path: root/drivers/net/bfin_mac.c
2010-10-02Blackfin: bfin_mac: convert from old style MMR macrosMike Frysinger
The old MMR defines are being scrubbed, so convert the driver to use the new standard helper macros. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-08-09miiphy: constify device nameMike Frysinger
The driver name does not need to be writable, so constify it. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-07-13Blackfin: bfin_mac: remove space from nameMike Frysinger
Some commands (like 'mii') use this name to select devices, but they break when those names contain spaces. So drop the space from the Blackfin EMAC driver. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-13Blackfin: bfin_mac: convert to portmux frameworkMike Frysinger
Rather than bang MMRs directly, use the new portmux framework to handle the details. While we're doing this, let boards declare the exact list of pins they need in case there is one or two they don't actually have hooked up. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Ben Warren <biggerbadderben@gmail.com>
2010-05-03Blackfin: bfin_mac: hook up new write_hwaddr functionMike Frysinger
2009-08-25Add debug message for Blackfin Ethernet Rx function.Robin Getz
Add a simple print for the Blackfin's Ethernet Rx function, so we can debug incomming Ethernet functions easier. Signed-off-by: Robin Getz <rgetz@blackfin.uclinux.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-03-20Blackfin: bfin_mac: force boards to setup the MAC themselvesMike Frysinger
Since the on-chip MAC does not have an eeprom or similar interface, force all Blackfin boards that use this driver to setup the board data with a proper MAC. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-02-02Blackfin: bfin_mac: cleanup pointer/casts for aliasing issuesMike Frysinger
Redo how pointers are managed to get rid of ugly casts and strict pointer aliasing issues that are highlighted by gcc 4.3. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Ben Warren <biggerbadderben@gmail.com>
2009-02-02Blackfin: bfin_mac: convert CONFIG_BFIN_MAC_RMII to CONFIG_RMIIMike Frysinger
No point in having a Blackfin-specific define "CONFIG_BFIN_MAC_RMII" that does exactly the same thing as common "CONFIG_RMII". Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Ben Warren <biggerbadderben@gmail.com>
2009-02-02Blackfin: bfin_mac: use common debug()Mike Frysinger
Rather then defining our own DEBUGF(), just use the common debug(). Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Ben Warren <biggerbadderben@gmail.com>
2009-02-02Blackfin: bfin_mac: respect CONFIG_PHY_{ADDR,CLOCK_FREQ}Mike Frysinger
Rather than having the on-chip MAC hardcoded to phy address 1 and a speed of 2.5mhz, use these as defaults if the board doesn't specify otherwise. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Ben Warren <biggerbadderben@gmail.com>
2009-02-02Blackfin: bfin_mac: cleanup MII/PHY functionsMike Frysinger
Cleanup and rewrite the MII/PHY related functions so that we can reuse the existing common linux/miiphy.h code and hook into the `mii` command. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Ben Warren <biggerbadderben@gmail.com>
2009-02-02Blackfin: bfin_mac: set MDCDIV based on SCLKMike Frysinger
Rather than hardcoding MDCDIV to 24 (which is correct for ~125mhz SCLK), use the real algorithm so it gets set correctly regardless of SCLK. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Ben Warren <biggerbadderben@gmail.com>
2009-01-28Blackfin: bfin_mac: update port muxingMike Frysinger
Adds support more Blackfin parts and fixes broken muxing for older ones. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-09-02Introduce netdev.h header file and remove externsBen Warren
This addresses all drivers whose initializers have already been moved to board_eth_init()/cpu_eth_init(). Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-08-26Moved initialization of Blackfin EMAC Ethernet controller to board_eth_init()Ben Warren
Added board_eth_init() function to bf537-stamp board. Removed initialization for the Blackin EMAC driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-03-25net/Blackfin: move on-chip MAC driver into drivers/net/Mike Frysinger
The Blackfin on-chip MAC driver was being managed in the BF537-STAMP board directory, but it is not board specific, so relocate it to the drivers dir so that other Blackfin ports can utilize it. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
