path: root/drivers/net/armada100_fec.c
2013-04-01Consolidate bool typeYork Sun
'bool' is defined in random places. This patch consolidates them into a single header file include/linux/types.h, using stdbool.h introduced in C99. All other #define, typedef and enum are removed. They are all consistent with true = 1, false = 0. Replace FALSE, False with false. Replace TRUE, True with true. Skip *.py, *.php, lib/* files. Signed-off-by: York Sun <yorksun@freescale.com>
2012-09-24dm: net: Fixup the armada100 FEC driverMarek Vasut
Apply the following questionable adjustment to silence GCC. armada100_fec.c: In function ‘armdfec_send’: armada100_fec.c:589:2: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing] Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Prafulla Wadaskar <prafulla@marvell.com>
2012-05-22drivers/net/armada100_fec.c: Fix compile warningJoe Hershberger
Fix this: armada100_fec.c: In function 'armada100_fec_register': armada100_fec.c:723:12: warning: assignment from incompatible pointer type Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com>
2012-03-18net/miiphy/serial: drop duplicate "NAMESIZE" defineMike Frysinger
A few subsystems are using the same define "NAMESIZE". This has been working so far because they define it to the same number. However, I want to change the size of eth_device's NAMESIZE, so rather than tweak the define names, simply drop references to it. Almost no one does, and the handful that do can easily be changed to a sizeof(). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-12-06net: Armada100: Fix compilation warningsAjay Bhargav
This patch fix compilation warnings for Armada100 FEC driver Ref: warning: dereferencing type-punned pointer will break strict-aliasing rules Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com> Acked-by: Anatolij Gustschin <agust@denx.de>
2011-09-30net: Adds Fast Ethernet Controller driver for Armada100Ajay Bhargav
This patch adds support for Fast Ethernet Controller driver for Armada100 series. Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com> Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
