path: root/drivers/net/cs8900.c
2012-05-22drivers/net/cs8900.c: Fix compile warningJoe Hershberger
Fix this: cs8900.c: In function 'cs8900_initialize': cs8900.c:326:12: warning: assignment from incompatible pointer type Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc Joe Hershberger <joe.hershberger@gmail.com>
2011-11-23drivers/net/cs8900.c: Fix GCC 4.6 warningAnatolij Gustschin
Fix: cs8900.c: In function 'get_reg_init_bus': cs8900.c:69:14: warning: variable 'c' set but not used [-Wunused-but-set-variable] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2010-01-31cs8900_initialize() cleanupMatthias Kaehlcke
cs8900_initialize(): remove unecessary calls to free() and fix memory leak Signed-off-by: Matthias Kaehlcke <matthias@kaehlcke.net> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-11-09Fix CS8900 regression on impa7 boardBen Warren
The following error was seen on impa7 board, due to its use of a 32-bit bus on CS8900. cs8900.c:137:37: error: macro "get_reg_init_bus" passed 2 arguments, but takes just 1 This patch gives the macro the correct number of arguments Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-11-09Fix cs8900 dev->priv not init issueHui.Tang
Ensure all CS8900 data structures are assigned before accessing device Signed-off-by: Hui.Tang <zetalabs@gmail.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-08-25Convert CS8900 Ethernet driver to CONFIG_NET_MULTI APIBen Warren
All in-tree boards that use this controller have CONFIG_NET_MULTI added Also: - changed CONFIG_DRIVER_CS8900 to CONFIG_CS8900 - changed CS8900_BASE to CONFIG_CS8900_BASE - changed CS8900_BUS?? to CONFIG_CS8900_BUS?? - cleaned up line lengths - modified VCMA9 command function that accesses the device - removed MAC address initialization from lib_arm/board.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Tested-by: Wolfgang Denk <wd@denx.de> Acked-by: Wolfgang Denk <wd@denx.de>
2009-03-29cs8900 compile fixLadislav Michl
cs8900.c: In function 'eth_init': cs8900.c:164: warning: passing argument 2 of 'eth_getenv_enetaddr' from incompatible pointer type cs8900.c:165: error: invalid operands to binary << cs8900.c:166: error: invalid operands to binary << cs8900.c:167: error: invalid operands to binary << Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-03-20cs8900: get mac address from environmentMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. The cs8900 driver also changes slightly in that the hardware is not consulted if the mac address in the env is sane. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Marius Groeger <mgroeger@sysgo.de> CC: Ben Warren <biggerbadderben@gmail.com>
2008-06-09net: Conditional COBJS inclusion of network driversShinya Kuribayashi
Replace COBJS-y with appropriate driver config names. Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-04-28minor cs8900 driver clean upGuennadi Liakhovetski
Remove a redundant register definition, clean up some coding style violations. Signed-off-by: Guennadi Liakhovetski <lg@denx.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-02-14Fix remaining CONFIG_COMMANDSJean-Christophe PLAGNIOL-VILLARD
update comments Fix coding style Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2007-11-25drivers/net : move net drivers to drivers/netJean-Christophe PLAGNIOL-VILLARD
