path: root/drivers/net/bfin_mac.h
2012-05-23net: Fix remaining API interface breakageJoe Hershberger
These are all the files which use the API incorrectly but did not get built using MAKEALL -a powerpc|arm. I have no compiler for them, but the remaining issues should be far less than without this patch. Any outstanding issues are left to the maintainers of boards that use these drivers. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2010-05-03Blackfin: bfin_mac: hook up new write_hwaddr functionMike Frysinger
Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-03-20Blackfin: bfin_mac: force boards to setup the MAC themselvesMike Frysinger
Since the on-chip MAC does not have an eeprom or similar interface, force all Blackfin boards that use this driver to setup the board data with a proper MAC. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-02-02Blackfin: bfin_mac: cleanup pointer/casts for aliasing issuesMike Frysinger
Redo how pointers are managed to get rid of ugly casts and strict pointer aliasing issues that are highlighted by gcc 4.3. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Ben Warren <biggerbadderben@gmail.com>
2009-02-02Blackfin: bfin_mac: respect CONFIG_PHY_{ADDR,CLOCK_FREQ}Mike Frysinger
Rather than having the on-chip MAC hardcoded to phy address 1 and a speed of 2.5mhz, use these as defaults if the board doesn't specify otherwise. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Ben Warren <biggerbadderben@gmail.com>
2009-02-02Blackfin: bfin_mac: cleanup MII/PHY functionsMike Frysinger
Cleanup and rewrite the MII/PHY related functions so that we can reuse the existing common linux/miiphy.h code and hook into the `mii` command. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Ben Warren <biggerbadderben@gmail.com>
2008-03-25net/Blackfin: move on-chip MAC driver into drivers/net/Mike Frysinger
The Blackfin on-chip MAC driver was being managed in the BF537-STAMP board directory, but it is not board specific, so relocate it to the drivers dir so that other Blackfin ports can utilize it. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
