path: root/drivers/net/bcm-sf2-eth-gmac.c
2017-10-04treewide: replace with error() with pr_err()Masahiro Yamada
U-Boot widely uses error() as a bit noisier variant of printf(). This macro causes name conflict with the following line in include/linux/compiler-gcc.h: # define __compiletime_error(message) __attribute__((error(message))) This prevents us from using __compiletime_error(), and makes it difficult to fully sync BUILD_BUG macros with Linux. (Notice Linux's BUILD_BUG_ON_MSG is implemented by using compiletime_assert().) Let's convert error() into now treewide-available pr_err(). Done with the help of Coccinelle, excluing tools/ directory. The semantic patch I used is as follows: // <smpl> @@@@ -error +pr_err (...) // </smpl> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Re-run Coccinelle] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-03-26net: fix cache misaligned issue in Broadcom SF2 driverSuji Velupillai
Fixed cache misaligned issue in the net driver. The issue shows-up when a call to flush_dcache_range is made with unaligned memory. The memory must be aligned to ARCH_DMA_MINALIGN. Signed-off-by: Suji Velupillai <suji.velupillai@broadcom.com> Tested-by: Suji Velupillai <suji.velupillai@broadcom.com> Reviewed-by: Arun Parameswaran <arun.parameswaran@broadcom.com> Reviewed-by: JD Zheng <jiandong.zheng@broadcom.com> Reviewed-by: Shamez Kurji <shamez.kurji@broadcom.com> Signed-off-by: Steve Rae <steve.rae@raedomain.com> Cover Letter: This series resolves issues specific to the Broadcom SF2 driver: - fix cache misaligned issue - convert to Kconfig END Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-08-15net: mii: Changes not made by spatchJoe Hershberger
If the functions passed to the registration function are not in the same C file (extern) then spatch will not handle the dependent changes. Make those changes manually. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> For the 4xx related files: Acked-by: Stefan Roese <sr@denx.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2014-08-30arm: bcm281xx: net: Add Ethernet DriverJiandong Zheng
The Broadcom StarFighter2 Ethernet driver is used in multiple Broadcom SoC(s) and: - supports multiple MAC blocks, - provides support for the Broadcom GMAC. This driver requires MII and PHYLIB. Signed-off-by: Jiandong Zheng <jdzheng@broadcom.com> Signed-off-by: Steve Rae <srae@broadcom.com>
