For consistency, we should use the dm_ prefix for all driver model functions. Update pci_get_bdf() accordingly. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-12-22net: designware: Zap trailing backslashMarek Vasut
Trailing backslashes are necessary only in macros, not in the actual code, so remove them. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Joe Hershberger <joe.hershberger@ni.com>
2015-12-22net: eth_designware: select PHYLIB in KconfigThomas Chou
Select PHYLIB in drivers/net/Kconfig. And remove CONFIG_PHYLIB from legacy board header files. This fixed the warnings when both ALTERA_TSE and ETH_DESIGNWARE are selected. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reported-by: Pavel Machek <pavel@denx.de> Acked-by: Chin Liang See <clsee@altera.com> Acked-by: Pavel Machek <pavel@denx.de> Tested-by: Pavel Machek <pavel@denx.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-10-29net: designware: Add driver remove supportBin Meng
In designware_eth_probe(), some additional resources are allocated (eg: mdio, phy). We should free these in the driver remove phase. Add designware_eth_remove() to clean it up. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-09-16net: designware: Add support to PCI designware devicesBin Meng
The Designware ethernet controller is also seen on PCI bus, e.g. on Intel Quark SoC. Add this support in the DM version driver. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-09-09net: designware: Fix build warningsBin Meng
When building dm version of designware eth driver on a platform with 64-bit phys_addr_t, it reports the following warnings: drivers/net/designware.c: In function 'designware_eth_probe': drivers/net/designware.c:599:2: warning: format '%lx' expects argument of type 'long unsigned int', but argument 3 has type 'phys_addr_t' [-Wformat] drivers/net/designware.c:600:21: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] drivers/net/designware.c:601:21: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] This commit fixes the build warnings. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-08-08net: designware: Rename the driver var name to eth_designwareMarek Vasut
The driver variable name is eth_sandbox, which is probably a copy-paste mistake. Fix it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-08-08net: designware: Add SoCFPGA GMAC DT compatible stringMarek Vasut
Add the OF compatible property to match the SoCFPGA GMAC. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-07-21dm: eth: Avoid blocking on packet receptionSimon Glass
Some devices can take a long time to work out whether they have a new packet or now. For example the ASIX USB Ethernet dongle can take 5 seconds to do this, since it waits until it gets a new packet on the wire before allowing the USB bulk read packet to be submitted. At present with driver mode the Ethernet receive code reads 32 packets. This can take a very long time if we must wait for all 32 packets. The old code (before driver model) worked by reading a single set of packets from the USB device, then processing all the packets with in. It would be nice to use the same behaviour with driver model. Add a flag to the receive method which indicates that the driver should try to find a packet if available, by consulting the hardware. When the flag is not set, it should just return any packet data it has already received. If there is none, it should return -EAGAIN so that the loop will terminate. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-07-08net: designware: Program MAC address to hardware after soft resetBin Meng
commit f566c99 "net: Update hardware MAC address if it changes in env" removes writing MAC address to designware controller after soft reset. This makes designware ethernet port fail to work. Actually the MAC address should always be programmed after soft reset. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-05-19net: Update hardware MAC address if it changes in envJoe Hershberger
When the ethaddr changes in the env, the hardware should also be updated so that MAC filtering will work properly without resetting U-Boot. Also remove the manual calls to set the hwaddr that was included in a few drivers as a result of the framework not doing it. Reported-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Tested-by: Michal Simek <michal.simek@xilinx.com>
2015-04-18dm: net: Adjust designware driver to support driver modelSimon Glass
Add driver model support to the designware driver. This reuses most of the existing code except for some duplication in the probe() method. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-04-18dm: net: Tidy up designware driver ready for driver modelSimon Glass
Adjust the error handling to use errno.h instead of returning -1. Change leaf functions to pass in the arguments they require rather than struct eth_device. Apart from simplifying the code it makes is easier to reuse these functions for driver model, since mostly they actually only use struct dw_eth_priv (which we can keep). Create a stub for each Ethernet operation function. This will allow use to share code with the driver model versions. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-04-18net: cosmetic: Fix var naming net <-> eth driversJoe Hershberger
Update the naming convention used in the network stack functions and variables that Ethernet drivers use to interact with it. This cleans up the temporary hacks that were added to this interface along with the DM support. This patch has a few remaining checkpatch.pl failures that would be out of the scope of this patch to fix (drivers that are in gross violation of checkpatch.pl). Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-03-05net: Support DMA threshold mode in DWMAC driverSonic Zhang
- DMA threshold mode can be selected in board config head file. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
2015-03-05net: configure DWMAC DMA by default AXI burst lengthSonic Zhang
Board can define its own AXI burst length to improve DWMAC DMA performance. v2-changes: - Avoid write burst len register when the Macro is not defined. v3-changes: - Add axi_bus register member to struct eth_dma_regs. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-01-30net/designware: add error message on DMA reset timeoutAlexey Brodkin
If for some reason DMA module fails to reset user oserves only this: --->--- # dhcp Trying dwmac.e0018000 FAIL --->--- This message makes not much sense. With proposed change error message will be more helpful: --->--- # dhcp Trying dwmac.e0018000 DMA reset timeout FAIL --->--- For example user may do power toggle to recover board functionality. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Pavel Machek <pavel@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Ian Campbell <ijc@hellion.org.uk> Cc: Marek Vasut <marex@denx.de> Reviewed-by: Tom Rini <trini@ti.com> Acked-by: Pavel Machek <pavel@denx.de> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2014-10-06net: dwc: Make the cache handling less crypticMarek Vasut
Add a few new variables to make the cache handling less cryptic. Add a variable for DMA and DATA descriptor start and end, so the correctness of the code is easier to inspect. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Pavel Machek <pavel@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Acked-by: Pavel Machek <pavel@denx.de> Acked-by: Chin Liang See <clsee@altera.com>
2014-10-06net: dwc: Fix cache alignment issuesMarek Vasut
Fix remaining cache alignment issues in the DWC Ethernet driver. Please note that the cache handling in the driver is making the code hideous and thus the next patch cleans that up. In order to make this change reviewable though, the cleanup is split from it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Pavel Machek <pavel@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Acked-by: Pavel Machek <pavel@denx.de>
2014-05-25net/designware: Make DMA burst length configurable and reduce by defaultIan Campbell
The correct value for this setting can vary across SoCs and boards, so make it configurable. Also reduce the default value to 8, which is the same default as used in the Linux driver. Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Cc: Alexey Brodkin <abrodkin@synopsys.com>
2014-05-25net/designware: ensure cache invalidations are aligned to ARCH_DMA_MINALIGNIan Campbell
This is required at least on ARM. When sending instead of simply invalidating the entire descriptor, flush as little as possible while still respecting ARCH_DMA_MINALIGN, as requested by Alexey. Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Cc: Alexey Brodkin <abrodkin@synopsys.com>
2014-05-25net/designware: ensure device private data is DMA aligned.Ian Campbell
struct dw_eth_dev contains fields which are accessed via DMA, so make sure it is aligned to a dma boundary. Without this I see: ERROR: v7_dcache_inval_range - start address is not aligned - 0x7fb677e0 Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Reviewed-by: Alexey Brodkin <abrodkin@synopsys.com> Acked-by: Marek Vasut <marex@denx.de>
2014-05-12net/designware: call phy_connect_dev() to properly setup phylib deviceIan Campbell
This sets up the linkage from the phydev back to the ethernet device. This symptom of not doing this which I noticed was: <NULL> Waiting for PHY auto negotiation to complete.... rather than: dwmac.1c50000 Waiting for PHY auto negotiation to complete.... Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Cc: Alexey Brodkin <Alexey.Brodkin@synopsys.com>
2014-02-07net/designware: make driver compatible with data cacheAlexey Brodkin
Up until now this driver only worked with data cache disabled. To make it work with enabled data cache following changes were required: * Flush Tx/Rx buffer descriptors their modification * Invalidate Tx/Rx buffer descriptors before reading its values * Flush cache for data passed from CPU to GMAC * Invalidate cache for data passed from GMAC to CPU Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Vipin Kumar <vipin.kumar@st.com> Cc: Stefan Roese <sr@denx.de> Cc: Mischa Jonker <mjonker@synopsys.com> Cc: Shiraz Hashim <shiraz.hashim@st.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Amit Virdi <amit.virdi@st.com> Cc: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2014-02-07net/designware - switch driver to phylib usageAlexey Brodkin
With this change driver will benefit from existing phylib and thus custom phy functionality implemented in the driver will go away: * Instantiation of the driver is now much shorter - 2 parameters instead of 4. * Simplified phy management/functoinality in driver is replaced with rich functionality of phylib. * Support of custom phy initialization is now done with existing "board_phy_config". Note that after this change some previously used config options (driver-specific PHY configuration) will be obsolete and they are simply substituted with similar options of phylib. For example: * CONFIG_DW_AUTONEG - no need in this one. Autonegotiation is enabled by default. * CONFIG_DW_SEARCH_PHY - if one wants to specify attached phy explicitly CONFIG_PHY_ADDR board config option has to be used, otherwise automatically the first discovered on MDIO bus phy will be used I believe there's no need now in "doc/README.designware_eth" because user only needs to instantiate the driver with "designware_initialize" whose prototype exists in "include/netdev.h". Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Vipin Kumar <vipin.kumar@st.com> Cc: Stefan Roese <sr@denx.de> Cc: Mischa Jonker <mjonker@synopsys.com> Cc: Shiraz Hashim <shiraz.hashim@st.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Amit Virdi <amit.virdi@st.com> Cc: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2014-02-07net/designware: add explicit reset of {tx|rx}_currdescnumAlexey Brodkin
Driver "init" function might be called multiple times. On every "init" Tx/Rx buffer descriptors are initialized: "descs_init" -> "{tx|rx}_descs_init". In its turn those init functions set MAC's "{tx|rx}desclistaddr" to point on the first buffer descriptor in the list. So CPU to start operation from the first buffer descriptor as well after every "init" we have to reset "{tx|rx}_currdescnum". Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Vipin Kumar <vipin.kumar@st.com> Cc: Stefan Roese <sr@denx.de> Cc: Mischa Jonker <mjonker@synopsys.com> Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2013-11-22net: designware: Respect "bus mode" register contents on SW resetAlexey Brodkin
"bus mode" register contains lots of fields and some of them don't expect to be written with 0 (zero). So since we're only interested in resetting MAC (which is done with setting the least significant bit of this register with "0") I believe it's better to modify only 1 bit of the register. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Acked-by: Vipin Kumar <vipin.kumar@st.com> Patch: 277864
2013-06-24net/designware: Do not select MIIPORT for RGMII interfaceVipin Kumar
Do not select MIIPORT for RGMII interface Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Acked-by: Stefan Roese <sr@denx.de>
2012-07-11net/designware: Consecutive writes to the same register to be avoidedDinh Nguyen
This commit is an add-on to f6c4191f. There are a few registers where consecutive writes to the same location should be avoided or have a delay. According to Synopsys, here is a list of the registers and bit(s) where consecutive writes should be avoided or a delay is required: DMA Registers: Register 0 Bit 7 Register 6 All bits except for 24, 16-13, 2-1. GMAC Registers: Registers 0-3 All bits Registers 6-7 All bits Register 10 All bits Register 11 All bits except for 5-6. Registers 16-47 All bits Register 48 All bits except for 18-16, 14. Register 448 Bit 4. Register 459 Bits 0-3. Signed-off-by: Dinh Nguyen <dinguyen@altera.com> Reviewed-by: Matthew Gerlach <mgerlach@altera.com> Acked-by: Amit Virdi <amit.virdi@st.com>
2012-07-07net: Multiple updates/enhancements to designware.cStefan Roese
This patch adds the following changes to designware ethernet driver found on the ST SPEAr SoC: - Don't init MAC & PHY upon startup. This causes a delay, waiting for the auto negotiation to complete. And we don't want this delay to always happen. Especially not on platforms where ethernet is not used at all (e.g. booting via flash). Instead postpone the MAC / PHY configuration to the stage, where ethernet is first used. - Add possibility for board specific PHY init code. This is needed for example on the X600 board, where the Vitesse PHY needs to be configured for GMII mode. This board specific PHY init is done via the function designware_board_phy_init(). And this driver now adds a weak default which can be overridden by board code. - Use common functions miiphy_speed() & miiphy_duplex() to read link status from PHY. - Print status and progress of auto negotiation. - Print link status (speed, dupex) upon first usage. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Amit Virdi <amit.virdi@st.com> Cc: Vipin Kumar <vipin.kumar@st.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@gmail.com>
2012-07-07SPEAr: Add interface information in initializationVipin Kumar
Few Designware peripheral registers need to be modified based on the ethernet interface selected by the board. This patch supports interface information in ethernet driver Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Signed-off-by: Amit Virdi <amit.virdi@st.com> Signed-off-by: Stefan Roese <sr@denx.de>
2012-05-23net: Fix remaining API interface breakageJoe Hershberger
These are all the files which use the API incorrectly but did not get built using MAKEALL -a powerpc|arm. I have no compiler for them, but the remaining issues should be far less than without this patch. Any outstanding issues are left to the maintainers of boards that use these drivers. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-04-04net/designware: Change timeout loop implementationAmit Virdi
The new implementation changes the timeout loop implementation to avoid 1 ms delay in each failing test. It also configures the delay to 10usec. Signed-off-by: Amit Virdi <amit.virdi@st.com>
2012-04-04net/designware: Set ANAR to 0x1e1Armando Visconti
This patch forces the advertised capabilities during auto negotiation to always be 10/100 Mbps and half/full as duplexing. Signed-off-by: Armando Visconti <armando.visconti@st.com> Signed-off-by: Amit Virdi <amit.virdi@st.com>
2012-04-04net/designware: Program phy registers when auto-negotiation is ONVikas Manocha
If AN(auto-negotiation) is ON, speed bit of control register are not applicable. Also phy registers were not getting programmed as per the result of AN. This patch sets only AN bit & restart AN bit for AN ON selection & programs PHY registers as per AN result. Signed-off-by: Vikas Manocha <vikas.manocha@st.com> Signed-off-by: Amit Virdi <amit.virdi@st.com>
2012-04-04net/designware: Try configuring phy on each dw_eth_initVipin Kumar
Phy autonegotiation works only when the ethernet cable is plugged in. Since the phy was configured only at the init time, a plugged in cable was necessary to initialize the phy properly. This patch keeps a flag to check if the phy initialization has succeeded, and calls configure_phy routine at every init if this flag reports otherwise. Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Signed-off-by: Amit Virdi <amit.virdi@st.com>
2012-04-04net/designware: Consecutive writes must have delayArmando Visconti
This patch solves a TX/RX problem which happens at 10Mbps, due to the fact that we are not respecting 4 cyles of the phy_clk (2.5MHz) between two consecutive writes on the same register. Signed-off-by: Armando Visconti <armando.visconti@st.com> Signed-off-by: Amit Virdi <amit.virdi@st.com>
2012-04-04net/designware: Phy address fixVipin KUMAR
The code assumes the phy address to be > 0, which is not true, the phy address can be in the range 0-31. Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Signed-off-by: Amit Virdi <amit.virdi@st.com>
2012-04-04net/designware: Fix to restore hw mac addressVipin KUMAR
The network controller mac resets hardware address stored in MAC_HI and MAC_LO registers if mac is resetted. So, hw mac address needs to be restored in case mac is explicitly resetted from driver. Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Signed-off-by: Amit Virdi <amit.virdi@st.com>
