path: root/drivers/net/dc2114x.c
2012-05-22drivers/net/dc2114x.c: Fix compile warningJoe Hershberger
Fix this: dc2114x.c: In function 'dc21x4x_initialize': dc2114x.c:305:15: warning: assignment from incompatible pointer type Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com>
2011-10-22net: dc2114x: check for apropriate commandLinus Walleij
The code had two paths depending on whether the card was to be accessed from plain memory or the IO region. However the error path checks whether IO region was obtained - twice. Fix up the error path according to the probable intention. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2010-11-14net: dc2114x: Add initialized eth_device structureNobuhiro Iwamatsu
dc2114x driver does not have write_hwaddr function. However, eth stuff executes write_hwaddr function because eth_device structure has not been initialized. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-03-20drivers/net/: get mac address from environmentMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. The drivers that get converted here: 3c589 4xx_enet dc2114x dm9000x enc28j60 fsl_mcdmafec ks8695eth mcffec rtl8019 rtl8169 s3c4510b_eth xilinx_emac xilinx_emaclite Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com> CC: Rolf Offermanns <rof@sysgo.de> CC: Stefan Roese <sr@denx.de> CC: Sascha Hauer <saschahauer@web.de> CC: TsiChung Liew <Tsi-Chung.Liew@freescale.com> CC: Greg Ungerer <greg.ungerer@opengear.com> CC: Xue Ligong <lgxue@hotmail.com> CC: Masami Komiya <mkomiya@sonare.it> CC: Curt Brune <curt@cucy.com> CC: Michal SIMEK <monstr@monstr.eu>
2008-09-02Moved initialization of TULIP Ethernet controller to board_eth_init()Ben Warren
Affected boards: cu824 bab7xx adciop dasa_sim mousse mpc8540eval musenki mvblue pcippc2/pcippc6 sbc8240 stxssa Removed initialization of the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-06-09net: Conditional COBJS inclusion of network driversShinya Kuribayashi
Replace COBJS-y with appropriate driver config names. Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-01-10Fix Ethernet init() return codesBen Warren
Change return values of init() functions in all Ethernet drivers to conform to the following: >=0: Success <0: Failure All drivers going forward should return 0 on success. Current drivers that return 1 on success were left as-is to minimize changes. Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Kim Phillips <kim.phillips@freescale.com> Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Acked-By: Timur Tabi <timur@freescale.com>
2007-11-25drivers/net : move net drivers to drivers/netJean-Christophe PLAGNIOL-VILLARD
